Hello,
I may be the only one with this (looking at the search results for GreenIQ) but if someone with any spare time and knowledge about writing a plugin could assist, many beers would be owed.
Basically there is a Python module already created and a sample script found here: https://bitbucket.org/greeniqrd/gardenkit-python-sdk
It uses oAuth to authenticate to their rest API.
What I would like is a plugin that would allow me to turn on a zone for a specified amount of time. Thats it.
GreenIQ has only 6 zones. I just want to be able to turn a zone on for x.
I can then use triggers or schedules to determine when to turn on zone y for x.
Anyone have any spare time that knows how to write what looks to be a simple plugin?
The Story: GreenIQ supports the use of FlowerPower sensors. It only supports 1 per zone though. I have 14 FlowerPower sensors. GreenIQ waters on a schedule, and does not if flower power says there is enough water. I want to water when the soil is too dry (trigger) not on a schedule.
I already have my irrigation system set up and is fed from water butts (mains powered pump), and if the buts drop too low (float switch) the mains water is used (solenoid valve).]
