Clicking the Controlling Keypad Room drop down within Managed Linked Devices shows the following message:
- Code: Select all
Failed to Get UI List from Plugin:
InvalidParameterError: plugin does not define method roomListGenerator
This is what I'm seeing in the logs:
- Code: Select all
Lutron RRA2/Caséta Debug menuChanged, typeId = manageLinkedDevices, valuesDict = UiValuesDict : (dict)
addLinkedDevice : (string)
buttonDevice : (string)
controlledDevice : (string)
deleteLinkedDevices : (string)
linkName : (string)
linkedDeviceList : (list)
publishedLabel : (string)
room : InvalidParameterError: plugin does not define method roomListGenerator (string)
sep1 : (string)
Lutron RRA2/Caséta Debug controllableDevices, typeId = manageLinkedDevices, targetId = 0, valuesDict = UiValuesDict : (dict)
linkName : (string)
sep1 : (string)
Lutron RRA2/Caséta Debug pickKeypadButton, typeId = manageLinkedDevices, targetId = 0, valuesDict = UiValuesDict : (dict)
linkName : (string)
sep1 : (string)
The plugin seems to be working fine otherwise. I was able to successfully create the Caseta L-BDGPRO2 gateway device and import my Lutron devices (Pico remotes, Plug-In Dimmer) to Indigo using the Create Devices from Caseta Smart Bridge Pro option. Lutron events such as keypad button presses and plug-in dimmer states are registering in Indigo.
Am I missing a step somewhere?
