Help with JSON Variable Decoding
Fri Mar 13, 2020 7:43 pm
lvrouter offline
I have a URL (from a temperature sensor) which returns the following:
   "result": "success",
   "server_time": "2020-03-14T01:17:53Z",
   "channels": [{
      "channel_id": "12503",
      "field1": "Temperature",
      "field2": "Humidity",
      "field3": "Light",
      "field4": "Voltage",
      "field5": "WIFI RSSI",
      "field6": "Vibration Index",
      "field7": "Knocks",
      "field8": "External Temperature Probe",
      "field9": "",
      "field10": null,
      "latitude": "36.0097",
      "longitude": "-115.1479",
      "name": "Garage",
      "public_flag": "false",
      "tags": null,
      "url": null,
      "metadata": "{\"fn_th\":300,\"fn_light\":300,\"fn_mag\":0,\"fn_mag_int\":0,\"fn_acc_tap1\":0,\"fn_acc_tap2\":0,\"fn_acc_act\":0,\"fn_acc_min\":10,\"fn_bt\":0,\"fn_ext_t\":0,\"fn_battery\":7200,\"fn_dp\":900,\"cg_data_led\":1,\"wifi_mode\":1,\"no_net_fn\":1}",
      "description": null,
      "traffic_out": "273787",
      "traffic_in": "117292",
      "status": "{\"ssid\":\"cfwap\",\"status\":\"mac=6c:c3:74:eb:7d:77,usb=0\",\"usb\":\"0\",\"mac\":\"6c:c3:74:eb:7d:77\"}",
      "timezone": null,
      "created_at": "2020-03-12T02:09:23Z",
      "updated_at": "2020-03-12T18:28:16Z",
      "usage": "363330",
      "last_entry_id": "1908",
      "last_entry_date": "2020-03-14T01:11:29Z",
      "product_id": "ubibot-ws1",
      "device_id": "cf43a1776ff0218985d7a91a40965b1700819c56",
      "channel_icon": null,
      "last_ip": "70.180.187.74",
      "attached_at": "2020-03-12T02:09:23Z",
      "firmware": "ws1_v2.6.8",
      "full_dump": "0",
      "activated_at": "1583979074",
      "serial": "VBM***WS1",
      "mac_address": "6c:c3:74:eb:7d:77",
      "full_dump_limit": "3",
      "cali": null,
      "size_out": "1073741824",
      "size_storage": "209715200",
      "plan_code": "ubibot_free",
      "plan_start": "2020-03-12T02:09:23Z",
      "plan_end": null,
      "bill_start": "2020-03-12T02:09:23Z",
      "bill_end": "2020-04-11T02:09:23Z",
      "last_values": "{\"field1\":{\"value\":24.754333,\"created_at\":\"2020-03-14T01:11:15Z\",\"net\":\"1\"},\"field3\":{\"value\":22.43,\"created_at\":\"2020-03-14T01:11:15Z\"},\"field4\":{\"value\":3.132439,\"created_at\":\"2020-03-14T00:11:14Z\"},\"field2\":{\"value\":30,\"created_at\":\"2020-03-14T01:11:15Z\",\"net\":\"1\"},\"field5\":{\"value\":-33,\"created_at\":\"2020-03-14T01:11:17Z\"}}",
      "vconfig": "{\"field1\":{\"h\":\"0\",\"u\":\"1\"},\"field2\":{\"h\":\"0\",\"u\":\"3\"},\"field3\":{\"h\":\"0\",\"u\":\"4\"},\"field4\":{\"h\":\"0\",\"u\":\"5\"},\"field5\":{\"h\":\"0\",\"u\":\"6\"},\"field6\":{\"h\":\"0\",\"u\":\"7\"},\"field7\":{\"h\":\"0\",\"u\":\"8\"},\"field8\":{\"h\":\"0\",\"u\":\"1\"},\"field9\":{\"h\":\"0\",\"u\":\"9\"}}",
      "vpref": null,
      "battery": null,
      "vpref_from": "owner",
      "net": "1",
      "c_icon_base": null,
      "full_serial": "VBM39XWS1",
      "triggering_rules": null
If I access it as follows:
myvar = str(result['channels'][0]['field1'])
I get "Temperature" as the myvar as expected.
