Can you install this on your Indigo's Python install?
- Code: Select all
pip install --upgrade certifi
Web Server Warning HTTP API v2 POST command received, id: 'optional-user-generated-id' from '192.168.111.11'
Turribeach wrote:PS: A bit of FUD on the logging message when using local secrets...
- Code: Select all
jay (support) wrote:That's not FUD. We believe (based on prior feedback among other things) that users should be very aware of any incoming API connections. This message is shown for all API messages (not just for those using local secrets). You can turn off these warnings in the new Advanced Web Server Config dialog.
