Fibaro Wall Plug Type G FGWPG-111 (UK Socket)
Sun Sep 30, 2018 5:02 am
Suncroft offline
Re: Fibaro Wall Plug Type G FGWPG-111 (UK Socket)
I to am a bit disappointed that this did not make it as I had submitted the definition via Indigo back in June. Really hope to see it in 7.2.1 especially with the up to date subscription service :)
Appreciate all the work you guys do though on 7.2.
Stephen
Sun Sep 30, 2018 11:25 am
Noted, but if I understand this thread correctly it is working well now. The only thing missing is UI for the configuration parameters, but those can still be set now via the Modify Configuration Parameter... menu. Is that correct?
Mon Oct 01, 2018 1:53 am
Suncroft offline
Hi Matt,
Yes agreed its just a cosmetic thing my plugs are working fine.
Stephen
Mon Oct 01, 2018 9:46 am
We have to prioritize things, and we tend to favor adding devices that don't work before devices that do work but just don't have UI for config settings (since there is the ability to generically set parameters).
Sun May 12, 2019 4:18 pm
Indigo 7.3 (and 7.3.1) are now available and should support the Fibaro Wall Plug Relay (FGWPG111).
Mon Oct 16, 2023 2:52 pm
mike_c offline
unable to switch off
I have two of these devices. One for about a year that is working perfectly; the other just very recently.
I am unable to switch off the new socket. Any ideas ?
I note that parameter 1 can be set via UI option : Force module to always ON (disable OFF)
Param 1 is defined as per : https://manuals.fibaro.com/document/fgw ... arameters/
However, neither the UI or the Modify Configuration Parameter options seem to work, and the device is left on all the time.
When I try to read the value of parameter 1, I get:
Z-Wave Error failed to read value -- device may not support parameter 1 or may be asleep
(This happens on the existing device (this is working fine) and the new device (which does not want to switch off).
When I sync the device, I get the following:
2023-10-16 21:40:59.207 Z-Wave Syncing - started for "study power socket"
2023-10-16 21:40:59.214 Z-Wave Syncing - retrieved module neighbors list: 9, 14, 15, 19, 22, 25, 37
2023-10-16 21:40:59.214 Z-Wave Syncing - assigning return route to "038 - study power socket"
2023-10-16 21:40:59.992 Z-Wave Syncing - assigned return route
2023-10-16 21:41:00.437 Z-Wave Syncing - retrieved manufacture and model names: Fibaro System - 010F, Wall Plug Relay (FGWPG111) - 18011000
2023-10-16 21:41:00.489 Z-Wave Syncing - retrieved protocol version 4.61, app version 4.02
2023-10-16 21:41:00.539 Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01, base 25)
2023-10-16 21:41:00.539 Z-Wave Syncing - retrieved command classes: 20v1 25v1 27v1 5Ev1 85v1 8Ev1 59v1 55v1 86v1 72v1 5Av1 73v1 98v1 9Fv1 6Cv1 32v3 70v1 56v1 71v1 75v1 7Av1 22v1
2023-10-16 21:41:00.539 Z-Wave Syncing - retrieved encrypt commands: - none -
2023-10-16 21:41:00.539 Z-Wave Syncing - retrieved capabilities: routing, beaming, security
2023-10-16 21:41:00.639 Z-Wave Syncing - retrieved group 1 associations: [1]
2023-10-16 21:41:00.690 Z-Wave Syncing - retrieved group 2 associations: []
2023-10-16 21:41:00.740 Z-Wave Syncing - retrieved group 3 associations: []
2023-10-16 21:41:00.741 Z-Wave Syncing - group 1 association to interface already exists (skipping)
2023-10-16 21:41:19.452 Z-Wave Syncing - failed to retrieve parameter 1 "Force module to always ON (disable OFF)" (skipping)
2023-10-16 21:41:19.500 Z-Wave Syncing - retrieved parameter 2 "Power up to last known state" is false
2023-10-16 21:41:19.551 Z-Wave Syncing - retrieved parameter 40 "Power exceeded threshold" is 30000 * 0.1 watts
2023-10-16 21:41:19.602 Z-Wave Syncing - retrieved parameter 3 "Power overloaded threshold" is 0 * 0.1 watts
2023-10-16 21:41:37.951 Z-Wave Syncing - failed to retrieve parameter 10 "Immediate power threshold" (skipping)
2023-10-16 21:41:38.000 Z-Wave Syncing - retrieved parameter 11 "Interval power threshold" is 10 %
2023-10-16 21:41:38.051 Z-Wave Syncing - retrieved parameter 12 "Interval report delay" is 15 seconds
2023-10-16 21:41:38.102 Z-Wave Syncing - retrieved parameter 13 "Energy report threshold" is 3600 * 0.1 kWh
2023-10-16 21:41:38.153 Z-Wave Syncing - retrieved parameter 14 "Periodic power reports" is 3600 seconds
2023-10-16 21:41:38.204 Z-Wave Syncing - retrieved parameter 15 "Include Wall Plug energy usage in reports" is false
2023-10-16 21:41:38.255 Z-Wave Syncing - retrieved parameter 41 "LED ring color when ON" is 1 "Smooth Color Change from Power"
2023-10-16 21:41:38.305 Z-Wave Syncing - retrieved parameter 42 "LED ring color when OFF" is 0 "Off"
2023-10-16 21:41:38.391 Z-Wave Syncing - complete
This is remarkably similar to the existing device.
Any thoughts or pointers appreciated.
Wed Oct 18, 2023 8:52 am
Is this one newer than the one that's working? The device does seem to be indicating to Indigo that it doesn't support that parameter. Clear your Event Log window, turn on Z-Wave debugging, and resync. Then paste in the log so we an see what the device is sending when we try to access that parameter.
