Adapters Error Error in plugin execution ServerReplacedElem:
File "plugin.py", line 130, in deviceUpdated
File "/Library/Application Support/Perceptive Automation/Indigo 7.3/Plugins/Adapters.indigoPlugin/Contents/Server Plugin/sensor_adapter.py", line 37, in go
KeyError: key chmode_value not found in dict
I wrote:I'll have to do a bit of sleuthing to be sure, but there may be room for improvement to the order of operations that the plugin uses to refresh the data. It sounds like what may be happening is that the plugin is wiping the slate of device states clean before ensuring that the newest content has been downloaded successfully.
