Announcing GivEnergy Cloud Controller
Sun Nov 13, 2022 3:40 pm
neilk online
The GivEnergy cloud controller plugin is a minimally viable plugin to interface with the GivEnergy hybrid battery and solar inverter.
Working with forum user @mwoodgate to build this as I do not as yet have one this is still very much a prototype, but basic functionality and device stats have been proven
https://github.com/neilkplugins/GivEnergy-indigo-plugin/releases/tag/2022.0.2Alpha
This latest version has a prototype energy flow device, but I will need some test data from Martin to complete it.
The plugin does not have any configuration options other than polling frequency (how often to update from the API) and the timeout value.
Currently it supports 2 devices.
Inverter device - this is the main data for the inverter and is configured with your API key and the inverter serial number.
Energy Flow - is a slave to the inverter (so you do not need to repeat your API Key and Serial number details) which will when completed will report the energy flows grouped as below and this is a device configuration option.
Grouping ID Name Description
0 Half Hourly Groups the data into 30-minute intervals
1 Daily Groups the data into 24-hour intervals
2 Monthly Groups the data into monthly intervals
3 Yearly Groups the data into yearly intervals
The following is not yet supported
4 Total Groups the data into a single interval, spanning from the start time to the end time (this may be added later with the start time being the "commission date")
The flow device will then report the following flows (when completed)
Type ID Name Description
0 PV to Home The amount of energy generated by the solar panels to be used immediately for local consumption
1 PV to Battery The amount of energy generated by the solar panels that has been used to charge the battery
2 PV to Grid The amount of energy generated by the solar panels that has been exported to the grid
3 Grid to Home The amount of energy imported from the grid that has been used immediately for local consumption
4 Grid to Battery The amount of energy imported from the grid that has been used to charge the battery
5 Battery to Home The amount of energy discharged by the battery that has been used for local consumption
6 Battery to Grid The amount of energy discharged by the battery that has been exported to the grid
Not sure if Martin is the only GivEnergy user, but others welcome and I may well purchase one myself.
Neil
Mon Nov 14, 2022 4:20 am
mwoodage offline
Re: Announcing GivEnergy Cloud Controller
Hi Neil,
Great work on the plugin so far :) - i've added the 4No. flow devices (1/2 hourly, daily, monthly, yearly) and shown the de-bug results below.
I've taken away parts of the API key and the inverter number - xxxxxxxxxx is where the inverter number would have been.
Hope thats all ok, thanks again
Martin
2022-11-14 09:40:30.412   GivEnergy Debug   {'Authorization': 'Bearer.eyJhdWQiOiI5NTc3MDIxOS1jYWE2LTRmOTctOTE3Ni0zNDBlZGMzZDQxNTgiLCJqdGkiOiIzMTI5YjAyM2I2ODlhNTY1OTIyYmRhMzdmZjJkOTdiZjI4NzViZThkYzA3OGM5MmJmYmNlOTFjYTg4MjJhMmI1YTE0MjZlYTkwY2VhNmUwOSIsImlhdCI6MTY2Njk4MjkyNi4yNTkwNzcsIm5iZiI6MTY2Njk4MjkyNi4yNTkwODEsImV4cCI6MTY5ODUxODkyNi4yNTIzNzQsInN1YiI6IjE5MjE5Iiwic2NvcGVzIjpbImFwaSJdfQ -yZvgflfCGGKaKRsqOT_k6EwCKSF-ePu5LQI8wJ8v9tNkBzNeG4yc5jB88QQRPWLdHwcQ', 'Content-Type': 'application/json', 'Accept': 'application/json'}
2022-11-14 09:40:30.836   GivEnergy Error   HTTP error getting Energy Flow Yearly xxxxxxxxxx data: 422 Client Error: Unprocessable Content for url: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
2022-11-14 09:40:45.008   Schedule   Inverter Data - Battery Percentage
2022-11-14 09:40:45.904   GivEnergy Debug   Updating Flow device: Energy Flow 1/2 hour with aggregation 0
2022-11-14 09:40:45.904   GivEnergy Debug   Which is linked to Inverter  7470xxxxx
2022-11-14 09:40:45.905   GivEnergy Debug   xxxxxxxxxx
2022-11-14 09:40:45.905   GivEnergy Debug   Half Hourly Reporting
2022-11-14 09:40:45.906   GivEnergy Debug   Start Time is 2022-11-14 09:30:00
