My devices update however I also get an error for unknown device where the address is the same as an existing device. Also, the display on the device list shows the temp in "C" but it gets to indigo in the variable as "F" so the logic of using the temp to control the AC and heater works. Here are some screen shots:
Oct 19, 2018 at 8:18:46 AM
Trigger Temp change in children room
Action Group Check status of children room temperature python
Script Children room temp is 65.8. Setpoints are 75/66. Outside temp for AC to turn on is 56. Outside temp is 60.9
RFXCOM Error unknown device detected (id = 8, type = 112). Select a RFX Sensor from the list of devices
and
Oct 19, 2018 at 7:51:11 AM
RFXCOM Error unknown device detected (id = 1, type = 112). Select a RFX Sensor from the list of devices
Attached are screen shots of the device list showing the address, device type and the temperature in C.
