I was wondering if anyone else has seen this. Over the course of the last few years I have increased my Home Automation significantly. Adding more switches, receptacles and sensors. But lately I am noticing a few bugs. Things that always seemed to just work are starting to get wonky.
An example of this is: I have a basic Trigger set in all the bathrooms to turn the light on when the motion goes on. It triggers a 4 min timer that upon expiring turns the off. And pauses the times if motion is again detected. This always seemed to just work. Now at times I can see the light go on on the Motion Sensor but no lights turn on. I can turn on the switch and then everything will work normally for awhile and maybe a few days later it will happen again. Sometimes it will turn on but the timer might expire and the light won't turn off.
My though is maybe I have too much going on in Indigo for it and something may be firing for something else like polling the Electricity usage for a Plot at the same time and Indigo is missing the light trigger. Is this possible?
Just about everything I use is Zwave.