2022-11-14 09:40:45.906   GivEnergy Debug   End Time is 2022-11-14 10:00:00
2022-11-14 09:40:45.906   GivEnergy Debug   URL is: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
2022-11-14 09:40:45.906   GivEnergy Debug   Payload is:
2022-11-14 09:40:45.907   GivEnergy Debug   {'start_time': '2022-11-14 09:30:00', 'end_time': '2022-11-14 10:00:00', 'grouping': '0'}
2022-11-14 09:40:45.907   GivEnergy Debug   Headers are:
2022-11-14 09:40:45.907   GivEnergy Debug   {'Authorization': 'Bearer.eyJhdWQiOiI5NTc3MDIxOS1jYWE2LTRmOTctOTE3Ni0zNDBlZGMzZDQxNTgiLCJqdGkiOiIzMTI5YjAyM2I2ODlhNTY1OTIyYmRhMzdmZjJkOTdiZjI4NzViZThkYzA3OGM5MmJmYmNlOTFjYTg4MjJhMmI1YTE0MjZlYTkwY2VhNmUwOSIsImlhdCI6MTY2Njk4MjkyNi4yNTkwNzcsIm5iZiI6MTY2Njk4MjkyNi4yNTkwODEsImV4cCI6MTY5ODUxODkyNi4yNTIzNzQsInN1YiI6IjE5MjE5Iiwic2NvcGVzIjpbImFwaSJdfQ, 'Content-Type': 'application/json', 'Accept': 'application/json'}
2022-11-14 09:40:46.280   GivEnergy Error   HTTP error getting Energy Flow 1/2 hour xxxxxxxxxx data: 422 Client Error: Unprocessable Content for url: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
2022-11-14 09:40:46.285   GivEnergy Debug   Updating Flow device: Energy Flow Daily with aggregation 1
2022-11-14 09:40:46.286   GivEnergy Debug   Which is linked to Inverter  7470xxxxx
2022-11-14 09:40:46.287   GivEnergy Debug   xxxxxxxxxx
2022-11-14 09:40:46.287   GivEnergy Debug   Daily Reporting
2022-11-14 09:40:46.287   GivEnergy Debug   Start Time is 2022-11-14
2022-11-14 09:40:46.287   GivEnergy Debug   End Time is 2022-11-14 10:00:00
2022-11-14 09:40:46.288   GivEnergy Debug   URL is: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
2022-11-14 09:40:46.288   GivEnergy Debug   Payload is:
2022-11-14 09:40:46.288   GivEnergy Debug   {'start_time': '2022-11-14', 'end_time': '2022-11-14 10:00:00', 'grouping': '1'}
2022-11-14 09:40:46.289   GivEnergy Debug   Headers are:
2022-11-14 09:40:46.289   GivEnergy Debug   {'Authorization': 'Bearer.eyJhdWQiOiI5NTc3MDIxOS1jYWE2LTRmOTctOTE3Ni0zNDBlZGMzZDQxNTgiLCJqdGkiOiIzMTI5YjAyM2I2ODlhNTY1OTIyYmRhMzdmZjJkOTdiZjI4NzViZThkYzA3OGM5MmJmYmNlOTFjYTg4MjJhMmI1YTE0MjZlYTkwY2VhNmUwOSIsImlhdCI6MTY2Njk4MjkyNi4yNTkwNzcsIm5iZiI6MTY2Njk4MjkyNi4yNTkwODEsImV4cCI6MTY5ODUxODkyNi4yNTIzNzQsInN1YiI6IjE5MjE5Iiwic2NvcGVzIjpbImFwaSJdfQ.x_gjzmZbfdLyBsFyM-yZvgflfCGGKaKRsqOT_k6EwCKSF-ePu5', 'Content-Type': 'application/json', 'Accept': 'application/json'}
2022-11-14 09:40:46.657   GivEnergy Error   HTTP error getting Energy Flow Daily xxxxxxxxxx data: 422 Client Error: Unprocessable Content for url: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
2022-11-14 09:40:46.658   GivEnergy Debug   Updating Flow device: Energy Flow Monthly with aggregation 2
2022-11-14 09:40:46.658   GivEnergy Debug   Which is linked to Inverter  7470xxxxx
2022-11-14 09:40:46.659   GivEnergy Debug   xxxxxxxxxx
2022-11-14 09:40:46.659   GivEnergy Debug   Monthly Reporting
2022-11-14 09:40:46.659   GivEnergy Debug   Start Time is 2022-11-01
2022-11-14 09:40:46.660   GivEnergy Debug   End Time is 2022-11-14 10:00:00
2022-11-14 09:40:46.660   GivEnergy Debug   URL is: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
2022-11-14 09:40:46.660   GivEnergy Debug   Payload is:
2022-11-14 09:40:46.660   GivEnergy Debug   {'start_time': '2022-11-01', 'end_time': '2022-11-14 10:00:00', 'grouping': '2'}
2022-11-14 09:40:46.661   GivEnergy Debug   Headers are:
2022-11-14 09:40:46.661   GivEnergy Debug   {'Authorization': 'Bearer.eyJhdWQiOiI5NTc3MDIxOS1jYWE2LTRmOTctOTE3Ni0zNDBlZGMzZDQxNTgiLCJqdGkiOiIzMTI5YjAyM2I2ODlhNTY1OTIyYmRhMzdmZjJkOTdiZjI4NzViZThkYzA3OGM5MmJmYmNlOTFjYTg4MjJhMmI1YTE0MjZlYTkwY2VhNmUwOSIsImlhdCI6MTY2Njk4MjkyNi4yNTkwNzcsIm5iZiI6MTY2Njk4MjkyNi4yNTkwODEsImV4cCI6MTY5ODUxODkyNi4yNTIzNzQsInN1YiI6IjE5MjE5Iiwic2NvcGVzIjpbImFwaSJdfQ., 'Content-Type': 'application/json', 'Accept': 'application/json'}
2022-11-14 09:40:47.146   GivEnergy Error   HTTP error getting Energy Flow Monthly xxxxxxxxxx data: 422 Client Error: Unprocessable Content for url: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
