CrazyFin wrote:I have a ZW062 staring at me here on my lab table. I´ll try hook it up to my garage door motor this weekend to test it.
In my post
http://forums.indigodomo.com/viewtopic.php?f=58&t=14504#p117115 I got the following device and firmware info when I did my first sync into my controller (Aeon Labs USB Gen5 stick) and to Indigo:
Model ID: 0003003E
Manufacturer: Aeon Labs
Manufacturer ID: 0086
Protocol Version: 3.99
Application Version: 1.11
Mine has the latest firmware 1.11 .
I finally had some time to install my unit into my garage door opener system.
Installation, inclusion and calibration went fine and I was also able to turn off the annoying sound.
Indigo controls the door opener properly and clicking "ON" in Indigo opens the garage door and status updates correctly in Indigo as well. Same thing for OFF which closes the garage door and status changes to CLOSED when door is fully closed.
Would be really nice of the state names in Indigo could be changed to OPEN and CLOSED instead of ON and OFF.
On thing I have noticed is that if the garage door is in the OPENING state and I press OFF or ON then nothing happens, the garage door completes its opening phase. Pressing OFF should STOP the movement of the garage door (which is what happens if I press the switch that is connected to the garage door opener or using the remote control). Pressing now ON after stop should continue the opening state and pressing OFF from the "paused" mode should start closing the garage door.
Same thing should happen when garage door is in the closing state, i.e. pressing ON should stop the closing process and pressing OFF after that should continue the closing process or pressing ON after the "pause" should start the opening.
These are just minor/cosmetic improvements that would make the Aeotec Garage Door Controller ZW062 completely integrated with Indigo.
EDIT:
Interesting! I did a direct association between the ZW062 and a battery operate remote wall switch (ZME-WALLC-S) and then I get the same control functionality as when I operate the garage door with the standard remote control or the built-in wall switch, i.e. pressing either button on the directly associated ZME-WALLC-S starts the garage door movement. Pressing again stops the movement and when I press it a third time the movement starts again but in the opposite direction which is correct. So it seems to be somewhat an issue with how Indigo controls the ZW062 when controlling the ZW062 via the Indigo GUI.
