Trouble with Configuration
Wed Apr 06, 2022 11:11 am
pgershon offline
I needed to port my Indigo Server to a new device temporarily, and I am having issues configuring the Sonos plugin with the new server.
I have:
Reference Zone Player : auto
Event Processor: SoCo
Event Listener IP address: 192.168.1.71 (address of my Indigo server)
HTTP Streaming Id: 192.168.1.71
HTTP Streaming Port: 8888
Issue seems to be with the HTTP Streaming. From log
Sonos Using Reference ZonePlayer IP: 192.168.1.194
Sonos Loaded Sonos Favorites... [12]
Sonos Loaded Playlists... [1]
Sonos Loaded RadioTime Favorite Stations... [2]
Sonos: Initialized: SXM_Bolt_On V1.2.A
Sonos Serving HTTP Streamer on 192.168.1.71 [0.0.0.0], port 8888
Sonos_Dev 'NoneType' object has no attribute 'get' <== This was the error that was returned from the init_chan_array / test_the_water / sxm_tester function call
Sonos <== This is the username from the init_chan_array function that was used to login to SiriusXM
Sonos [Wed Apr 6 13:10:37 2022] Processed plugin preferences.
Sonos SoCo Reactor Ignition...
Any thoughts?
Wed Apr 06, 2022 8:04 pm
pgershon offline
Re: Trouble with Configuration
Got an answer - Indigo was looking for a folder that was not present on the new machine:
There is supposed to be a folder "Perceptive Automation\images\Sonos" that was missing. I tried to copy it over from the old server but had to change the permissions of the Perceptive Automation folder to get it in. Once the folder was there, the error messages went away and everything works as it did before,
The folder contains artwork related to the Sonos Player (TV Room_art.jpg). Not sure why its needed or when its used, but without the folder, everything crashes.