2022-11-14 09:40:47.147   GivEnergy Debug   Updating Flow device: Energy Flow Yearly with aggregation 3
2022-11-14 09:40:47.147   GivEnergy Debug   Which is linked to Inverter  7470xxxxx
2022-11-14 09:40:47.148   GivEnergy Debug   xxxxxxxxxx
2022-11-14 09:40:47.148   GivEnergy Debug   Yearly Reporting
2022-11-14 09:40:47.148   GivEnergy Debug   Start Time is 2022-01-01
2022-11-14 09:40:47.149   GivEnergy Debug   End Time is 2022-11-14 10:00:00
2022-11-14 09:40:47.149   GivEnergy Debug   URL is: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
2022-11-14 09:40:47.149   GivEnergy Debug   Payload is:
2022-11-14 09:40:47.149   GivEnergy Debug   {'start_time': '2022-01-01', 'end_time': '2022-11-14 10:00:00', 'grouping': '3'}
2022-11-14 09:40:47.149   GivEnergy Debug   Headers are:
2022-11-14 09:40:47.150   GivEnergy Debug   {'Authorization': 'Bearer.eyJhdWQiOiI5NTc3MDIxOS1jYWE2LTRmOTctOTE3Ni0zNDBlZGMzZDQxNTgiLCJqdGkiOiIzMTI5YjAyM2I2ODlhNTY1OTIyYmRhMzdmZjJkOTdiZjI4NzViZThkYzA3OGM5MmJmYmNlOTFjYTg4MjJhMmI1YTE0MjZlYTkwY2VhNmUwOSIsImlhdCI6MTY2Njk4MjkyNi4yNTkwNzcsIm5iZiI6MTY2Njk4MjkyNi4yNTkwODEsImV4cCI6MTY5ODUxODkyNi4yNTIzNzQsInN1YiI6IjE5MjE5Iiwic2NvcGVzIjpbImFwaSJdfQ, 'Content-Type': 'application/json', 'Accept': 'application/json'}
2022-11-14 09:40:48.018   GivEnergy Error   HTTP error getting Energy Flow Yearly xxxxxxxxxx data: 422 Client Error: Unprocessable Content for url: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
Mon Nov 14, 2022 4:41 am
neilk online
Martin,
Thanks for that, I think I spotted the issue and should be fixed in https://github.com/neilkplugins/GivEnergy-indigo-plugin/releases/tag/2022.0.3Alpha
Hopefully this will return the data in the different forms, so I can then write the state update sections.
Neil
Mon Nov 14, 2022 7:36 am
mwoodage offline
Hi Neil,
Thanks for the updated plugin - however i'm stilll getting an error?
2022-11-14 13:31:00.026   Schedule   Inverter Data - Battery Percentage
2022-11-14 13:31:00.951   GivEnergy Debug   Updating Flow device: Energy Flow 1/2 hour with aggregation 0
2022-11-14 13:31:00.951   GivEnergy Debug   Which is linked to Inverter  7470xxxxx
2022-11-14 13:31:00.952   GivEnergy Debug   xxxxxxxxxx
2022-11-14 13:31:00.952   GivEnergy Debug   Half Hourly Reporting
2022-11-14 13:31:00.952   GivEnergy Debug   Start Time is 2022-11-14 13:30:00
2022-11-14 13:31:00.952   GivEnergy Debug   End Time is 2022-11-14 14:00:00
2022-11-14 13:31:00.953   GivEnergy Debug   URL is: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
2022-11-14 13:31:00.953   GivEnergy Debug   Payload is:
2022-11-14 13:31:00.953   GivEnergy Debug   {'start_time': '2022-11-14 13:30:00', 'end_time': '2022-11-14 14:00:00', 'grouping': 0}
2022-11-14 13:31:00.954   GivEnergy Debug   Headers are:
2022-11-14 13:31:00.954   GivEnergy Debug   {'Authorization': 'Bearer.eyJhdWQiOiI5NTc3MDIxOS1jYWE2LTRmOTctOTE3Ni0zNDBlZGMzZDQxNTgiLCJqdGkiOiIzMTI5YjAyM2I2ODlhNTY1OTIyYmRhMzdmZjJkOTdiZjI4NzViZThkYzA3OGM5MmJmYmNlOTFjYTg4MjJhMmI1YTE0MjZlYTkwY2VhNmUwOSIsImlhdCI6MTY2Njk4MjkyNi4yNTkwNzcsIm5iZiI6MTY2Njk4MjkyNi4yNTkwODEsImV4cCI6MTY5ODUxODkyNi4yNTIzNzQsInN1YiI6IjE5MjE5Iiwic2NvcGVzIjpbImFwaSJdfQ.x_gjzmZbfdLyBsFyM-yZvgflfCGGKaKRsqOT, 'Content-Type': 'application/json', 'Accept': 'application/json'}
2022-11-14 13:31:01.333   GivEnergy Error   HTTP error getting Energy Flow 1/2 hour xxxxxxxxxx data: 422 Client Error: Unprocessable Content for url: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
2022-11-14 13:31:01.334   GivEnergy Debug   Updating Flow device: Energy Flow Daily with aggregation 1
2022-11-14 13:31:01.334   GivEnergy Debug   Which is linked to Inverter  7470xxxxx
2022-11-14 13:31:01.335   GivEnergy Debug   xxxxxxxxxx
2022-11-14 13:31:01.335   GivEnergy Debug   Daily Reporting
2022-11-14 13:31:01.335   GivEnergy Debug   Start Time is 2022-11-14
2022-11-14 13:31:01.336   GivEnergy Debug   End Time is 2022-11-14 14:00:00
2022-11-14 13:31:01.336   GivEnergy Debug   URL is: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
2022-11-14 13:31:01.336   GivEnergy Debug   Payload is:
