Sun Oct 11, 2020 8:11 am
Set Reis it or to down
Click on confirm
Click on save
Then the notes field should change
Sun Oct 11, 2020 8:49 am
yassi offline
Click on confirm
Click on save
You mean "count transition down".
Done.
No it's showing LOW (0) and the status is updated.
Thanks, Karl!
Bildschirmfoto 2020-10-11 um 16.47.57.png (45.88 KiB) Viewed 5927 times
Sun Oct 11, 2020 9:03 am
Count off. That would give you
1 2 3... not 1/0
And the notes field does not change?
Sun Oct 11, 2020 9:13 am
yassi offline
Another question, Karl.
Would it be possible to us a sound detector sensor (with sound pattern recognition) with the plugin?
I know you would be able to develop this :lol: :idea:
Background: I would like to have something to recognize the ring of the bell. It's an old installation here in the house of my landlord, and at the moment not possible to replace it.
Well, it could be maybe possible to open the intercom device and maybe insert a sensor or something similar. But I don't trust these old installations.
So, I was thinking if it's somehow be possible to capture the ring bell, save it as a pattern and have it recognized --> if rings, set to HIGH or something like this.
Often I don't hear that ring bell thru the hallway and two closed doors while I'm in the kitchen.
I've searched the Internet and found this:
1. SOPARE: https://github.com/bishoph/sopare
2. https://www.youtube.com/watch?v=GcGF6b5 ... WL&index=1 :lol:
3. https://clydelettsome.com/blog/2019/12/ ... n-arduino/
Yassi
Sun Oct 11, 2020 9:14 am
yassi offline
1 2 3... not 1/0
Then I have no idea what to change.
I change it to this like in the screenshot.
Now it shows "OFF".
Let's see if it will stay so.
Bildschirmfoto 2020-10-11 um 17.15.55.png (18.15 KiB) Viewed 5912 times
Bildschirmfoto 2020-10-11 um 17.15.47.png (36.53 KiB) Viewed 5912 times
Sun Oct 11, 2020 9:40 am
I tried those. 50 error rate for simple things like on off
But the new google external ai device could be used.
I got one, but have not installed it.
Sun Oct 11, 2020 9:46 am
yassi offline
Oh, ok.
Which Google device do you mean?
Gesendet von iPhone mit Tapatalk
Sun Oct 11, 2020 9:51 am
Coral usb accelerator
Sun Oct 11, 2020 9:52 am
yassi offline
Ok, I‘ve heard once about it.
Thanks.
Sun Oct 11, 2020 12:24 pm
https://www.beaconzone.co.uk/allbeacons/iBS02M2
for a switch input you can try above BLE-beacon.
It sends a BLE advertising message when contact opens/ closes, runs on 2 CR2032 batteries. It can be up to 30 m away from the RPI (in a building w sheet rock (wood) walls, outside .. 100 m, not tested).
Better than WiFi sensors (ie shelly) as those just "eat" batteries. This one should last several years. Also the Wifi switches need to walke up contact the router, get an IP# and then send, that can take several seconds. This one is < 0.4 secs from switch change to the indigo device state change.
They have different versions of this one ( touch, magnetic, IR ..) the inside is the same besides the actual on/off sensor (mechanical, magnetic, IR short distance long range IR ..)
They are really ugly but work very well.
Also for magnetic - door window sensor try: url]https://www.beaconzone.co.uk/sensor/IM21[/url]
simple on/off, also very fast, and small and looks nice.
Similar for water leak: https://www.beaconzone.co.uk/sensor/EW70
I use now the 4 button remote https://www.beaconzone.co.uk/sensor/RC10 for my alley way sliding door and garage door: alley way door (3 buttons) open/close/stop --> 3 relays on RPi and garage door (one button) open/stop/close --> one Insteon switch connected to the garage door motor.
This are all very solid beacons that run on CRxxx battery cells, wake up for a message send the message and go back to sleep, very fast and long battery life
Mon Oct 12, 2020 9:07 am
yassi offline
Ok, thanks, Karl, I will have a look.
Yassi
Sun Feb 28, 2021 11:49 pm
GlennNZ offline
Hi Karl
I've had to use - predictable names for rpi networking.
Issue was wlan0 and wlan1 would constantly swap loosing connection and also having an new DHCP ip address appear and a number of log messages regarding. (wlan0 not strong enough)
This gives me a lovely ifconfig:
enxb827eb427d52: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.173  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::90bd:5cb9:8983:7022  prefixlen 64  scopeid 0x20<link>
        ether b8:27:eb:42:7d:52  txqueuelen 1000  (Ethernet)
        RX packets 427  bytes 119209 (116.4 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 84  bytes 13732 (13.4 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 4  bytes 240 (240.0 B)
        TX packets 4  bytes 240 (240.0 B)
wlan0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether b8:27:eb:17:28:07  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 0  bytes 0 (0.0 B)
wlx803f5d147f78: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 2312
        inet 192.168.1.183  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::916f:58fd:5c85:ce21  prefixlen 64  scopeid 0x20<link>
        ether 80:3f:5d:14:7f:78  txqueuelen 1000  (Ethernet)
        RX packets 459  bytes 164546 (160.6 KiB)
        TX packets 28  bytes 4476 (4.3 KiB)
        TX errors 0  dropped 3 overruns 0  carrier 0  collisions 0
pi@raspberrypi4:~ $ /sbin/route
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
default         HawkenPfsense.h 0.0.0.0         UG    304    0        0 wlx803f5d147f78
192.168.1.0     0.0.0.0         255.255.255.0   U     304    0        0 wlx803f5d147f78
Like that
The ETH is only for testing/setup, with WIFI being the only persistent connection.
I have appropriately name wpa_supplicant-wlan0 and wpa_supplicant-wlx803f5d147f78 files which work fine.
Issue is pibeacon can't find the IP address as no wlan0... or eth0; not surprisingly.
Can I set this manually somewhere?
(I did seem to recall a ipaddress file; but can no longer see it on the rpi)
Edit:
I have come to conclusion that I may be asking a bit much.... :)
Have returned to usual names wlan0/wlan1 and will have to try to figure out how to set one to another.
(?udev rules - but did find these weren't that stable..)
Mon Mar 01, 2021 10:33 am
I tried to automate as much as possible eg et the ip number. Naturally there is a limit to what options can be covered
I could add an option in the plugin to ignore all the "get IP number stuff" and set it to a fixed #.
If that would help you I can do that in the next days.
Mon Mar 01, 2021 2:16 pm
GlennNZ offline
Thanks Karl,
If it’s easy/not to much trouble, others and myself may have a need for it down the track., if not now. I suspect it may be useful for those with 2 wifi adapters, or as above, when need predicatable network names enabled.
But certainly not a priority, or rush. I’m continuing trying to sort out wlan0 and wlan1 swapping after boot.
Mon Mar 01, 2021 3:02 pm
I think I am done, still doing some testing
ignoring things is easier than adding things
