Interested to know which system most people are using with Indigo so quick survey, if you use more then one pick your primary:
Zwave Insteon or Other?
Which controller is used with the above?
kelmk wrote:wemo
jay (support) wrote:I think you'll find that many people here use a combination of many different things: Z-Wave, Insteon, various WiFi devices, etc. This is the strength of Indigo - it abstracts the technology such that it doesn't really matter what the underlying system is. In fact, that is our recommendation. I'd expect your poll to not really represent reality given this fact (and you might not get many replies).
For Insteon, you must use a PowerLinc 2413U (recommended) or an Insteon USB Stick. Several USB Z-Wave interfaces are compatible, but we recommend the Z-Stick from Aeotec.
trazanka wrote:Interested to know which system most people are using with Indigo so quick survey, if you use more then one pick your primary:
