New Plugin - BMW Connected Drive
Sun Aug 15, 2021 5:59 pm
Turribeach offline
Re: New Plugin - BMW Connected Drive
I got version 1.0.4 from Github but it's not working properly, this is what I get:
BMW Connected Drive Debug runConcurrentThread starting
BMW Connected Drive Debug Send wrapper message: {"cmd": "vehicles"}
BMW Connected Drive Debug wrapper_read JSON decode error:
I see that you are using the bimmer-connected library in your plugin. I installed version 0.7.18 on my Python 3 env and it's working fine for me outsiode the plugin. The library releases page shows they have fixed the login issues. So looks like you just need to update the library version inside the plugin and it should work. I tried replacing the bimmer-connected library inside the plugin installation directory (/Library/Application Support/Perceptive Automation/Indigo 2021.1/Plugins/BMW ConnectedDrive.indigoPlugin/Contents/Server Plugin/bimmer_connected) but it didn't work, not sure if that hack is possible but thought it was worth a try.
Sun Aug 15, 2021 6:03 pm
Yeah, they were still dorking around trying to fix it last I checked. I'll see if I can get an update out soon.
Mon Aug 16, 2021 10:05 am
ryanbuckner offline
I'm getting login errors too:
Aug 16, 2021 at 9:17:52 AM
   BMW Connected Drive Error       BMW Account: [u'Authentication failed. Maybe your password is invalid?']
Sat Sep 04, 2021 9:46 am
ryanbuckner offline
@Turribeach did you have any luck getting this working?
Wed Sep 08, 2021 3:17 am
Turribeach offline
No, when I attempted to hack the new library version into the plugin it didn't work so I was waiting for joe to update the BMW library in the plugin and release a new version.
Sat Sep 18, 2021 8:42 am
ryanbuckner offline
I tried the same. Didn't work.
Mon Apr 11, 2022 10:59 am
ryanbuckner offline
it looks like there has been progress made here to combine the latest and greatest libraries
https://github.com/bimmerconnected/bimmer_connected
Sun Apr 17, 2022 11:53 am
I'm working on the Python3 version of this plugin for Indigo 2022.1. The updated bimmer_connected library is considerably different than what I was using before, and makes available a LOT of information on each vehicle. Way more than I can shoehorn into an Indigo device.
So, what I need from current users is a list of the information you actually need from the plugin. I'll definitely be doing simple stuff like fuel level and range remaining. Probably also door/window/lock states.
Just FYI, here's a (partial) list of the data I'm getting back from the API.
    'attributes':
        'vin': '5UX2V5C08L9BXXXXX',
        'model': 'X4 M40i',
        'year': 2019,
        'brand': 'BMW',
        'headUnit': 'MGU',
        'isLscSupported': True,
        'driveTrain': 'COMBUSTION',
        'puStep': '0321',
        'iStep': 'S15A-21-03-582',
        'telematicsUnit': 'ATM02',
        'hmiVersion': 'id7',
        'bodyType': 'G02',
        'a4aType': 'NOT_SUPPORTED',
        'capabilities':
            'isRemoteServicesBookingRequired': False,
            'isRemoteServicesActivationRequired': False,
            'lock':
                isEnabled': True,
                'isPinAuthenticationRequired': False,
                executionMessage': 'Lock your vehicle now? Remote functions may take a few seconds.'
            'unlock':
                'isEnabled': True,
                'isPinAuthenticationRequired': True,
                'executionMessage': 'Unlock your vehicle now? Remote functions may take a few seconds.'
            'lights':
                'isEnabled': True,
                'executionMessage': 'Flash headlights now? Remote functions may take a few seconds.'
            'horn':
                'isEnabled': True,
                'executionMessage': 'Using your horn is only allowed in certain situations in many countries. Responsibility for the use and adherence to the respective regulations lies solely with you as the user. \n\nDo you want to use the horn now? Remote functions may take a few seconds.'
            'vehicleFinder':
                'isEnabled': True,
                'executionMessage': 'Find your vehicle now? Remote functions may take a few seconds.'
            'speechThirdPartyAlexa':
                'isEnabled': True, '
                'executionMessage': 'Activate Alexa now? Remote functions may take a few seconds.'
            'sendPoi':
                isEnabled': True,
                'executionMessage': 'Send POI now? Remote functions may take a few seconds.'
