My log flowing which info from pibecon please help...
Wed Jun 07, 2017 12:17 pm
jens offline
Have replace indigowebserver file as you should, but still get all this,
would not use it for Becon´s only for difrent sensors.
Wed Jun 07, 2017 2:50 pm
Re: My log flowing which info from pibecon please help...
You can
Send log to file in config Then all pibeacon messages go to a file ... documents/pibeacon/pibeacon.log
If it is the weblog the option replace Webserver should work.
Also check if you have debugging switched on.
I am away from home will check later what those lines are.
Wed Jun 07, 2017 3:17 pm
jens offline
We're waiting for you to be home when Karl or when you have time.
Has turned off PI Beacon
//Jens
Wed Jun 07, 2017 3:29 pm
ok this is the fingscan plugin complaining the pibeacon plugin is not active. .. the message is mis leading .. it does not the the MAC number i an internal dict .
so to stop the flooding stop fingscan not pibeacon .. or you can switch off " use pibeacon for tracking" in FINGSCAN config
i will be posting a fingscan version that gives a bit more info in a minute
Wed Jun 07, 2017 3:35 pm
could you try THIS FINGSCAN version:
https://www.dropbox.com/s/revtiqkhrf107mb/fingscan-v-7-22-4.zip?dl=1
it should give the proper error message and a SHORT dump of the dict it is checking (100 bytes not 40 lines)
I would need to see the error message
Wed Jun 07, 2017 3:45 pm
jens offline
Is in bed, will check it first when I'm up :)
Thanks Karl, very nice app, wil try this instead of Arduino for my sensors and actors
Wed Jun 07, 2017 4:53 pm
fixed something, don't know it it will resolve your issue: fingscan was looking at all piBeacon devices also the sensors. Now it will look ONLY at ibeacons.
https://www.dropbox.com/s/7xhlrk85ll8saom/fingscan-v-7-22-5.zip?dl=1
Thu Jun 08, 2017 2:07 am
jens offline
It works now Karl, just shows what's happening in the log,
A question has an input that is linked to a motion monitor it shows on off but does not show the status of the icon do you know what i can do for wrong then?
Best regards Jens
Thu Jun 08, 2017 6:40 am
Ok. Just to play back. Fingscan is ok?
Then for pibeacon :which sensor type do you mean. The status shows on/ off but the icon does not change? And which version are you running?
In device. Edit you should be able to pick the status icon pair for each sensor.
Thu Jun 08, 2017 8:45 am
jens offline
Yes fingscan work perfect now, what I mean is that the device don't change status, (icon) have ir sensor, in the device, the latest one, download it tonight earlier it shoved indication
Thu Jun 08, 2017 9:46 am
I need more details:
could you post
a) the screen print of device edit
b) "print device info to log file" in pibeacon menu, select THAT ir sensor device in the selection menu that follows
Sun Jun 11, 2017 9:06 am
jens offline
Hello Karl,
Have been out for business for a few days, come home now downloaded the latest software V-7-60-104 and now everything works like it will be, sorry for the answer Karl.
Sincerely
Jens
