Getting this error when trying to check device history. I can see the main log.
Not sure if domopad or logging in sql causing the issue
Sent from my COL-L29 using Tapatalk
I haven't checked all my devices (would take very long time, hehe) but it seems all of them are getting the same invalid historical data error.
First I get internal error when launching (first screen shot) :
http://MYIP:8176/AndroidClientHelper/
WebServer internal server error "http://MYLOCALIP:8176/AndroidClientHelper/" from MYLOCALIPFROM
WebServer
Request Headers:
AUTHORIZATION: Digest username="MYUSERNAME", realm="Indigo Control Server", nonce="3bb406141e0ce03e315a4ff64970f508", uri="/AndroidClientHelper/", algorithm=MD5, response="319e84fb1982cab2e9ae9f9826b71b97", qop=auth, nc=0000026b, cnonce="6c4a1b878c4e169f"
HOST: MYLOCALIP:8176
UPGRADE-INSECURE-REQUESTS: 1
ACCEPT: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8
USER-AGENT: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/71.0.3578.44 Safari/537.36
CONNECTION: keep-alive
Remote-Addr: MYLOCALIPFROM
ACCEPT-LANGUAGE: en-US,en;q=0.9,nb-NO;q=0.8,nb;q=0.7
ACCEPT-ENCODING: gzip, deflate
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/IndigoWebServer/cherrypy/_cprequest.py", line 609, in respond
cherrypy.response.body = self.handler()
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/IndigoWebServer/cherrypy/_cpdispatch.py", line 25, in __call__
return self.callable(*self.args, **self.kwargs)
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/IndigoWebServer/plugins/AndroidClientHelper/reqhandler.py", line 157, in index
dbConn = self.getDatabaseConnection()
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/IndigoWebServer/plugins/AndroidClientHelper/reqhandler.py", line 380, in getDatabaseConnection
return indigosql.IndigoSqlite(dbConfig["dbName"], None, self.logMessage, None)
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/IndigoWebServer/plugins/AndroidClientHelper/dataAccess/indigosql.py", line 392, in __init__
self.sqlConn = self.sqlmod.connect(sql_lite_db_file, detect_types=self.sqlmod.PARSE_COLNAMES)
ValueError: database parameter must be string or APSW Connection object
WebServer undefined page requested "http://MYLOCALIP:8176/AndroidClientHelper/css/global4.css" from MYLOCALIPFROM
WebServer undefined page requested "http://MYLOCALIP:8176/AndroidClientHelper/css/indigo4.css" from MYLOCALIPFROM
WebServer undefined page requested "http://MYLOCALIP:8176/AndroidClientHelper/css/fonts.css" from MYLOCALIPFROM
RogueProeliator wrote:SQL logger (in debug perspective) is running as normal and tables are updating and adding data ok. Also tried to rename sqlite dB in order to start fresh. No effect. Do you have any idea how to restart services further? Or should I post in another forum for this error?Traceback (most recent call last):
This seems to be the issue - it is failing to read the database configuration. Do you have the SQL Logger configured and working?
No news?
