"product": {
"name": "LIFX A19",
"identifier": "lifx_a19",
"company": "LIFX",
"vendor_id": 1,
"product_id": 93,
"capabilities": {
"has_color": true,
"has_variable_color_temp": true,
"has_ir": false,
"has_hev": false,
"has_chain": false,
"has_matrix": false,
"has_multizone": false,
"min_kelvin": 1500,
"max_kelvin": 9000
amannone wrote:.... At any rate, it be much appreciated if you could add the new product id.
autolog wrote:"product_id": 93 isn't listed on the LIFX Developer site yet AFAICS, see: LIFX - Our Products
LIFX Error Error in plugin execution UiAction:
File "plugin.py", line 1302, in actionConfigLifxDeviceSelected
NameError: global name 'devId' is not defined
amannone wrote:... As an aside, I think I found a bug in the set color when trying to use "Pre-Fill Options: Set Value from Lifx Device". After picking the device from the dropdown, I get this error printed in the log an the UI does not update with the state from the selected device.I was getting this error in both the latest release from the Plugin Store as well as the pre-release on Github.
- Code: Select all
Should be fixed in Version 6.0.17, now available as a pre-release on Github: Bug Fix
