Reflector newbie looking for advice. Indigo 7.5 going 2021.
Fri Oct 08, 2021 8:28 pm
hwitten offline
Before going with Reflector I was going straight to my IP, with firewall, port forwarding etc.
I'm hoping to use Alexa once upgraded to 2021.x.x. I've been reading/researching before jumping off the cliff and found that the Reflector is needed to make Alexa work. Unless I've read it all wrong of course.
Reflector traffic may be a concern, but since I don't do much, if any, image transfers it may be a non issue. The only thing I'm using/concerned about, however slightly, is a control page for my DSC Alarm Panel. First outing was today and I noticed Indigo Touch went on pause after a brief time. I assume that's normal so as to keep traffic within reason.
Finally my question :)
If I leave my direct access up as well as WiFi and Reflector do I have to do some manual switching in Indigo Touch when I leave my LAN/WiFi?
To put it another way, what is the best configuration to use my Public IP when away from home yet WiFi and Alexa when at home.
Hopefully I'm just overthinking :)
Sat Oct 09, 2021 10:15 am
Re: Reflector newbie looking for advice. Indigo 7.5 going 20
Honestly, I'm not sure exactly what will happen. I believe you can have port forwarding and a reflector running at the same time, though I've never tried it myself.
Since Indigo Touch doesn't know how to automatically switch between a local bonjour connection and a port-forwarding solution, you're now either manually switching when you change networks or you are just using the port forwarding all the time. If it's the latter, then I don't think that enabling a reflector will cause any issues (assuming that it works with both active). However, I believe that any bonjour connection created while on your local network will automatically pick up the reflector and start using that for automatic switching.
Bottom line: you're going to have to just try it and see since we haven't tested that scenario (and to be perfectly honest it's not a supported scenario since doing the work to configure direct access from the Internet is such a site specific thing - it's why we created reflectors in the first place).
Sun Oct 10, 2021 12:21 am
hwitten offline
Thanks Jay. I'll play around some and report back. Low on the priority list though.
I just don't want to abuse the Reflector bandwidth. Is there any kind of gentle nudge should that happen?
Sun Oct 10, 2021 10:28 am
No worries – we'll send you an email if there is a problem.
Wed Oct 20, 2021 8:30 pm
hwitten offline
Been running 2021.x for a few days now. Indigo Touch is set for my public IP/firewall that forwards to Indigo Server on M1 Mini. Set same wether at home or out and about. Alexa works great at home.
Happy camper here.
Thu Oct 21, 2021 7:14 pm
Great, thanks for the follow-up report.