2022-11-14 13:31:01.337   GivEnergy Debug   {'start_time': '2022-11-14', 'end_time': '2022-11-14 14:00:00', 'grouping': 1}
2022-11-14 13:31:01.337   GivEnergy Debug   Headers are:
2022-11-14 13:31:01.337   GivEnergy Debug   {'Authorization': 'Bearer.eyJhdWQiOiI5NTc3MDIxOS1jYWE2LTRmOTctOTE3Ni0zNDBlZGMzZDQxNTgiLCJqdGkiOiIzMTI5YjAyM2I2ODlhNTY1OTIyYmRhMzdmZjJkOTdiZjI4NzViZThkYzA3OGM5MmJmYmNlOTFjYTg4MjJhMmI1YTE0MjZlYTkwY2VhNmUwOSIsImlhdCI6MTY2Njk4MjkyNi4yNTkwNzcsIm5iZiI6MTY2Njk4MjkyNi4yNTkwODEsImV4cCI6MTY5ODUxODkyNi4yNTIzNzQsInN1YiI6IjE5MjE5Iiwic2NvcGVzIjpbImFwaSJdfQ, 'Content-Type': 'application/json', 'Accept': 'application/json'}
2022-11-14 13:31:01.726   GivEnergy Error   HTTP error getting Energy Flow Daily xxxxxxxxxx data: 422 Client Error: Unprocessable Content for url: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
2022-11-14 13:31:01.727   GivEnergy Debug   Updating Flow device: Energy Flow Monthly with aggregation 2
2022-11-14 13:31:01.727   GivEnergy Debug   Which is linked to Inverter  747025714
2022-11-14 13:31:01.728   GivEnergy Debug   xxxxxxxxxx
2022-11-14 13:31:01.728   GivEnergy Debug   Monthly Reporting
2022-11-14 13:31:01.729   GivEnergy Debug   Start Time is 2022-11-01
2022-11-14 13:31:01.729   GivEnergy Debug   End Time is 2022-11-14 14:00:00
2022-11-14 13:31:01.729   GivEnergy Debug   URL is: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
2022-11-14 13:31:01.729   GivEnergy Debug   Payload is:
2022-11-14 13:31:01.730   GivEnergy Debug   {'start_time': '2022-11-01', 'end_time': '2022-11-14 14:00:00', 'grouping': 2}
2022-11-14 13:31:01.730   GivEnergy Debug   Headers are:
2022-11-14 13:31:01.730   GivEnergy Debug   {'Authorization': 'Bearer.eyJhdWQiOiI5NTc3MDIxOS1jYWE2LTRmOTctOTE3Ni0zNDBlZGMzZDQxNTgiLCJqdGkiOiIzMTI5YjAyM2I2ODlhNTY1OTIyYmRhMzdmZjJkOTdiZjI4NzViZThkYzA3OGM5MmJmYmNlOTFjYTg4MjJhMmI1YTE0MjZlYTkwY2VhNmUwOSIsImlhdCI6MTY2Njk4MjkyNi4yNTkwNzcsIm5iZiI6MTY2Njk4MjkyNi4yNTkwODEsImV4cCI6MTY5ODUxODkyNi4yNTIzNzQsInN1YiI6IjE5MjE5Iiwic2NvcGVzIjpbImFwaSJdfQ, 'Content-Type': 'application/json', 'Accept': 'application/json'}
2022-11-14 13:31:02.099   GivEnergy Error   HTTP error getting Energy Flow Monthly xxxxxxxxxx data: 422 Client Error: Unprocessable Content for url: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
2022-11-14 13:31:02.101   GivEnergy Debug   Updating Flow device: Energy Flow Yearly with aggregation 3
2022-11-14 13:31:02.101   GivEnergy Debug   Which is linked to Inverter  7470xxxxx
2022-11-14 13:31:02.102   GivEnergy Debug   xxxxxxxxxx
2022-11-14 13:31:02.102   GivEnergy Debug   Yearly Reporting
2022-11-14 13:31:02.103   GivEnergy Debug   Start Time is 2022-01-01
2022-11-14 13:31:02.103   GivEnergy Debug   End Time is 2022-11-14 14:00:00
2022-11-14 13:31:02.103   GivEnergy Debug   URL is: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
2022-11-14 13:31:02.103   GivEnergy Debug   Payload is:
2022-11-14 13:31:02.104   GivEnergy Debug   {'start_time': '2022-01-01', 'end_time': '2022-11-14 14:00:00', 'grouping': 3}
2022-11-14 13:31:02.104   GivEnergy Debug   Headers are:
2022-11-14 13:31:02.104   GivEnergy Debug   {'Authorization': 'Bearer eyJhdWQiOiI5NTc3MDIxOS1jYWE2LTRmOTctOTE3Ni0zNDBlZGMzZDQxNTgiLCJqdGkiOiIzMTI5YjAyM2I2ODlhNTY1OTIyYmRhMzdmZjJkOTdiZjI4NzViZThkYzA3OGM5MmJmYmNlOTFjYTg4MjJhMmI1YTE0MjZlYTkwY2VhNmUwOSIsImlhdCI6MTY2Njk4MjkyNi4yNTkwNzcsIm5iZiI6MTY2Njk4MjkyNi4yNTkwODEsImV4cCI6MTY5ODUxODkyNi4yNTIzNzQsInN1YiI6IjE5MjE5Iiwic2NvcGVzIjpbImFwaSJdfQ', 'Content-Type': 'application/json', 'Accept': 'application/json'}
2022-11-14 13:31:02.532   GivEnergy Error   HTTP error getting Energy Flow Yearly xxxxxxxxxx data: 422 Client Error: Unprocessable Content for url: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
Mon Nov 14, 2022 8:05 am
neilk online
OK - Apologies for that, back to the drawing board. Could you try running this example directly in a terminal window after adding your api key and serial number. I think it may be to do with the date coding, and you may try changing the start and end time date until after your install if it was not done on the 1st of Jan 2022.
