New plugin - RFPlayer by ZiBlue
Fri Nov 24, 2017 4:45 pm
Colly offline
Re: New plugin - RFPlayer by ZiBlue
Still no joy.. Getting this error each time I try a command:
   RFPlayer Error                  Error in plugin execution ExecuteAction:
  File "plugin.py", line 430, in sendCommandAction
KeyError: (233446487,)
Fri Nov 24, 2017 4:46 pm
That's a different issue. Try deleting the RFPlayer device and recreating it.
Fri Nov 24, 2017 4:55 pm
Colly offline
Deleted and recreated and still getting the error.
Fri Nov 24, 2017 4:58 pm
Did you delete and recreate the action group? If that doesn't work, I think I'm caching something in the preferences file that's messing things up. Try disabling the plugin, deleting the preference file, then re-enabling. You'll have to recreate the device and action group as well.
If that fixes it I'll try to find some time this weekend to figure out why the cached data is bad. Unfortunately, it's Holiday season and I think we're putting up the tree this weekend.
Fri Nov 24, 2017 5:07 pm
Colly offline
Something else going on I think!!
RFPlayer                        Starting RFPlayer
   RFPlayer Error                  "RFPlayer" serial port open error: [Errno 16] could not open port /dev/cu.usbserial-A1251VTU: [Errno 16] Resource busy: '/dev/cu.usbserial-A1251VTU'
   RFPlayer Error                  make sure the USB virtual serial port driver (ex: FTDI driver) is installed and correct port is selected
   RFPlayer Error                  exception in deviceStartComm(RFPlayer): _log() got an unexpected keyword argument 'isError'
Fri Nov 24, 2017 5:08 pm
Make sure you have the right port selected and that the Java config app is not running (because it will also open that port).
Fri Nov 24, 2017 5:11 pm
Colly offline
How do I do that?
Very early for the tree :D :D
Fri Nov 24, 2017 5:13 pm
Colly offline
This was the problem.
Thanks Joe.
Thu Nov 30, 2017 5:45 pm
Colly offline
Joe,
Is it possible to get entries in the log for any RFPlayer actions? Just like to see that a command properly issued if/when following up on unsuccessful operations.
Thu Nov 30, 2017 7:01 pm
Colly wrote:
Joe,
Turn on debug level logging.
Mon Dec 04, 2017 7:40 am
koburg offline
Somebody who know how to add the somfy rts remote
I have tried almost any thing with no luck. so far.
Thu Dec 07, 2017 11:15 am
koburg offline
I have a remote I have added in the java app parrot mode
but how do I use it with indigodomo to receive the remote commands to trigger a scene ?
Thu Dec 07, 2017 11:20 am
You can't right now. My bad on that. Same issue that was previously posted that the Parrot code went missing.
I'll try to get that fixed next week.
Tue Dec 26, 2017 5:39 pm
Colly offline
Hi Joe,
Getting this error in my log and seems to coincide with updating my OS. Any ideas of what's causing it?
   RFPlayer Error                  Error in plugin execution runConcurrentThread:
  File "plugin.py", line 92, in runConcurrentThread
KeyError: u'0'
   RFPlayer Error                  plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Tue Dec 26, 2017 5:45 pm
Turn on Verbose Debugging in the Configure Plugin dialog. That might give me a clue. That error on that line means it's not decoding the incoming data from the RFPlayer properly.
