Security Camera Plugin
Mon Jun 12, 2017 4:26 pm
johnpolasek offline
Re: Security Camera Plugin
Got a problem hen when I upgraded to 1.6...
    Security Camera Error Error in plugin execution runConcurrentThread:
    File "plugin.py", line 605, in runConcurrentThread
    KeyError: 'key RecordingPause not found in dict'
    Security Camera Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
in red
Mon Jun 12, 2017 7:01 pm
bkmar1192 offline
Sorry - haven't had time to post a fix. Just open the plugin and re-save.
Sat Jun 17, 2017 10:35 pm
bkmar1192 offline
Just release 1.6.2 that should fix this issue.
Sun Jun 18, 2017 5:29 am
johnfdl offline
Just a small nit, when I click in Pugins->Security Camera->About Security Camera, it takes me to the Dynamic Control plugin page.
Sun Jun 18, 2017 9:47 am
Just upgraded. Opened the plugin config & re-saved. opened this camera & checked settings.
Still getting
 Security Camera Error           Error in plugin execution ExecuteAction:
  File "plugin.py", line 917, in Snapshot
KeyError: key Quality not found in dict
Mon Jun 19, 2017 8:09 am
bkmar1192 offline
Still getting
Do you get the error on start up or when taking a snapshot via the snapshot action? If the later, check the action and see if it has a resolution specified.
Mon Jun 19, 2017 8:10 am
bkmar1192 offline
Should be fixed in 1.6.2 release
Mon Jun 19, 2017 9:46 am
Looks like this was it. Thanks!
Tue Jun 20, 2017 5:18 pm
OK, and here's a new thing:
The carousel image seems to be stuck on one camera. I can look at images being captured by the plugin via multiple other methods, but the carousel image appears to be refreshing only a single camera, over and over again. I have not seen this behavior before.
Update: I've tried toggling the carousel. No change.
Sun Sep 24, 2017 11:13 pm
bkmar1192 offline
---- NEW VERSION 2.0 ----
New version of the Security Camera plugin with performance and motion detection improvements. This is a significant change to the base code of the plugin, please read all instructions below before upgrading.
Camera: Better performance and provides both standard and digest authentication.
Motion: Significant change in how motion is detected and reported. Will now show where the motion is detected and provides size and shape details of the detected objects.
PLEASE NOTE: This is a major new release of the Security camera software. Before upgrading please:
1. Turn off all cameras from within the previous version of the plugin (not the camera itself).
2. Perform the upgrade.
3. Open the plugin configuration and save.
4. Open each of the camera devices and re-save.
5. Turn cameras back on.
PLEASE NOTE: The motion sensing has dramatically change and previous use of motion detection triggers will no longer work. Please read the manual to reset all of your motion detection.
Cameras:
- Improved performace
- Use of Request code
- Handles basic and digest authentication
- Code improvements and clean-up
- More efficient file handling
Motion:
- Object detection
- Improved performance
- More detailed motion triggering
- Live motion display
Mon Sep 25, 2017 8:50 am
CliveS offline
Just tried to install the new Version 2, never installed before so brand new install.
Indigo log after install
2017-09-25 11:37:02.781 Application Installing and enabling plugin Security Camera v2.0
2017-09-25 11:37:02.782 Application Loading plugin "Security Camera 2.0"
2017-09-25 11:37:02.784 Application Starting plugin "Security Camera 2.0" (pid 31740)
2017-09-25 11:37:03.187 Security Camera Error Error in plugin execution InitializeMain:
File "plugin.py", line 22, in <module>
ImportError: No module named PIL
2017-09-25 11:37:03.187 Application Stopping plugin "Security Camera 2.0" (pid 31740)
2017-09-25 11:37:04.004 Application Stopped plugin "Security Camera 2.0"
2017-09-25 11:40:04.551 Application Reloading plugin "Security Camera 2.0"
2017-09-25 11:40:04.553 Application Starting plugin "Security Camera 2.0" (pid 31971)
2017-09-25 11:40:04.817 Security Camera Error Error in plugin execution InitializeMain:
2017-09-25 11:40:04.818 Application Stopping plugin "Security Camera 2.0" (pid 31971)
2017-09-25 11:40:05.731 Application Stopped plugin "Security Camera 2.0"
Decided a reboot of the Mac mini might help (yes years of using Windows!!!) but still no joy.
Started plugin "Z-Wave Lock Manager 1.0.45"
Started plugin "Action Collection 2.0.4"
Started plugin "Timed Devices 0.0.13"
Reflector starting reflector connection to https://xxxxxxxxxx.indigodomo.net
Started plugin "Online Sensor 0.0.9"
Stopping plugin "Security Camera 2.0" (pid 930)
Started plugin "Honeywell 0.5.1
Did a few checks in Terminal
Last login: Mon Sep 25 11:42:07 on console
Mac-mini:~ Indigo$ which python
/Library/Frameworks/Python.framework/Versions/2.7/bin/python
Mac-mini:~ Indigo$ sudo -H pip3 install Pillow
Password:
sudo: pip3: command not found
Mac-mini:~ Indigo$ sudo -H pip install Pillow
Password:
Requirement already satisfied: Pillow in /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages
Requirement already satisfied: olefile in /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages (from Pillow)
Mac-mini:~ Indigo$
Is the Versions/2.7/bin/python and Versions/2.7/lib/python2.7/ being different the problem?
CliveS
CliveS
Mon Sep 25, 2017 10:13 pm
bkmar1192 offline
I have had someone else with this same problem and I am stumped on how to fix it. I am going to post a question to the larger community and see if I get any assistance.
Password:
Password:
Mac-mini:~ Indigo$
CliveS
Sat Sep 30, 2017 5:48 am
CliveS offline
Finally got Security Camera installed (see http://forums.indigodomo.com/viewtopic.php?f=108&t=19104&p=145998#p145998 )
One thing I did notice is that the configuration settings are pointing to Indigo 6 directory, perhaps time to change that to 7 or check version and adjust (says a non programmer!!!)
Now off to read the manual and see what I can do with my 3 Hikvision cameras.
CliveS
CliveS
Sat Sep 30, 2017 10:29 am
bkmar1192 offline
CliveS
Hmmmm... thought I had fixed that. I'll go take a look.
Sun Oct 01, 2017 6:48 am
johnpolasek offline
Hmmm, I was going to update, but sounds like I need to wait for things to settle a little since everything is working fine now and I'm not using motion sensing. And the camera info is too valuable to lose...
