BlueIris Indigo Plugin
Fri Feb 23, 2018 6:20 pm
Seeker offline
Re: BlueIris Indigo Plugin
i just had some time to play with this again. i upgraded from an early version to version 8. none of the communication seems to be working (profile update, triggers). did i miss another necessary step for the upgrade?
Fri Feb 23, 2018 6:21 pm
GlennNZ offline
Yes
Everything has changed !
The instructions are all updated - but need to change the trigger in BlueIris webalerts to be compatible to the new version
Fri Feb 23, 2018 6:33 pm
Seeker offline
GlennNZ wrote:
Yes
Ahh, what a difference a week makes. I changed the BI alert settings on a cam, trigger it, get this on indigo side:
Feb 23, 2018 at 6:31:47 PM
WebServer undefined page requested "http://192.168.1.101:8176/Cam6/EXTERNAL/1/True" from 192.168.2.100
Fri Feb 23, 2018 6:35 pm
GlennNZ offline
The port number is now the plugins port, not Indigo web servers
The plugin creates its own server
Don’t use 8176 - Indigo ones
Plugin default is port 4556
So exchange 8176 for 4556
G
Fri Feb 23, 2018 6:51 pm
Seeker offline
Some exchange 8176 for 4556
Thanks, that seems to work perfectly.
Sat Feb 24, 2018 12:32 am
GlennNZ offline
Version 0.8.5
https://github.com/Ghawken/IndigoPlugin ... /tag/0.8.5
This add a new Action group to generate a recent ClipList, with thumbnails for playback of recently recorded files. (! )
This is the only addition but has taken a bit of time. Consider this addition a bit of a test, but if not running this action group - nothing specific has changed.
The new Action Group - Create Cliplist Html for Cameras
Select the Cameras (I do all) and then select the number of hours to go back and display the clips. (in hours)
This will go back the selected hours and for the selected cameras generate a cliplist of recent alerts/videos. The plugin then creates html file/s (stored in IndigoWebServer/static which can be used to display these clips).
Clicking on the clip then opens the video/playback/audio etc.
From within Indigo Touch - in a Control Page use go to external URL and use this URL to navigate here.
This will on my ipad open Safari and display nicely - can play videos by clicking, or just browse the thumbnails, and then click back top left arrow to go back to Touch.
(There is a Cross-Origin Domain issue with Chrome where the images won't show - so for the moment Safari it needs to be.)
eg.
IndigoIP:IndigoPort/static/CameraName-cliplist.html
eg
192.168.1.6:8176/static/FrontLow-cliplist.html
Try it out!
If I can think of better Indigo Touch integration I'll change.
But I am very pleasantly surprised at how useful this is going to be, as when I start down this cliplist road I wasn't quite sure how it was going to end up useful in Indigo!
__________________________________________________________________________________________________________________________________________________________________________________
Currently I have this action running every 2 hours generating the cliplists and html files. From within Indigo touch I now have a separate camera screen which pressing on the live camera feed - takes you to this external URL with a list of recent files; simple top left to go back!
I do serve the passwords for both BlueIris and Indigo from within the external URL - but they don't seem to be passed. This means when first taken to the link need to enter password first for Indigo and then for BlueIris. This appears to only happen once as Safari then saves.
Glenn
Sat Feb 24, 2018 3:33 am
neilk offline
Hi Glenn,
I cannot believe how much progress and so responsive you have been on this, it really is a fantastic work including your documentation, so once again thanks. One thing I am noticing is that my Blue Iris Server Device stops updating. If I reload it refreshes, but for example it hasn't updated since 15:23 yesterday. I don't yet have a need for it as I have BI Tools with notifications setup "pre-plugin" so no issue for me but I thought I should let you know. It may be one of those difficult issues as I have followed through almost all of your versions and tinkered before that. No log errors or warnings and triggers, gif creation etc are all working fine.
Neil
Sat Feb 24, 2018 3:44 am
GlennNZ offline
neilk wrote:
Hi Glenn,
Neil
Thanks for the feedback!
I’ll have a closer look at that device code - presume there is probably an missed exception happening somewhere in the log when BI is not contactable.... will track it down ....
(the debug log might show something earlier on to cause)
(might in fact be the camlist one Professor Falken reported which is caught at least in 0.8.0 and above)
Sat Feb 24, 2018 4:18 am
neilk offline
It could well be that it is to do with lost communication to BI and then not recovering, I was on 8.0 and now upgraded to 8.5 and I may have a something funky going on with my network that I am trying to pin down but it could have also been the connection where I was yesterday.
Neil
Sat Feb 24, 2018 6:22 am
CliveS offline
It maybe related to Neil's locking up but if I change a camera setting it closes the camera but does not restart it until I restart.
