- Posted on
Thu Feb 01, 2024 5:21 pm
offline
changes in v2022.21.80 @ 2024-02-02
1. change sqlite path to default directory, removed option in config to change it.
it is now always: /Library/Application Support/Perceptive Automation/Indigo 20xx.y/Logs
this removes an issue when indigo changes its directory, i.e. moving from 2023.2 to 2023.3
this path is also used if you use psql, not only for sqlite
