Dynamic Refreshing Image URL
Tue Mar 06, 2018 11:15 am
Colorado4Wheeler offline
Re: Dynamic Refreshing Image URL
matt (support) wrote:
Yeah, the variable redirect doesn't support authentication currently.
You could also write the URL to fire something else that does allow authentication via the URL, such as a PHP file served on the same mac with Apache or something. This is making a little issue highly complicated but it can be done if you think outside the box.
Tue Mar 06, 2018 7:27 pm
jrickmd offline
Thanks for the response, guys. Don't think the image in front of another will solve my ultimate issue, which is having a log file filled with 404 error messages when a camera is not connected... WiFi cameras are NOT my friends. Trying to find ways to wire all my cameras is my next solution...
Thanks again,
Rick
Sun Apr 29, 2018 7:48 am
So here's a new one.
Using basic auth on a new camera. This URL works fine in a browser:
http://user:pwd@192.168.0.999/cgi-bin/currentpic.cgi
It gives me a snapshot and nothing else, which is just what we want.
But when I try to make it a variable for a DRI URL, I get this error:
http://localhost:8176/variable_url_redirect/redirect?name=CurrentCam load error: nonnumeric port: 'pwd@192.168.0.999'
EDIT: I tried this on another computer, and I'm presented with a login window instead of the image when I use Safari. So it seems this URL scheme is not correct.
Mon Apr 30, 2018 9:43 am
That IP address is invalid (999 as the last part isn't valid)... :wink:
Mon Apr 30, 2018 10:07 am
well yeah.
I do that for the same reason I put the username as USER and the password as PWD. No reason to show anyone what my LAN is like.
Mon Apr 30, 2018 10:48 am
Um, ok.
I have no idea where that error is coming from then.
[EDIT] - yes I do (I think): viewtopic.php?p=145341#p145341
Mon Apr 30, 2018 12:29 pm
Yeah, I think that's the problem.
Just thought I'd mention that authentication does work if it comes after the host in the dynamic URL. I can pull from foscam cameras with http://192.168.0.999:88/cgi-bin/CGIProx ... apPicture2
but http://user:pwd@192.168.0.999/cgi-bin/currentpic.cgi does not work.
Mon Apr 30, 2018 12:48 pm
Right - if the authentication isn't HTTP-based auth (basic or digest which goes before the hostname) then it should work fine since the plugin just passes the GET data along.
Tue May 01, 2018 9:10 am
I'm fiddling about with the first locally saved image in the IWS/public folder, and wondering what the URL I should specify is. While https://myindigoname.indigodomo.net/etcEtc/whatev.jpg works, if I understand the way the reflector works, that's making a BIG trip outside my LAN to get the image. Seeing as I have only 0.8 Mbps upload speed, this has the chance of slowing down things a lot.
Can I specify http://localhost? http://192.168.(indigo server IP)? What's best practice?
Tue May 01, 2018 10:03 am
Are you talking about the IWS plugin that will serve up an image from a URL specified in a variable, or are you talking about the unprotected public directory that IWS serves up (yes, I just added that post after realizing that we never documented it beyond the README.txt file we put in that directory :oops: )? Those are two different things.
Tue May 01, 2018 10:43 am
Some of both actually. I’m using the IWS plug-in to specify file in the public folder.
Tue May 01, 2018 11:16 am
So, did that post answer your question? If not, can you rephrase?
Tue May 01, 2018 11:38 am
I think it does answer my question. I'll experiment and see.
Thing is I can access dynamic URLs that are on my LAN and not routed to the WAN if they're in a control page. So I would expect that a dynamic URL that is set to http://INDIGOSERVERIP/public/README.txt should work too.
But it doesn't.
I get
 WebServer                       http://localhost:8176/variable_url_redirect/redirect?name=CurrentCam load error: <urlopen error [Errno 61] Connection refused>
So I'm missing some understanding of how this all goes together. Because I have Dynamic URL variable values that are straight out of a camera that CANNOT reach the internet, and they work.
Tue May 01, 2018 1:46 pm
Sorry, I'm still not sure where you're going with this. This plugin does a simple HTTP redirect. So, when you hit the plugin's URL:
(for which you must specify authentication creds assuming you have auth turned on for IWS), it gets the URL from the specified variable and does a standard HTTP Redirect.
I'm unclear what this means:
Since README.txt isn't an image. I also don't know what this means:
without more clear explanation.
Tue May 01, 2018 1:54 pm
Maybe I'm not understanding what you're asking. So here are two examples. Remember that every single one of my cameras is blocked at the router from reaching the internet.
When the variable for the dynamic URL is set to http://192.168.0.999/tmpfs/auto.jpg?usr=USER&pwd=PWD the DRI URL plugin works, and the image is displayed in a Control Page as it should.
When the variable for the dynamic URL is set to http://INDIGOSERVERLANIP/public/whatev.jpg I get the error
I note that both of these image URLs are internal LAN addresses, but one of them can be displayed in a control page viewed from the internet via the reflector, and the other cannot. And I don't understand the reason why or if there's a workaround.
Page 4 of 9 1, 2, 3, 4, 5, 6, 7 ... 9
