Lock toggle ability removed?
Sun Feb 13, 2022 9:28 am
george99 offline
I just upgraded from 7.4 to 2021.
I just realized that the ability to toggle a lock is no gone. I have to set either lock or unlock.
Is there any way to do this? I am using 2 kwikset z wave locks.
Only way I can think of now is with variables and triggers, etc. Seems like a big pain just for a simple task.
Am I missing something?
Sun Feb 13, 2022 2:24 pm
Re: Lock toggle ability removed?
Is the device visible in the popup if you choose the action Type Device Actions->Light/Appliance Controls->Toggle On/Off ? If it isn't then I can show you how to do the toggle with an embedded action script.
Tue Feb 15, 2022 9:51 pm
george99 offline
Sorry for the delayed reply.
No, the device doesn't even show when I try a toggle for lights.
It used to when I had 7.4. I had control pages set up with this for a few years without issue.
Now the locks are not available for toggle.
As a workaround, I used variables and triggers.
Fri Feb 18, 2022 12:40 pm
Instead of using variable/triggers, select the action Type Server Actions->Script and File Actions->Execute Script and paste in this line to the Embedded Python field:
indigo.device.toggle(DEV_ID_HERE)
Right-click on your lock device in the main window and choose the Copy ID menu, then paste that in to replace DEV_ID_HERE.
Fri Feb 18, 2022 1:50 pm
george99 offline
I’ll give it a shot and report back.
Sun Feb 12, 2023 11:09 am
wackena offline
I have a Kwikset 910 z-wave door lock. Before upgrade to 2022.1, status request and device (loc/unlock) action worked OK. Now, no response to status request or device acton (lock/unlock). It Syncs OK, but does not respond to status request or lock/unlock actions. The manual keypad lock/unlock works OK. I've tried factory reset and re-inclusion with same results. I tried the previous suggestion to see it the device appears in a Trigger -Device Action-light Appliance Controls-toggle(onOff). I also tried Lock(lock controls) and device did not appear int he selection device list. I also bought a Model 450191 z-wave carder the lock and same results. If any suggestions, please reply.
Feb 12, 2023 at 11:40:05 AM
Z-Wave Syncing - started for "113 - Front Door Lock (910)"
Z-Wave Syncing - retrieved module neighbors list: 13, 14, 16, 21, 46, 47, 50, 57, 58, 77
Z-Wave Syncing - assigning return route to "113 - Front Door Lock (910)"
Z-Wave Syncing - retrieved manufacture and model names: Kwikset - 0090, SmartCode Lock (910) - 00010001
Z-Wave Syncing - retrieved protocol version 3.67, app version 3.37
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Entry Control : Keypad Door Lock (04 : 40 : 03, base 62)
Z-Wave Syncing - retrieved command classes: 20v1 62v1 63v1 72v1 86v1 98v1
Z-Wave Syncing - retrieved encrypt commands: - none -
Z-Wave Syncing - retrieved capabilities: routing, beaming, security, frequentWaking
Z-Wave Syncing - complete
Z-Wave sent "113 - Front Door Lock (910)" status request
Sun Feb 12, 2023 11:37 am
That's saying no encrypted commands are supported. Lock/unlock require encryption. Looks like you lost the encryption key in the upgrade. Try excluding the device and then re-including with encryption.
Wed Feb 15, 2023 5:47 am
wackena offline
The previous posted sync report is excluding then including with encryption . I tried several times to include with encryption I have a Z-Stick Gen-5 z-wave controller. What’s the best USB Z-Wave hub/controller?
Wed Feb 15, 2023 6:21 am
wackena offline
I found the problem with Kwikset Lock (910) not working. I had an older node on the controller that would not sync. I tried to sync with it and sync failed. I went to Z-Wave interface and used the "remove failed nodes from controller". That removed the failed node. I did a new excluding then including with encryption and now it's working OK.