curl --request POST \
    "https://api.givenergy.cloud/v1/inverter/{YOUR_SERIAL_NUMBER}/energy-flows" \
    --header "Authorization: Bearer {YOUR_API_KEY}" \
    --header "Content-Type: application/json" \
    --header "Accept: application/json" \
    --data "{
    \"start_time\": \"2022-01-01\",
    \"end_time\": \"2022-01-01\",
    \"grouping\": 0,
    \"types\": [
        0,
        1,
        2,
        5
Mon Nov 14, 2022 8:50 am
mwoodage offline
Hello,
I've tried the request below and i get the following response,
curl: (6) Could not resolve host:
{"message":"The given data was invalid.","errors":{"start_time":["The start time field is required."],"end_time":["The end time field is required."],"grouping":["The grouping field is required."]}}curl: (6) Could not resolve host:
If i change the start time dates to 2022-10-25 and the end dates to 2022-11-13 I get the same message. I've tried other dates as well but still getting the same message
My system was commissioned on the 2022-10-24
This is what i'm posting
    "https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows" \
    --header "Authorization: Bearer eyJhdWQiOiI5NTc3MDIxOS1jYWE2LTRmOTctOTE3Ni0zNDBlZGMzZDQxNTgiLCJqdGkiOiIzMTI5YjAyM2I2ODlhNTY1OTIyYmRhMzdmZjJkOTdiZjI4NzViZThkYzA3OGM5MmJmYmNlOTFjYTg4MjJhMmI1YTE0MjZlYTkwY2VhNmUwOSIsImlhdCI6MTY2Njk4MjkyNi4yNTkwNzcsIm5iZiI6MTY2Njk4MjkyNi4yNTkwODEsImV4cCI6MTY5ODUxODkyNi4yNTIzNzQsInN1YiI6IjE5MjE5Iiwic2NvcGVzIjpbImFwaSJdfQ.x_gjzmZbfdLyBsFyM-yZvgflfCGGKaKRsqOT" \
    --data "{
    \"start_time\": \"2022-10-25\”,
    \"end_time\": \"2022-11-13\”,
    \"grouping\": 0,
    \"types\": [
        0,
        1,
        2,
        5
Mon Nov 14, 2022 9:52 am
mwoodage offline
Also, just noticed that the plug-in is not working since the update, I restarted it and am seeing this error,
Sorry!
Reloading plugin "GivEnergy 2022.0.3" using API v3.0
   Stopping plugin "GivEnergy 2022.0.3" (pid 58917)
   Stopped plugin "GivEnergy 2022.0.3"
   Starting plugin "GivEnergy 2022.0.3" (pid 66081)
   Started plugin "GivEnergy 2022.0.3"
   GivEnergy Error                 exception in device_start_comm(Inverter): name 'json' is not defined
   Z-Wave                          received "Lounge Sensor" status update is off
   Disabling plugin "GivEnergy 2022.0.3"
   Stopping plugin "GivEnergy 2022.0.3" (pid 66081)
   Enabling plugin "GivEnergy 2022.0.3" using API v3.0
   Starting plugin "GivEnergy 2022.0.3" (pid 66113)
Mon Nov 14, 2022 10:29 am
neilk online
Martin - no need to apologise, you can revert to https://github.com/neilkplugins/GivEnergy-indigo-plugin/releases/tag/2022.0.1-Alpha while I figure out what is going on.
We will sort it out, I will give you some standalone python scripts to try so that we don't break the plugin, as of course I cannot test it 100% in between.
More later.
Neil
Mon Nov 14, 2022 1:35 pm
neilk online
I have sorted the JSON issue, I accidentally deleted a line of code by accident, and as I don't get results it doesn't fail when I test. It will be corrected in the next release which should also add the full flow functionality.
I am digging through the givenergy forums, as it looks like I may not be alone in struggling to make this work !
Neil
Mon Nov 14, 2022 2:16 pm
mwoodage offline
Thanks Neil, much appreciated. I've rolled back to version 1 so all working here at the moment :)
Cheers
Martin
Mon Nov 14, 2022 3:36 pm
neilk online
Martin,
I have done some digging on the use of the API, and I think I may be being too clever adding in the time so have removed it. It appears the request is being understood but found not to be processable. You can try this version which should also fix the issue with the breaking error I introduced (and one other minor change)
Fingers crossed, this one will move it forward, and if it works I will need the data returned for each device type.
Neil
https://github.com/neilkplugins/GivEnergy-indigo-plugin/releases/tag/2022.0.4-Alpha
Tue Nov 15, 2022 6:17 am
mwoodage offline
Hi Nick,
Thanks for the update, having a busy day at work today so not been able to test until now.
