Plugin Compatibility with Battery Watch
Thu Dec 16, 2021 7:41 am
ryanbuckner offline
If we are building a plugin that has a battery state, is there a way to update the device.batteryLevel object attribute to become compatible Battery Watch? Right now I'm updating a custom state only.
I'm able to update the device.address attribute but only when the user is editing a device.
Thu Dec 16, 2021 8:32 am
autolog offline
Re: Plugin Compatibility with Battery Watch
You need to have a boolean field in your devices.xml that has the name SupportsBatteryLevel with a value of true and set to hidden.
Then you should add a device state of batteryLevel to the devices.xml and have some code like:
                    if dev.pluginProps.get("SupportsBatteryLevel", False):
                        battery_level = int(float(<BATTERY_LEVEL_VALUE>))
                        dev.updateStateOnServer(key='batteryLevel', value=battery_level)
Replace <BATTERY_LEVEL_VALUE> with the value from your battery.
Hope this helps. :)
Thu Dec 16, 2021 2:04 pm
ryanbuckner offline
[quote="autolog"]You need to have a boolean field in your devices.xml that has the name SupportsBatteryLevel with a value of true and set to hidden.
That did it. Thanks!
Users browsing this forum: norcoscia and 2 guests
