Restarting every minute or so?
Wed Feb 07, 2018 5:15 am
autolog offline
Hi Karl,
Running the latest version 7.10.85.
I am getting this in the log every minute or so:
uniFiAP stopping plugin due to: ::::: new devices :::::
Reloading plugin "uniFiAP 7.10.85"
Stopping plugin "uniFiAP 7.10.85" (pid 26381)
uniFiAP Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Stopped plugin "uniFiAP 7.10.85"
Starting plugin "uniFiAP 7.10.85" (pid 26597)
uniFiAP setting parameters for indigo version: >>7<<
Started plugin "uniFiAP 7.10.85"
uniFiAP initializing ... variables
SQL Logger deleting table variable_history_1772453974
SQL Logger creating table variable_history_532564913 for "Unifi_With_Status_Change"
uniFiAP start runConcurrentThread, initializing variables ..
uniFiAP ..getting missing vendor names for MAC #
uniFiAP ..starting threads for 1 APs 4 sec apart (MSG-log and db-DICT)
uniFiAP ..starting threads for GW (MSG-log and db-DICT)
uniFiAP ..starting threads for 2 SWs 13 sec apart (db-DICT only)
uniFiAP initialized
Any clues on how to resolve this? :)
Wed Feb 07, 2018 8:00 am
Can you switch on debug - I believe it’s is connect-?
It thinks it is finding an unknown UniFi system device
I am out for the day. Jury duty in dallas. Just one day of waiting in large rooms.
Wed Feb 07, 2018 12:22 pm
https://www.dropbox.com/s/l0x46p2a2evqvfs/uniFiAP-v-7.10.86.zip?dl=1
could you try this version. Hhave added an option in config for unifi system devices to be used to do auto discovery/ reports: "/on/off/reports only".
But could you run it with ON? Then you should see why it thinks there is a new unifi device.
also switch on the debug - connect option. I need that to understand the details
Back from jury duty.
Wed Feb 07, 2018 12:30 pm
autolog offline
Re: Restarting every minute or so?
Just installed it :)
If I set the config to 'send logs to file', where is the file? :)
Wed Feb 07, 2018 12:31 pm
~/indigo/unifi
!!! it shows user id and passwords !!!
Wed Feb 07, 2018 12:51 pm
autolog offline
I have PM'd you the log - seemed safest. :)