I've given it a try this morning and getting the following results:-
   GivEnergy Debug                 {'Authorization': 'Bearer eyJhdWQiOiI5NTc3MDIxOS1jYWE2LTRmOTctOTE3Ni0zNDBlZGMzZDQxNTgiLCJqdGkiOiIzMTI5YjAyM2I2ODlhNTY1OTIyYmRhMzdmZjJkOTdiZjI4NzViZThkYzA3OGM5MmJmYmNlOTFjYTg4MjJhMmI1YTE0MjZlYTkwY2VhNmUwOSIsImlhdCI6MTY2Njk4MjkyNi4yNTkwNzcsIm5iZiI6MTY2Njk4MjkyNi4yNTkwODEsImV4cCI6MTY5ODUxODkyNi4yNTIzNzQsInN1YiI6IjE5MjE5Iiwic2NvcGVzIjpbImFwaSJdfQ.x_gjzmZbfdLyBsFyM-', 'Content-Type': 'application/json', 'Accept': 'application/json'}
   GivEnergy Debug                 API Response was:
   GivEnergy Debug                 {'data': {'time': '2022-11-15T11:16:14Z', 'solar': {'power': 2235, 'arrays': [{'array': 1, 'voltage': 227.4, 'current': 5, 'power': 1137}, {'array': 2, 'voltage': 215.7, 'current': 5.1, 'power': 1098}]}, 'grid': {'voltage': 245.8, 'current': 2.4, 'power': 11, 'frequency': 49.93}, 'battery': {'percent': 8, 'power': -1614, 'temperature': 15}, 'inverter': {'temperature': 35.5, 'power': 483, 'output_voltage': 245.7, 'output_frequency': 49.93, 'eps_power': 0}, 'consumption': 491}}
   GivEnergy Debug                 Which is linked to Inverter  7470xxxxxxxxx
   GivEnergy Debug                 Start Time is 2022-11-15
   GivEnergy Debug                 End Time is 2022-11-15
   GivEnergy Debug                 URL is: https://api.givenergy.cloud/v1/inverter/xxxxxxxx/energy-flows
   GivEnergy Debug                 {"start_time": "2022-11-15", "end_time": "2022-11-15", "grouping": 0}
   GivEnergy Debug                 {'Authorization': 'Bearer eyJhdWQiOiI5NTc3MDIxOS1jYWE2LTRmOTctOTE3Ni0zNDBlZGMzZDQxNTgiLCJqdGkiOiIzMTI5YjAyM2I2ODlhNTY1OTIyYmRhMzdmZjJkOTdiZjI4NzViZThkYzA3OGM5MmJmYmNlOTFjYTg4MjJhMmI1YTE0MjZlYTkwY2VhNmUwOSIsImlhdCI6MTY2Njk4MjkyNi4yNTkwNzcsIm5iZiI6MTY2Njk4MjkyNi4yNTkwODEsImV4cCI6MTY5ODUxODkyNi4yNTIzNzQsInN1YiI6IjE5MjE5Iiwic2NvcGVzIjpbImFwaSJdfQ.x_gjzmZbfdLyBsFyM-yZvgflfCGGKaKRsqOT', 'Content-Type': 'application/json', 'Accept': 'application/json'}
   GivEnergy Error                 HTTP error getting Energy Flow 1/2 hour xxxxxxxxx data: 422 Client Error: Unprocessable Content for url: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
   GivEnergy Debug                 {"start_time": "2022-11-15", "end_time": "2022-11-15", "grouping": 1}
   GivEnergy Debug                 {'Authorization': 'Bearer eyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiJ9.eyJhdWQiOiI5NTc3MDIxOS1jYWE2LTRmOTctOTE3Ni0zNDBlZGMzZDQxNTgiLCJqdGkiOiIzMTI5YjAyM2I2ODlhNTY1OTIyYmRhMzdmZjJkOTdiZjI4NzViZThkYzA3OGM5MmJmYmNlOTFjYTg4MjJhMmI1YTE0MjZlYTkwY2VhNmUwOSIsImlhdCI6MTY2Njk4MjkyNi4yNTkwNzcsIm5iZiI6MTY2Njk4MjkyNi4yNTkwODEsImV4cCI6MTY5ODUxODkyNi4yNTIzNzQsInN1YiI6IjE5MjE5Iiwic2NvcGVzIjpbImFwaSJdfQ.x_gjzmZbfdLyBsFyM', 'Content-Type': 'application/json', 'Accept': 'application/json'}
   GivEnergy Error                 HTTP error getting Energy Flow Daily xxxxxxxx data: 422 Client Error: Unprocessable Content for url: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
   GivEnergy Debug                 {"start_time": "2022-11-01", "end_time": "2022-11-15", "grouping": 2}
   GivEnergy Debug                 {'Authorization': 'Bearer eyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiJ9.eyJhdWQiOiI5NTc3MDIxOS1jYWE2LTRmOTctOTE3Ni0zNDBlZGMzZDQxNTgiLCJqdGkiOiIzMTI5YjAyM2I2ODlhNTY1OTIyYmRhMzdmZjJkOTdiZjI4NzViZThkYzA3OGM5MmJmYmNlOTFjYTg4MjJhMmI1YTE0MjZlYTkwY2VhNmUwOSIsImlhdCI6MTY2Njk4MjkyNi4yNTkwNzcsIm5iZiI6MTY2Njk4MjkyNi4yNTkwODEsImV4cCI6MTY5ODUxODkyNi4yNTIzNzQsInN1YiI6IjE5MjE5Iiwic2NvcGVzIjpbImFwaSJdfQ.x_gjzmZbfdLyBsFyM   GivEnergy Error                 HTTP error getting Energy Flow Monthly xxxxxxxx data: 422 Client Error: Unprocessable Content for url: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
   GivEnergy Debug                 {"start_time": "2022-01-01", "end_time": "2022-11-15", "grouping": 3}
   GivEnergy Error                 HTTP error getting Energy Flow Yearly xxxxxxxx data: 422 Client Error: Unprocessable Content for url: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
The plugin is working again, but we're still not getting the energy-flows.
