SecuritySpy: What cameras are uk users using?
Wed Apr 19, 2017 4:36 pm
Re: SecuritySpy: What cameras are uk users using?
Just noticed one's not POE.
I was planning on rewiring my LAN over Easter weekend; glad I didn't get further than lifting router onto a shelf made of two empty sweet tubs and a 2015 CPC catalogue now!
Wed Apr 19, 2017 6:39 pm
bkmar1192 offline
I'll throw my unabashed plug in here too - Security Camera. It will work with any camera that provides a URL pointing to a jpg image.
I am currently using a combination of Amcrest, Linksys, a cheap web cam, and a couple off-brand cameras.
My plugin does recording, motion sensing, and provides several different version of the image to create more versatile control pages. All is done within Indigo.
Thu Apr 20, 2017 3:27 pm
Does anyone know if the h.264 Foscam cameras provide JPG urls that Security Camera plugin can use? None of the Foscam cameras on Vesternet are MJPEG so I can't use iCamPro.
Fri Apr 21, 2017 6:58 am
jalves offline
I'm pretty sure the Foscam cameras do support JPG. Check out the documentation for your model at http://www.ispyconnect.com/sources.aspx
Jeff
Fri Apr 21, 2017 8:04 am
bkmar1192 offline
Different Computers is using Foscam C1, C3, and HD with the Security Camera plugin. I am using an Amcrest camera which is very similar to Foscam.
You can also go to http://www.ispyconnect.com/sources.aspx - there is a long list of cameras and what output types they support.
Sun May 14, 2017 3:03 pm
FYI, for the Foscam HD cameras, you need to follow this post:
http://skjm.com/forum/index.php?topic=6212.0
It works great!
Sun May 21, 2017 9:25 am
autolog offline
Found this post on how to view high quality Foscam video in VLC: How to use RTSP and HTTPS for HD cameras
Seems to work quite well : :D
Mon May 22, 2017 12:53 am
Busta999 offline
I have found this page very useful for setting up access to a very broad range of cameras.
http://skjm.com/icam/mjpeg.php
