Can't Get Sunrise / Sunset To Work Properly
Tue Jun 27, 2017 4:15 pm
Re: Can't Get Sunrise / Sunset To Work Properly
I believe your custom latitude/longitude entries are incorrect. The commas should be periods... ;)
Tue Jun 27, 2017 4:18 pm
He's got a Euro format that uses commas. I tried it on my computer - same numbers, with periods. Same error.
Tue Jun 27, 2017 4:32 pm
Are you sure the sun ever actually shines there? LOL
We'll look into it.
BTW, I'm not sure if Indigo uses commas in those fields correctly - that's why I suggested trying periods.
Wed Jun 28, 2017 5:26 am
mortenkols offline
I have also tried to remove the custom latitude/longitude, but it make no difference on sunrise...
Skjermbilde 2017-06-28 kl. 13.23.49.png (71.91 KiB) Viewed 3410 times
Wed Jun 28, 2017 5:42 am
You might try going into OS X system settings for Date & Time to see what the setting is there. I'm not sure that it will make a difference, but you could try setting that to something new (save and exit the dialog) and then repeat the process with the proper setting. You may have to enter your administrator password if you've locked down those settings.
Wed Jun 28, 2017 6:47 am
CliveS offline
Just been playing with this problem, it seems that in Indigo the Longitude is fine up to 10.8, 10.81 jumps the date to 2085.
Try setting the the Longitude to 346.81 West (360-13.190) , that puts sunset at 23:51 28/6 and sunrise at 00:33 29/6
CliveS
CliveS
Wed Jun 28, 2017 9:33 am
mortenkols offline
if I set latitude to 65,869 it seems to work, if I set it to 65,870 its jump up to 2085. Weird.
Skjermbilde 2017-06-28 kl. 17.31.40.png (73.86 KiB) Viewed 3377 times
Wed Jun 28, 2017 10:22 am
It looks like there was a bug that occurs at some of the higher/lower latitudes around certain times of the year (near the days when there is a transition to the sun never setting or never rising).
arccos(-1.000000435) is NaN :evil:
I've added logic to catch this case to the next version.