            'lastStateCall':
                'isNonLscFeatureEnabled': False,
                'lscState': 'ACTIVATED'
            'climateNow':
                'executionMessage': 'Do you want to ventilate now? Remote functions may take a few seconds.',
                'executionPopup':
                    'popupType': 'DIALOG',
                    'title': 'Start Ventilation',
                    'primaryButtonText': 'Start',
                    'secondaryButtonText': 'Cancel',
                    'iconId': 59733
                'executionStopPopup':
                    'executionMessage': 'Stop climate control in your vehicle now? Remote functions may take a few seconds.',
                    'title': 'Climate control is running'
            'isRemoteHistorySupported': True,
            'canRemoteHistoryBeDeleted': False,
            'remote360':
                'isEnabled': True,
                'isToggleEnabled': True,
                'isComingSoonEnabled': False,
                'isDataPrivacyEnabled': False
            'climateTimer':
                'isEnabled': True,
                'tile':
                    'iconId': 59774,
                    'title': 'Ventilation timer',
                    'description': 'Set departure time'
                'page':
                    'primaryButtonText': 'SEND TO VEHICLE',
                    'secondaryButtonText': 'DEACTIVATE AND SEND TO VEHICLE',
                    'subtitle': 'Set departure time',
                    'description': 'By setting a departure time you let the vehicle know when you plan to use it.'
            'isChargingHistorySupported': False,
            'isScanAndChargeSupported': False,
            'isDCSContractManagementSupported': False,
            'isBmwChargingSupported': False,
            'isMiniChargingSupported': False,
            'isChargeNowForBusinessSupported': False,
            'isDataPrivacyEnabled': False,
            'isChargingPlanSupported': False,
            'isChargingPowerLimitEnable': False,
            'isChargingTargetSocEnable': False,
            'isChargingLoudnessEnable': False,
            'isChargingSettingsEnabled': False,
            'isChargingHospitalityEnabled': False,
            'isEvGoChargingSupported': False,
            'isFindChargingEnabled': False,
            'isCustomerEsimSupported': False,
            'isCarSharingSupported': False,
            'isEasyChargeSupported': False,
            'isSustainabilitySupported': False,
            'specialThemeSupport': [],
            'isRemoteParkingSupported': False
        'connectedDriveServices': [],
        'isMappingPending': False,
        'isMappingUnconfirmed': False,
        'driverGuideInfo':
            'title': "BMW\nDriver's Guide",
            'androidAppScheme': 'com.bmwgroup.driversguide.usa',
            'iosAppScheme': 'bmwdriversguide:///open',
            'androidStoreUrl': 'https://play.google.com/store/apps/details?id=com.bmwgroup.driversguide.usa',
            'iosStoreUrl': 'https://apps.apple.com/us/app/id714042570?mt=8'
        'themeSpecs':
            'vehicleStatusBackgroundColor':
                'red': 127,
                'green': 129,
                'blue': 133
        'exFactoryPUStep': '0719',
        'exFactoryILevel': 'S15A-19-07-553'
    'status': <bimmer_connected.vehicle_status.VehicleStatus object at 0x10679b1f0>,
    'observer_latitude': None,
    'observer_longitude': None,
    'available_attributes': ['gps_position', 'vin', 'remaining_range_total', 'mileage', 'remaining_fuel', 'remaining_range_fuel', 'fuel_percent', 'condition_based_services', 'check_control_messages', 'door_lock_state', 'timestamp', 'last_update_reason', 'lids', 'windows'],
    'available_state_services': ['status'],
    'brand': <CarBrand.BMW: 'bmw'>,
    'charging_profile': None,
    'drive_train': <DriveTrainType.COMBUSTION: 'COMBUSTION'>,
    'drive_train_attributes': ['remaining_range_total', 'mileage', 'remaining_fuel', 'remaining_range_fuel', 'fuel_percent'],
    'has_hv_battery': False,
    'has_internal_combustion_engine': True,
    'has_range_extender': False,
    'has_weekly_planner_service': False,
    'is_vehicle_tracking_enabled': True,
    'lsc_type': <LscType.ACTIVATED: 'ACTIVATED'>,
    'name': 'X4 M40i'
    'status':
        'lastUpdatedAt': '2022-04-15T14:08:28Z',
        'currentMileage':
            'mileage': 11154,
            'units': 'mi',
            'formattedMileage': '11154'
        'issues': {},
        'doorsGeneralState': 'Unlocked',
        'checkControlMessagesGeneralState': 'No Issues',
        'doorsAndWindows':
            {'iconId': 59737, 'title': 'Lock status', 'state': 'Unlocked', 'criticalness': 'nonCritical'},
            {'iconId': 59722, 'title': 'All doors', 'state': 'Closed', 'criticalness': 'nonCritical'},
            {'iconId': 59725, 'title': 'All windows', 'state': 'Closed', 'criticalness': 'nonCritical'},
            {'iconId': 59706, 'title': 'Hood', 'state': 'Closed', 'criticalness': 'nonCritical'},
            {'iconId': 59704, 'title': 'Trunk', 'state': 'Closed', 'criticalness': 'nonCritical'},
            {'iconId': 59705, 'title': 'Sunroof', 'state': 'Closed', 'criticalness': 'nonCritical'}
        'checkControlMessages':
            {'criticalness': 'nonCritical', 'iconId': 60117, 'title': 'Tires', 'state': 'OK'},
            {'criticalness': 'nonCritical', 'iconId': 60197, 'title': 'Engine Oil', 'state': 'OK'}
        'requiredServices':
            {'id': 'BrakeFluid', 'title': 'Brake fluid', 'iconId': 60223, 'longDescription': 'Next service due by the specified date.', 'subtitle': 'Due in October 2022', 'criticalness': 'nonCritical'},
            {'id': 'Oil', 'title': 'Engine oil', 'iconId': 60197, 'longDescription': 'Next service due after the specified distance or date.', 'subtitle': 'Due in November 2022 or 8997 mi', 'criticalness': 'nonCritical'},
            {'id': 'VehicleCheck', 'title': 'Vehicle check', 'iconId': 60215, 'longDescription': 'Next visual inspection due by specified date or, if shown, when stated distance has been reached.', 'subtitle': 'Due in November 2023 or 19001 mi', 'criticalness': 'nonCritical'}
        'recallMessages': [],
        'recallExternalUrl': 'https://www.bmwusa.com/safety-and-emission-recalls.html#5UX2V5C08L9BXXXXX',
        'fuelIndicators':
                'secondaryBarValue': 0,
                'infoIconId': 59930,
                'infoLabel': 'Fuel Level',
                'rangeIconId': 59681,
                'rangeUnits': 'mi',
                'rangeValue': '409',
                'levelIconId': 59682,
                'isCircleIcon': False,
                'iconOpacity': 'high',
                'chargingType': None,
                'mainBarValue': 100,
                'showsBar': True,
                'levelUnits': '%',
                'levelValue': '100',
                'isInaccurate': False
        'timestampMessage': 'Updated from vehicle 4/16/2022 10:08 AM'
    'properties':
        'inMotion': False,
        'areDoorsLocked': False,
        'originCountryISO': 'US',
        'areDoorsClosed': True,
        'areDoorsOpen': False,
        'areWindowsClosed': True,
        'doorsAndWindows':
            'doors':
                'driverFront': 'CLOSED',
                'driverRear': 'CLOSED',
                'passengerFront': 'CLOSED',
                'passengerRear': 'CLOSED'
            'windows':
            'trunk': 'CLOSED',
            'hood': 'CLOSED',
            'moonroof': 'CLOSED'
        'tires':
            'frontLeft':
                'status': {'currentPressure': 214, 'localizedCurrentPressure': '31.0 psi', 'targetPressure': 234, 'localizedTargetPressure': '33.9 psi'}
            'frontRight':
            'rearLeft':
                'status': {'currentPressure': 234, 'localizedCurrentPressure': '33.9 psi', 'targetPressure': 255, 'localizedTargetPressure': '37.0 psi'}
            'rearRight':
        'isServiceRequired': False,
        'fuelLevel': {'value': 62, 'units': 'LITERS'},
        'fuelPercentage': {'value': 100},
        'combustionRange': {'distance': {'value': 659, 'units': 'KILOMETERS'}},
        'checkControlMessages': [],
        'serviceRequired':
            {'type': 'BRAKE_FLUID', 'status': 'OK', 'dateTime': '2022-10-01T00:00:00.000Z'},
            {'type': 'OIL', 'status': 'OK', 'dateTime': '2022-11-01T00:00:00.000Z', 'distance': {'value': 14480, 'units': 'KILOMETERS'}},
            {'type': 'VEHICLE_CHECK', 'status': 'OK', 'dateTime': '2023-11-01T00:00:00.000Z', 'distance': {'value': 30580, 'units': 'KILOMETERS'}}
        'vehicleLocation':
            'coordinates': {'latitude': XXXX, 'longitude': XXXX},
            'address': {'formatted': 'XXXX'},
            'heading': 77
        'climateControl':
