Have homebridge working but get the following error with Buddy?
Any help would be appreciated
Dec 24, 2016, 11:04:45 AM
Reloading plugin "EPS - Homebridge Buddy 0.17"
Starting plugin "EPS - Homebridge Buddy 0.17" (pid 68591)
EPS - Homebridge Buddy Error Error in plugin execution InitializeMain:
File "<string>", line 1, in <module>
File "plugin.py", line 60, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/lib/eps.py", line 87, in loadLibs
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/lib/plugcache.py", line 58, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/lib/plugcache.py", line 543, in refresh
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/lib/plugcache.py", line 848, in _parseDevicesXML
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/lib/plugcache.py", line 966, in _parseConfigUINode
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/lib/plugcache.py", line 643, in _getElementAttribute
ValueError: XML attribute 'hidden' in file /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/iFindStuff.indigoPlugin/Contents/Server Plugin/Devices.xml has a value that starts with invalid characters: ''false' (should begin with A-Z or a-z):
<Field defaultValue="20" hidden="'false" id="UDist" type="textfield">
<Label>Distance device can be moved and be at same address (ft or m)?</Label>
</Field>
Stopping plugin "EPS - Homebridge Buddy 0.17" (pid 68591)
Stopped plugin "EPS - Homebridge Buddy 0.17"