24 Feb 2018, 12:00:09
   Trigger                         Blue Iris Front Door Motion       <<Triggers OK
24 Feb 2018, 12:02:55
   BlueIris Plugin                 Stopping device: BlueIris Camera Living_Room  <<<<<Stop Living_Camera via an update to image size
24 Feb 2018, 12:03:11
   Trigger                         Blue Iris Front Door Motion      <<< Front_Door still triggers OK
24 Feb 2018, 12:04:30
24 Feb 2018, 12:07:41
24 Feb 2018, 12:07:58
   BlueIris Plugin                 Stopping device: BlueIris Camera Front_Door     <<<< Now I have changed image data and saved, Front_Door Cam stops and I try and trigger but nothing happens
24 Feb 2018, 12:09:52
   Reloading plugin "BlueIris Plugin 0.8.0"
   Stopping plugin "BlueIris Plugin 0.8.0" (pid 50200)
   BlueIris Plugin                 Restarting/or error. Stopping  thread.
   BlueIris Plugin                 Stopping device: Blue Iris Server Device
   Stopped plugin "BlueIris Plugin 0.8.0"
   Starting plugin "BlueIris Plugin 0.8.0" (pid 54253)
   BlueIris Plugin
   BlueIris Plugin                 ================================================ Initializing New Plugin Session =================================================
   BlueIris Plugin                 Plugin name:                   BlueIris Plugin
   BlueIris Plugin                 Plugin version:                0.8.0
   BlueIris Plugin                 Plugin ID:                     com.GlennNZ.indigoplugin.BlueIris
   BlueIris Plugin                 Indigo version:                7.1.1
   BlueIris Plugin                 Python version:                2.7.10 (default, Feb  7 2017, 00:08:15) [GCC 4.2.1 Compatible Apple LLVM 8.0.0 (clang-800.0.34)]
   BlueIris Plugin                 Install Path :                 /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/BlueIris.indigoPlugin/Contents/Server Plugin
   BlueIris Plugin                 Path to Gifsicle :             /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/BlueIris.indigoPlugin/Contents/Server Plugin/gifsicle/1.91/bin/giflossy
   BlueIris Plugin                 ==================================================================================================================================
   Started plugin "BlueIris Plugin 0.8.0"
   BlueIris Plugin                 Http Server Listening on TCP port 4556
   BlueIris Plugin                 BlueIris Update: Update Checking. Your Current version is: 0.8.0
   BlueIris Plugin                 BlueIris: Update Checking. The Github Latest release is: 0.8.5
   BlueIris Plugin                 BlueIris: Update Checking. Please visit the Plugin Store to Download
   BlueIris Plugin                 BlueIris Plugin: Update Checking.  Update is Available.  Taking you to plugin Store.
24 Feb 2018, 12:11:36
   Trigger                         Blue Iris Front Door Motion      <<<<<<< After reboot it triggers when I try again
CliveS
Sat Feb 24, 2018 2:28 pm
GlennNZ offline
Neil
Thinking about your issue. I think it will be because you have two BISever devices (probably one hiding somewhere in main directory)
Have a look and I’ll add a startup check for same.
If it happens again - turn on debug logging and check first box - BI Server Session only. Let this run for 10 minutes or so and PM me, or pastebin.org the resulting output - from the Event Logs directory.
Should be something fairly obviously within this log I would guess.
G
Sat Feb 24, 2018 2:53 pm
GlennNZ offline
Clive - thanks for the log.
Checking now and just seems comestic - Device Stop is logged at different level to Device Start. But both are happening (turn on debug logging and you'll see)
Triggers:
Fount it - squishing bug now.
After editing device or device restart defaults to disabled until checked with BIServer that Camera is online. (occurs every minute or so)
Changing behaviour to after startup/or editing defaults to Online as that probably makes sense
G
Sat Feb 24, 2018 3:50 pm
GlennNZ offline
Ok all; move on to
Release 0.9.3
- Code hardening for catching intermittent issues
- Change to default startup behaviour - cameras default to online; so remain online after editing preferences
- Add check for two BIServer devices at startup
- Change to update logging/turn of
- Fix for cliplist hyperlinks (image hyperlink was wrong/text right) Now both Right!
https://github.com/Ghawken/IndigoPlugin ... /releases/
Sun Feb 25, 2018 3:38 am
CliveS offline
Glenn, confirmed that bug has been squished :)
Triggers:
G
CliveS
Sun Feb 25, 2018 7:21 am
neilk offline
I checked and no duplicate device, I think I tracked down the network issue which was DHCP related (but not on the BI server but it was causing weird issues so I did some overdue housekeeping). I did have the issue yesterday (it stopped updating mid afternoon again) but I missed setting up the loggging.
Done now and also upgraded so if it does happen we should get an idea.
Neil
