durosity wrote:siclark wrote:There's even a plugin for my tumble drier
Which tumble dryer do you have?
Bosch
durosity wrote:Thanks. Think I’ve got it working. Missed the detailed bit in the homebridge log where it said I had to add the tv manually in the Home App. Now I’ve done that I’m golden.Londonmark wrote:And probably the most useful of them all is the Harmony plugin that presents my remotes as if they were HomeKit TVs.. works bloody marvellously!
Which one are you using? I'm trying the nicoduj one but can only get volume and mute to show up in the Home App. Homebridge says I have a television accessory, but I can't see it anywhere in the Home App.
Yup it's nicoduj's.. it's probably your config, wanna send me your config.json and I can have a lookie?
(Sorry meant to post that earlier and forgot to click submit after writing it )
durosity wrote:yassi wrote:So, is it possible to have for instance Homebridge.io on a Raspberry Pi running and also still have the Indigo plugin on the Mac running?
Will it act as a second bridge and will be visible this way in Homekit?
Any drawbacks/interferences?
You can run it on a raspberry pi, or indeed the same Mac as Indigo
it will add a second bridge
no drawbacks/interference that I've experienced
siclark wrote:durosity wrote:siclark wrote:There's even a plugin for my tumble drier
Bosch
vtmikel wrote:Yes, about three seconds for me. With the config that HomeKit Bridge used, I had a slower experience, and sometimes the video feeds would cut out after a bit. Latest HomeBridge + ffmpeg I do not see that problem. I'm also running HomeBridge on a docker container.
What do you mean about the Security Spy plugin? The SS iOS app for me takes several seconds to connect to the server. Once connected, bringing up a feed is near instant.
siclark wrote:I’ve set up some automations in Eve, which exposed more device states than the Apple Home app, to sync homebrodge.io devices back to indigo. That involves meta relays in indigo published with HKB and 2 rules, one for on and one for off.
Not something I will do a lot but now gets status of my tumble drier power and door open/closed into indigo where I also have power consumption and temp/humidity
siclark wrote:Meta devices are indigo plugin. Relay is a dummy on/off switch you create with that plugin
Publish that device to HomeKit with HKB
In the Eve app, or Homeif it shows the device, create a rule that is triggered if native HomeKit device turns on, then turn on your dummy device in HomeKit. That makes your dummy device in indigo turn on.
Same again for turning off.
siclark wrote:vtmikel wrote:Yes, about three seconds for me. With the config that HomeKit Bridge used, I had a slower experience, and sometimes the video feeds would cut out after a bit. Latest HomeBridge + ffmpeg I do not see that problem. I'm also running HomeBridge on a docker container.
Running on BgSur, I see the Indigo HKB setup pointing to SS being much faster to pull up the live stream, <1second vs 3 seconds for the standalone Homebridge.io setup. However, the advantage that the latter brings is that audio now works in the iOS Home app, and my cameras in the app are independent from SS in case there are any issues there (sometimes after powercuts I have had it not restart properly due to network drive issues).
Yet to look at the motion detection, I use SS for that at the moment so interested to see if I get more from using Homekit to do it. I would expect SS's logic is more advanced.
Error: listen EADDRINUSE: address already in use :::8581
[6/5/2021, 4:05:59 PM] [Homebridge UI] Another process or service on this host is using port 8581.
[6/5/2021, 4:05:59 PM] [Homebridge UI] Please stop the other service or change the port you have assigned to homebridge-config-ui-x.
[6/5/2021, 4:05:59 PM] [Homebridge UI] Ending process now.
