wideglidejrp wrote:I was able to get it working. I cannot explain exactly how. I think it would be much easier if all developers were identifiable by Apple although I don't know what that entails.
wideglidejrp wrote:Thanks for taking time to outline the detailed steps. I followed them. The good news is the plugin is now installed and Configure appears in the menu. The bad news is something is still wrong. The string of errors repeats every 10 seconds. Sonos is working. Favorites are loaded. Indigo action groups to do various things work. I cannot recognize anything in the error information I can take action on.
- Code: Select all
Action Group Sonos Play XM - Symphony Hall
Sonos ZonePlayer: Sonos - Workshop, Play SiriusXM: 76 - Classical Music with Preston Trombly
MyQ Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 78, in runConcurrentThread
File "plugin.py", line 394, in getDevices
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/models.py", line 816, in json
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/simplejson/__init__.py", line 307, in loads
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/simplejson/decoder.py", line 335, in decode
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/simplejson/decoder.py", line 353, in raw_decode
ValueError: No JSON object could be decoded
MyQ Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