Martin
Tue Nov 15, 2022 4:33 pm
neilk online
Martin,
This version still won't populate but hopefully will get the data and write it to the event log. If this doesn't work I have a plan that would involve you downloading a tool called postman, as Givenergy have a collection setup for their API that will allow you to try some calls. May not be necessary as fingers crossed this could give us the data, and once I see an example I can code the updates.
Sorry this is a little protracted !
Neil
https://github.com/neilkplugins/GivEnergy-indigo-plugin/releases/tag/2022.0.5-Alpha
Wed Nov 16, 2022 4:36 am
mwoodage offline
Hi Neil,
Data attached using the new version,
2022-11-16 10:27:56.784   GivEnergy Debug   {'Authorization': 'Bearer eyJhdWQiOiI5NTc3MDIxOS1jYWE2LTRmOTctOTE3Ni0zNDBlZGMzZDQxNTgiLCJqdGkiOiIzMTI5YjAyM2I2ODlhNTY1OTIyYmRhMzdmZjJkOTdiZjI4NzViZThkYzA3OGM5MmJmYmNlOTFjYTg4MjJhMmI1YTE0MjZlYTkwY2VhNmUwOSIsImlhdCI6MTY2Njk4MjkyNi4yNTkwNzcsIm5iZiI6MTY2Njk4MjkyNi4yNTkwODEsImV4cCI6MTY5ODUxODkyNi4yNTIzNzQsInN1YiI6IjE5MjE5Iiwic2NvcGVzIjpbImFwaSJdfQ.x_gjzmZbfdLyBsFyM-yZvgflfCGGKaKRsqOT_k6EwCKSF', 'Content-Type': 'application/json', 'Accept': 'application/json'}
2022-11-16 10:27:57.681   Z-Wave   received "Bathroom Sensor" status update is on
2022-11-16 10:27:57.765   GivEnergy Debug   API Response was:
2022-11-16 10:27:57.766   GivEnergy Debug   {'data': {'time': '2022-11-16T10:26:03Z', 'solar': {'power': 630, 'arrays': [{'array': 1, 'voltage': 232.6, 'current': 1.3, 'power': 318}, {'array': 2, 'voltage': 216.2, 'current': 1.4, 'power': 312}]}, 'grid': {'voltage': 241.4, 'current': 2.9, 'power': 263, 'frequency': 50.11}, 'battery': {'percent': 100, 'power': 0, 'temperature': 15}, 'inverter': {'temperature': 31.8, 'power': 598, 'output_voltage': 241.5, 'output_frequency': 50.11, 'eps_power': 0}, 'consumption': 327}}
2022-11-16 10:27:57.768   GivEnergy Debug   Updating Flow device: Energy Flow 1/2 hour with aggregation 0
2022-11-16 10:27:57.768   GivEnergy Debug   Which is linked to Inverter  xxxxxxxxxx
2022-11-16 10:27:57.769   GivEnergy Debug   xxxxxxxxxx
2022-11-16 10:27:57.769   GivEnergy Debug   Half Hourly Reporting
2022-11-16 10:27:57.770   GivEnergy Debug   Start Time is 2022-11-16
2022-11-16 10:27:57.770   GivEnergy Debug   End Time is 2022-11-16
2022-11-16 10:27:57.771   GivEnergy Debug   URL is: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
2022-11-16 10:27:57.771   GivEnergy Debug   Payload is:
2022-11-16 10:27:57.771   GivEnergy Debug   {"start_time": "2022-11-16", "end_time": "2022-11-16", "grouping": 0, "types": [0, 1, 2, 3, 4, 5]}
2022-11-16 10:27:57.772   GivEnergy Debug   Headers are:
2022-11-16 10:27:57.772   GivEnergy Debug   {'Authorization': 'Bearer eyJhdWQiOiI5NTc3MDIxOS1jYWE2LTRmOTctOTE3Ni0zNDBlZGMzZDQxNTgiLCJqdGkiOiIzMTI5YjAyM2I2ODlhNTY1OTIyYmRhMzdmZjJkOTdiZjI4NzViZThkYzA3OGM5MmJmYmNlOTFjYTg4MjJhMmI1YTE0MjZlYTkwY2VhNmUwOSIsImlhdCI6MTY2Njk4MjkyNi4yNTkwNzcsIm5iZiI6MTY2Njk4MjkyNi4yNTkwODEsImV4cCI6MTY5ODUxODkyNi4yNTIzNzQsInN1YiI6IjE5MjE5Iiwic2NvcGVzIjpbImFwaSJdfQ.x_gjzmZbfdLyBsFyM-yZvgflfCGGKaKRsqOT_k6EwCKSF', 'Content-Type': 'application/json', 'Accept': 'application/json'}
2022-11-16 10:27:58.143   GivEnergy Error   HTTP error getting Energy Flow 1/2 hour xxxxxxxxxx data: 422 Client Error: Unprocessable Content for url: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
2022-11-16 10:27:58.144   GivEnergy Debug   Updating Flow device: Energy Flow Daily with aggregation 1
2022-11-16 10:27:58.145   GivEnergy Debug   Which is linked to Inverter  xxxxxxxxxx
2022-11-16 10:27:58.146   GivEnergy Debug   xxxxxxxxxx
2022-11-16 10:27:58.146   GivEnergy Debug   Daily Reporting