            'activity': 'INACTIVE'
    'all_lids_closed': True,
    'all_windows_closed': True,
    'are_all_cbs_ok': True,
    'are_parking_lights_on': None,
    'charging_end_time': None,
    'charging_level_hv': None,
    'charging_start_time': None,
    'charging_status': None,
    'charging_time_label': None,
    'charging_time_remaining': 0.0,
    'check_control_messages': [],
    'condition_based_services':
        <bimmer_connected.vehicle_status.ConditionBasedServiceReport object at 0x112e3c3a0>,
        <bimmer_connected.vehicle_status.ConditionBasedServiceReport object at 0x112e3c2e0>,
        <bimmer_connected.vehicle_status.ConditionBasedServiceReport object at 0x112e3d630>
    'connection_status': None,
    'door_lock_state': <LockState.UNLOCKED: 'UNLOCKED'>,
    'fuel_indicator_count': 1,
    'fuel_percent': 100,
    'gps_heading': 77,
    'gps_position': (26.543991, -82.011688),
    'has_check_control_messages': False,
    'has_parking_light_state': False,
    'is_vehicle_active': False,
    'last_charging_end_result': None,
    'last_update_reason': 'Updated from vehicle 4/16/2022 10:08 AM',
    'lids':
        <bimmer_connected.vehicle_status.Lid object at 0x1130ded70>,
        <bimmer_connected.vehicle_status.Lid object at 0x1130df1f0>,
        <bimmer_connected.vehicle_status.Lid object at 0x1130defe0>,
        <bimmer_connected.vehicle_status.Lid object at 0x112e3c070>,
        <bimmer_connected.vehicle_status.Lid object at 0x112e3c130>,
        <bimmer_connected.vehicle_status.Lid object at 0x112e3d690>
    'max_range_electric': None,
    'mileage': (11154, 'mi'),
    'open_lids': [],
    'open_windows': [],
    'parking_lights': None,
    'remaining_fuel': (62, 'LITERS'),
    'remaining_range_electric': (None, None),
    'remaining_range_fuel': (409, 'mi'),
    'remaining_range_total': (409, 'mi'),
    'timestamp': datetime.datetime(2022, 4, 15, 14, 8, 28, tzinfo=datetime.timezone.utc),
    'windows':
        <bimmer_connected.vehicle_status.Window object at 0x112e3d600>,
        <bimmer_connected.vehicle_status.Window object at 0x112e3c4c0>,
        <bimmer_connected.vehicle_status.Window object at 0x112e3c370>,
        <bimmer_connected.vehicle_status.Window object at 0x112e3ece0>,
        <bimmer_connected.vehicle_status.Window object at 0x112e3d5d0>
Sun Apr 17, 2022 2:21 pm
ryanbuckner offline
My car isn't electric so I don't need any of that information. I use:
  • Basic Attributes: make model year
  • Status of each window
  • Status of each door (open/closed)
  • Status of each door (locked/unlocked)
  • Status of hood trunk sunroof
  • Fuel and range indicators
  • Mileage
  • Lat Long
  • Direction heading GPS
  • Anything I can control (locks, climate, horn, lights, etc.. )
Mon Apr 18, 2022 5:30 am
macpro offline
Is that all? :wink:
For me the fuel level and door status is useful info.
Details on the car like istep and type of headunit would be very nice to have, because I never know where to find these.
Mon Apr 18, 2022 6:29 am
For the Tesla plugin, I just dump all the JSON response into states.
I don’t process any of them, just leave them for the user to use.
(UI display state is a custom statename in config, so user can choose which state to display)
Mon Apr 18, 2022 6:32 am
That's what I was doing before, but there are multiple API calls to get different info, and the results are way to complicated now to do that. I'm working on an alternate solution.
Wed Apr 20, 2022 5:56 pm
Dave Durham offline
Hey FlyingDiver,
I'm glad you're still working on this Plug In! I used it extensively before. But when all is said and done my wants are simple :D
Is the car plugged into the charger or not?
Current battery level?
Current fuel level? (I have a BMW i3 with the Range Extender, so electric and gasoline but not a hybrid)
Door and Windows closed and locked?
Charging Started, Charging Done?
Current Range?
Those would make me very happy.
Thanks again for the great work!!!!
-Dave
Wed Apr 20, 2022 5:58 pm
Dave Durham wrote:
Hey FlyingDiver,
Current Range?
-Dave
As soon as Indigo 2022.1 is released, and you upgrade, I'll need you to run the plugin so I can see what data it's returning for your vehicle. As of right now, I only have gas-only test data.
Wed Apr 20, 2022 6:25 pm
Dave Durham offline
Joe,
Happy to help out. I'm usually an early adopter so 2022.1 can't come fast enough!
-d
