[Solved]Scripting help please
Fri Feb 17, 2017 10:02 am
jalves offline
I want to set up a trigger that will turn on an exhaust fan (two actually) in my master bathroom when the humidity in there gets significantly higher than the rest of the house. The idea is that if somebody should happen to forget to turn the exhaust fan on when showering it will magically turn itself on. Here's what I was thinking of:
    I've got a Aeotec Multi-sensor in the master bathroom that reports humidity.
    I've got another Aeotec Multi-sensor in the Master Bedroom that reports humidity (there is a door between the MBath & MBR) so ...
    Indigo should compare the two humidity readings and trigger the bathroom fan to run for 20 minutes if the humidity in the bath is 10% higher than the reading in the bedroom.
Can't see how to do this with regular Indigo commands so I think I need a python script. Unfortunately, I'm totally python illiterate so I have no clue as to how to do this. Can anybody help?
Jeff
Fri Feb 17, 2017 11:33 am
Re: Scripting help please
This should be close:
# Get the two humidities
bathHumidity = indigo.devices[12345].sensorValue  # Insert ID of bathroom humidity device
bedroomHumidity = indigo.devices[67890].sensorValue  # Insert ID of bedroom humidity device
# Test to make sure the bath is more humid than the bedroom
if bathHumidity > bedroomHumidity:
   # Calculate the percentage difference and check to see if it's greater than or equal to 10%
    diff = float(bathHumidity - bedroomHumidity) / ((bathHumidity + bedroomHumidity) / 2) * 100
    if diff >= 10:
       # Percentage is greater than or equal to 10%, so turn on the device(s) for 20 minutes
       # Duplicate the following line for each fan
       indigo.devices.turnOn(54321, duration=1200)  # Insert ID of exhaust fan
Run this script (using the Execute Script action) from a trigger that fires whenever the bath humidity sensor value has any change.
Fri Feb 17, 2017 11:49 am
jalves offline
Thanks Jay! Appreciate your quick response to this.
I probably should have made my criteria a little clearer though. Both sensors will report humidity as a %. I simply want to run the trigger when the bath is 10 higher than the BR, so I should be able to change
to
Right?
Jeff
Fri Feb 17, 2017 12:10 pm
Yes, if you want just the difference between the values vs the percentage difference. In fact, to do just a straight comparison it gets much easier (since you don't really have to test first to make sure the bathroom is higher):
# Get the two humidity values
# Calculate the difference and check to see if it's greater than or equal to 10
if (bathHumidity - bedroomHumidity) >= 10:
   # Difference is greater than or equal to 10, so turn on the device(s) for 20 minutes
Fri Feb 17, 2017 2:46 pm
jalves offline
Perfect!
Jeff
Fri Mar 03, 2017 3:09 pm
jalves offline
Re: [Solved]Scripting help please
Just replying to my own thread for the possible benefit of others who may be considering a similar script.
I found a minor typo in Jay's suggested script; The line that says
needed to be changed to
indigo.device.turnOn(54321, duration=1200)  # Insert ID of exhaust fan
Note the absence of the "s" in indigo.device....
After making that change I realized that there was actually no reason to have the fan run for 20 minutes each time the logic triggered it. Since the action fires whenever the bathroom humidity sensor reports a change I could just put a smaller run-time in (I settled on 5 minutes). If the humidity hasn't yet come down enough (but is still changing) the trigger fires again.
Tried this out today by purposely not turning the fan on when I showered. Sure enough a few minutes into the shower the fan kicked on. It stayed running until some time after the differential returned to a satisfactory range.
Some may be wondering why I wanted to do this. I live in central FL and mold/mildew is a constant threat. I wanted to be sure that bathroom exhaust fans ran whenever somebody showered to keep humidity low not just in the bathroom but in the whole house.
Jeff