2022-11-16 10:27:58.146   GivEnergy Debug   Start Time is 2022-11-16
2022-11-16 10:27:58.147   GivEnergy Debug   End Time is 2022-11-16
2022-11-16 10:27:58.147   GivEnergy Debug   URL is: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
2022-11-16 10:27:58.147   GivEnergy Debug   Payload is:
2022-11-16 10:27:58.148   GivEnergy Debug   {"start_time": "2022-11-16", "end_time": "2022-11-16", "grouping": 1, "types": [0, 1, 2, 3, 4, 5]}
2022-11-16 10:27:58.148   GivEnergy Debug   Headers are:
2022-11-16 10:27:58.148   GivEnergy Debug   {'Authorization': 'Bearer eyJhdWQiOiI5NTc3MDIxOS1jYWE2LTRmOTctOTE3Ni0zNDBlZGMzZDQxNTgiLCJqdGkiOiIzMTI5YjAyM2I2ODlhNTY1OTIyYmRhMzdmZjJkOTdiZjI4NzViZThkYzA3OGM5MmJmYmNlOTFjYTg4MjJhMmI1YTE0MjZlYTkwY2VhNmUwOSIsImlhdCI6MTY2Njk4MjkyNi4yNTkwNzcsIm5iZiI6MTY2Njk4MjkyNi4yNTkwODEsImV4cCI6MTY5ODUxODkyNi4yNTIzNzQsInN1YiI6IjE5MjE5Iiwic2NvcGVzIjpbImFwaSJdfQ.x_gjzmZbfdLyBsFyM-yZvgflfCGGKaKRsqOT_', 'Content-Type': 'application/json', 'Accept': 'application/json'}
2022-11-16 10:27:58.566   GivEnergy Error   HTTP error getting Energy Flow Daily xxxxxxxxxx data: 422 Client Error: Unprocessable Content for url: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
2022-11-16 10:27:58.567   GivEnergy Debug   Updating Flow device: Energy Flow Monthly with aggregation 2
2022-11-16 10:27:58.568   GivEnergy Debug   Which is linked to Inverter  xxxxxxxxxx
2022-11-16 10:27:58.568   GivEnergy Debug   xxxxxxxxxx
2022-11-16 10:27:58.569   GivEnergy Debug   Monthly Reporting
2022-11-16 10:27:58.569   GivEnergy Debug   Start Time is 2022-11-01
2022-11-16 10:27:58.570   GivEnergy Debug   End Time is 2022-11-16
2022-11-16 10:27:58.571   GivEnergy Debug   URL is: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
2022-11-16 10:27:58.571   GivEnergy Debug   Payload is:
2022-11-16 10:27:58.572   GivEnergy Debug   {"start_time": "2022-11-01", "end_time": "2022-11-16", "grouping": 2, "types": [0, 1, 2, 3, 4, 5]}
2022-11-16 10:27:58.572   GivEnergy Debug   Headers are:
2022-11-16 10:27:58.572   GivEnergy Debug   {'Authorization': 'Bearer eyJhdWQiOiI5NTc3MDIxOS1jYWE2LTRmOTctOTE3Ni0zNDBlZGMzZDQxNTgiLCJqdGkiOiIzMTI5YjAyM2I2ODlhNTY1OTIyYmRhMzdmZjJkOTdiZjI4NzViZThkYzA3OGM5MmJmYmNlOTFjYTg4MjJhMmI1YTE0MjZlYTkwY2VhNmUwOSIsImlhdCI6MTY2Njk4MjkyNi4yNTkwNzcsIm5iZiI6MTY2Njk4MjkyNi4yNTkwODEsImV4cCI6MTY5ODUxODkyNi4yNTIzNzQsInN1YiI6IjE5MjE5Iiwic2NvcGVzIjpbImFwaSJdfQ.', 'Content-Type': 'application/json', 'Accept': 'application/json'}
2022-11-16 10:27:58.929   GivEnergy Error   HTTP error getting Energy Flow Monthly xxxxxxxxxx data: 422 Client Error: Unprocessable Content for url: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
2022-11-16 10:27:58.930   GivEnergy Debug   Updating Flow device: Energy Flow Yearly with aggregation 3
2022-11-16 10:27:58.930   GivEnergy Debug   Which is linked to Inverter  xxxxxxxxxx
2022-11-16 10:27:58.931   GivEnergy Debug   xxxxxxxxxx
2022-11-16 10:27:58.932   GivEnergy Debug   Yearly Reporting
2022-11-16 10:27:58.932   GivEnergy Debug   Start Time is 2022-01-01
2022-11-16 10:27:58.932   GivEnergy Debug   End Time is 2022-11-16
2022-11-16 10:27:58.932   GivEnergy Debug   URL is: https://api.givenergy.cloud/v1/inverter/xxxxxxxxxx/energy-flows
2022-11-16 10:27:58.933   GivEnergy Debug   Payload is:
2022-11-16 10:27:58.933   GivEnergy Debug   {"start_time": "2022-01-01", "end_time": "2022-11-16", "grouping": 3, "types": [0, 1, 2, 3, 4, 5]}
2022-11-16 10:27:58.933   GivEnergy Debug   Headers are:
2022-11-16 10:27:58.934   GivEnergy Debug   {'Authorization': 'Bearer
Wed Nov 16, 2022 6:32 am
neilk online
Martin - apologies still no joy. I will send something about my plan B tonight.
Neil