But how do I access the values within the "last_values" portion?
What I want is the value (in this case 24.754333) within that string (it's the temperature recorded by the device).
Thank you for any assistance you can provide.
Sat Mar 14, 2020 3:11 am
neilk offline
Re: Help with JSON Variable Decoding
This may be the blind leading the blind but I will give it a go.
"last_values" is returning a string rather than a dictionary, for reasons beyond my knowledge and maybe due to the way the JSON is generated or decoded
myvar = result['channels'][0]['last_values']
will return a string rather than a dictionary (and it is the same in a JSON viewer)
{"field1":{"value":24.754333,"created_at":"2020-03-14T01:11:15Z","net":"1"},"field3":{"value":22.43,"created_at":"2020-03-14T01:11:15Z"},"field4":{"value":3.132439,"created_at":"2020-03-14T00:11:14Z"},"field2":{"value":30,"created_at":"2020-03-14T01:11:15Z","net":"1"},"field5":{"value":-33,"created_at":"2020-03-14T01:11:17Z"}}
this does evaluate as a python dictionary so you could use
last_values_dict = json.loads(result['channels'][0]['last_values'])
So to set your variable you would need
tempvar = last_values_dict['field1']['value']
I am sure I have missed something and someone better qualified can give a better answer but this does work against your sample.
* Edited to replace the eval with JSON loads as the prior use of eval was not good practice
Neil
Sat Mar 14, 2020 8:00 am
lvrouter offline
There is no better answer, you obviously can "see"! Works perfectly, thank you.
FWIW, this is accessing the temperature and humidity settings on an UbiBOT sensor (on Amazon for $80). Battery powered, wi-fi and has all types of capabilities including a free "portal" to access and record. It's a pretty amazing little device. Been looking for something like this for a while.
Sat Mar 14, 2020 8:24 am
Are there truly escape characters in the data like that? That's weird.
Use extreme caution when using eval as it can expose you to malicious code. If you *always* know the source is safe, you should be okay.
Safer is to use literal_eval.
Sat Mar 14, 2020 8:29 pm
If that’s actually a JSON string, you should use json.loads() to convert it to Python. Using eval() really isn’t safe.
Sun Mar 15, 2020 1:02 am
+1 - it's escaped because it's JSON inside of JSON...
Sun Mar 15, 2020 4:26 am
I don't think I've ever seen that before.
#! /usr/bin/env python
# -*- coding: utf-8 -*-
import json
result = r'''{
   "channels": [{
      "field3": "Light",
      "field7": "Knocks",
      "field9": "",
      "field10": null,
      "name": "Garage",
      "tags": null,
      "url": null,
      "timezone": null,
      "usage": "363330",
      "full_dump": "0",
      "cali": null,
      "plan_end": null,
      "vpref": null,
      "battery": null,
      "net": "1",
level_1 = json.loads(result)
level_2 = json.loads(level_1['channels'][0]['last_values'])
print(level_2['field1']['value'])
Sun Mar 15, 2020 5:00 am
neilk offline
I updated the original post to reflect the "right way". Thanks everyone, every day is a school day :D
BTW I had tried json.load not json.loads as I had figured it might be json in a json but I forgot the string bit. Some of the more esoteric bits of python still catch me out.
Sun Mar 15, 2020 6:31 am
I learned something new in this thread, too. JSON inside JSON? Who knew?
(Jay knew. :D )
Sun Mar 15, 2020 6:36 am
neilk offline
And I should have said some of the simple things catch me out as well :D
Sun Mar 15, 2020 9:46 am
I'm not really sure why they'd implement it like that - seems like it would have been easier to just make the value represented by "last_values" the actual dictionary of values rather than the JSON escaped string representation of the dictionary. I can't think of any reason why they did it that way...
