Fixed: Unable to begin with fresh install
Wed Mar 25, 2020 7:55 pm
Hackencrash offline
After my Mac SSD failed, I reinstalled Indigo 7.4 and piBeacon v7.118.340 onto a fresh install of Catalina.
With this fresh install, I am unable to get things started with piBeacon. The event log is flooded with piBeacon Errors, far too many to mention and occasionally the plugin restarts.
When I go into the plugin Configure... dialogue, I am unable to save any options as I get "Error validating fields" at the bottom, yet no fields are shown highlighted with errors.
The event log states: "indigo server userid or password not configured in config and security level is set to digest or basic"
I have put in the user ID and Password in these fields and set to Digest. I have tried different values here and can't get it to save any configuration at all to get rid of these errors.
What is the user field here? Is this the username that you configure in the Indigo Server connection dialogue box under Remote Access or is this the user for the Mac? I've tried both.
Remote access using the iPhone app, etc. works OK and all my other Indigo plugins work. The user ID that is set in Indigo is also a Catalina admin user ID with same password, but not the ID I login to the Mac with.
I cannot do anything and have spent hours on this - please help.
Wed Mar 25, 2020 8:12 pm
Re: Unable to begin with fresh install
please post the FIRST error message.
the userID and password is used by the RPIs to RESTfull connect w http to indigo
And yes starting from scratch is one thing I am not testing. I need to set that up on a separate system, will try overnight ... but my test license is not working --> Matt Jay?
Wed Mar 25, 2020 8:22 pm
Hackencrash offline
   piBeacon                        myLogSet setting parameters -- logFileActive= indigo; logFile= /Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.piBeacon/plugin.log;  debug plugin:[]   RPI#:-1
   piBeacon Error                  Error in plugin execution UiValidate:
  File "plugin.py", line 9446, in validatePrefsConfigUi
KeyError: key userIdOfServer not found in dict
Wed Mar 25, 2020 11:41 pm
Hackencrash: try latest version posted: 7.118.343
had a really weird issue (besides the key userIdOfServer not found in dict)
had to add copy.deepcoy() for a parameter in a function call:
def test(a,default={}):
   out = default  ## replace w copy.deepcopy(default)
  ...  read out from file a if exist ....
   return out
abc = test("filename" )
abc = "xyz"
def = test("filename2")
was overwriting "default" in the second call to test with the previous value, ==> abc == def == "xyz"
..still don't understand why
Thu Mar 26, 2020 1:26 am
Hackencrash offline
copy.deepcopy() - not had that issue myself!
Yep - that seems to have fixed it... well I can save my config anyway and I'm now not getting 100's of errors so I'm guessing everything is OK.
Thank you!
Thu Mar 26, 2020 8:19 am
Hackencrash offline
Re: Fixed: Unable to begin with fresh install
Been working solidly for 7 hours, glad to have this invaluable plugin back - I depend on it!
Marked as fixed - thank you 8)
