Can't validate login
Sat Sep 18, 2021 3:49 pm
rgspb offline
I'm using version 7.5.3 with Indio 2021.1.1 and High Sierra and keep getting Invalid login in the setup. I've triple checked my login credentials and they are correct. What do I try next?
Sat Sep 18, 2021 4:43 pm
ryanbuckner offline
Re: Can't validate login
Make sure your client version and server versions are the same
Sat Sep 18, 2021 4:47 pm
rgspb offline
Of Indigo? I've only got the server running.
Sat Sep 18, 2021 4:57 pm
ryanbuckner offline
My mistake. This is a plugin specific question
Sat Sep 18, 2021 5:26 pm
Turn on debug logging and restart the plug-in.
Sat Sep 18, 2021 6:02 pm
rgspb offline
Sep 18, 2021 at 8:01:58 PM
MyQ Debug logLevel = 5
MyQ Debug myqLogin response = {
"SecurityToken": "",
"ReturnCode": "0",
"ErrorMessage": "please contact customer care, supportID: 3927793506220115376",
"CorrelationId": ""
MyQ Debug myqLogin failure, status_code = 400
Error plugin "MyQ 7.5.3" (pid 14351) unexpectedly stopped -- restarting in 5 seconds
Reloading plugin "MyQ 7.5.3"
Starting plugin "MyQ 7.5.3" (pid 14428)
Started plugin "MyQ 7.5.3"
MyQ Starting MyQ
Sat Sep 18, 2021 6:25 pm
Sat Sep 18, 2021 6:30 pm
rgspb offline
That did it, thank you! I still can't setup any devices but at least I'm able to log in.
Mon Sep 27, 2021 7:47 pm
MattDinOC offline
I am having the same auth problem with the MyQ server... I tried updating to the latest prerelease, but I get these errors:
   Upgrading plugin MyQ to newer version 7.7.1 (previous version moved to trash)
   Loading plugin "MyQ 7.7.1"
   Starting plugin "MyQ 7.7.1" (pid 87273)
   Started plugin "MyQ 7.7.1"
   MyQ                             Starting MyQ
   MyQ Error                       Error in plugin execution startup:
  File "plugin.py", line 67, in startup
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py", line 394, in __init__
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py", line 1047, in _execute_child
OSError: [Errno 2] No such file or directory
   MyQ                             Garage Door (CG08500FA764): Starting myqOpener Device 1847282094
   MyQ Warning                     Unknown writing to subprocess: ''Plugin' object has no attribute 'pymyq''
Is this because I'm on Indigo 7.5.0 with MacOS Mojave?
Matt
Mon Sep 27, 2021 7:52 pm
If you don't have Python3 installed per the instructions in the Beta 7.6.0 thread, then it won't work.
Mon Sep 27, 2021 9:55 pm
MattDinOC offline
Great, thanks!
