Error in plugin execution runConcurrentThread
Wed Jan 22, 2020 8:28 am
Patje73 offline
I am pretty lost with this error.
EnablingXMPP did not help in solving this error.
Reloainf etc. has not worked eaither.
Does anyone have any advice on this one?
Harmony Hub Error               Error in plugin execution runConcurrentThread:
  File "plugin.py", line 71, in runConcurrentThread
TypeError: connect() takes exactly 2 arguments (1 given)
   Harmony Hub Error               plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Thanks a lot..
Wed Jan 22, 2020 8:34 am
Re: Error in plugin execution runConcurrentThread
Turn on debug logging, check the IP address in the Hub device, then restart the plugin. Then post the log.
Wed Jan 22, 2020 3:06 pm
Patje73 offline
Started plugin "Harmony Hub 7.3.0"
   Harmony Hub                     Starting Harmony Hub
   Harmony Hub Debug               Called deviceStartComm(self, device): Harmony Hub (417987721)
   Harmony Hub Debug               Harmony Hub: Device Current Version = 1
   Harmony Hub Debug               Harmony Hub: Device Version is up to date
   Harmony Hub Debug               Harmony Hub: Starting harmonyHub device (417987721)
   Harmony Hub Warning             Harmony Hub: Socket test failure, skipping hub connection
This is what I could take from the logging.
Hub functions via app..
Thanks a lot ,Patrick
Wed Jan 22, 2020 3:12 pm
You got this:
Which usually means you have the wrong IP address in the device configuration.
The plugin shouldn't be crashing when that happens. I'll have to fix that.
Fri Jan 24, 2020 11:07 am
Patje73 offline
Anything I can do? As in right IP address setting. Not sure where to do that.
Thanks..
Fri Jan 24, 2020 11:11 am
It's in the settings dialog for the Hub Device.
Screen Shot 2020-01-24 at 12.11.07 PM.png (753.87 KiB) Viewed 5382 times
Sun Jan 26, 2020 6:32 pm
denno offline
I'm having getting an identical error message. Confirmed that the IP address set in Indigo matches what is showing as the hub address in the Harmony app.
Sun Jan 26, 2020 6:53 pm
Are you getting this warning as well?
If so, you have the wrong IP address. Or a typo or some other error in the text field.
Sun Jan 26, 2020 8:05 pm
denno offline
No—not that warning
Sun Jan 26, 2020 8:06 pm
denno wrote:
No—not that warning
Then it's not the same error. I'll need to see a complete log in debug mode from restart.
Thu Dec 03, 2020 12:07 pm
mgolden50 offline
Your Harmony plugin has worked flawlessly until I just had a brief poser failure. When restored I'm getting same error message as the other folks.
I've confirmed that the IP setting is the same address as my router reports it to be.
If restarted the Harmony. No change.
Any suggestions?
Mike
Thu Dec 03, 2020 12:10 pm
Then make sure that XMPP didn't get turned off on the hub.
Menu -> Harmony Setup -> Add/Edit -> Remote & Hub
Thu Dec 03, 2020 12:11 pm
mgolden50 offline
Heres the debug log
 Harmony Hub Debug               Called deviceStopComm(self, device): Harmony Hub (1766988387)
   Harmony Hub                     Shutting down Harmony Hub
   Stopped plugin "Harmony Hub 7.3.0"
   Starting plugin "Harmony Hub 7.3.0" (pid 2284)
   Harmony Hub Debug               logLevel = 10
   Harmony Hub Debug               Called deviceStartComm(self, device): Harmony Hub (1766988387)
   Harmony Hub Debug               Harmony Hub: Starting harmonyHub device (1766988387)
Thu Dec 03, 2020 12:16 pm
mgolden50 offline
Checked XMPP
It was enabled So disabled and re enabled it. No Change
Thu Dec 03, 2020 12:21 pm
Confirm the IP address in the mobile app, Menu->About->Versions.
Also, post the Hub Software version and the App version.
