Device state - not working
Sat Oct 05, 2019 5:56 pm
SMUSEBY offline
I've tried two ways to report the device state as I read the documentation (one at the bottom of the plug-in, the other from documentation), and neither is inserting the device state into the email message created.
Two lines from my better email plug-in:
The Tank temperature is %%d:892742387:StateID%%.
Tank is now %%d:163642000:someStateID%%.
Resulting in the email message,
The Tank temperature is .
Tank is now .
Note: the tank temperature is a Phidgets device, not a variable.
Sat Oct 05, 2019 6:21 pm
Re: Device state - not working
Tank is now .
Why do you not have the actual state name/ID in there?
Sat Oct 05, 2019 6:49 pm
SMUSEBY offline
I used the device ID.
What is the "actual state name ID"?
Sat Oct 05, 2019 6:54 pm
Devices have states. You need to identify which state you want in there. I'm not a Phidgets user, so I don't know what those devices use. If it's a simple value sensor (one value per device), use "sensorValue" if you want the raw number, "sensorValue.ui" if you want the formatted number that's shown in the Indigo UI.
Sat Oct 05, 2019 6:56 pm
SMUSEBY offline
what value do I use for a device (on or off?)?
Sat Oct 05, 2019 6:58 pm
An on/off sensor, like a motion sensor? That would be 'onOffState'.
Sat Oct 05, 2019 7:49 pm
SMUSEBY offline
Not a sensor; for this instance, I want the on/off state for a device.
Is there a list of Indigo states that would be appropriate for this field? I'm guessing that the syntax needs to be precise.
Sat Oct 05, 2019 8:13 pm
SMUSEBY wrote:
Not a sensor; for this instance, I want the on/off state for a device..
A sensor is a device.
You need to take this over to the Phidgets forum/thread. This is not a Better Email issue. The states are defined by the plugin, unless it's derived from a standard Indigo base device. In which case it'll be one of the state names I already gave you.
Sat Oct 05, 2019 9:17 pm
SMUSEBY offline
OK.
Thanks.
Sun Oct 06, 2019 11:37 am
In the Main Window grab the divider above the Device Details section and drag upward to expose all of the Custom States defined by the device. So in the case below which is for a Timer device the stateIDs that could be used are longStatusString, timeLeftDays, etc. Not shown in that list will be the non-custom states, which are the ones built-in to the device type. So for example, an On/Off Relay device or an On/Off Sensor device always has a state of onOffState defined (which might be what you are after). Other examples, a dimmer device always has brightnessLevel. You can also log all of the states to the Event Log by choosing the Plugins->Open Scripting Shell menu item then pasting in something like this (substitute in correct device ID you are interested in for someDevIdHere):
indigo.server.log(unicode(indigo.devices[someDevIdHere].states))
Screen Shot 2019-10-06 at 12.29.59 PM.png (169.21 KiB) Viewed 3913 times
Sun Oct 06, 2019 2:06 pm
SMUSEBY offline
This sounds like what I need. However, I can't find the window over Device Details. (the attached shows where I'm looking).
Sun Oct 06, 2019 2:15 pm
Click-drag on the thumbnail grabby thingie (the small gray circle) that is directly above the "left .53" and drag up – it will expose the device states view.
Sun Oct 06, 2019 2:18 pm
You need to drag up on the "dimple". See the image.
But in this case, you don't need to see what's in there. This is a standard on/off device. As I stated above, the name of the state is 'onOffState'.
Sun Oct 06, 2019 2:23 pm
SMUSEBY offline
Wow!
My peeling of the Indigo onion continues.
Sun Oct 06, 2019 2:33 pm
SMUSEBY offline
small bug: in the Device Details window, onOffState is written as On State (which I just discovered, does not work).
