Multiple on/off statuses in one plot
Wed Dec 14, 2016 12:05 pm
Tsjompie offline
LS,
I'd like to plot multiple motion detectors in one graph.
Reason for that is to allow me to image on the movement in the house, determining whether someone is there. Eventually a variable is set "HouseInUse", based on the different motion sensors.
Plotting those as 0 or 1 implies any of the detected motions is shown on the y-axis, though multiple variables are written on the 0 or 1 scale. X-axis in time.
When no motion is detected all variables are plotted on the 0 value of the scale.
I assume using the multiplier per variable allows me to plot (for example) a 2, 3 or 4 on the y axis.
However, using that setup, when no motion is detected all the variable are still plotted on 0, making the graph impossible to interpret. All *, ^, + are on the same line, making it impossible to distinct.
I thought about a solution to cover this is to add 1 per motion detector, so the first one +0, the second one +1, the third +3, etcetera.
This would allow me identify which variable (motion) is on or off during a specific time span.
As far as I understand there is only the option to multiple, which will be useful for the ON state, though Off is still plotted on the 0 line. All motion detector plotting on 0 again makes the interpretation of the graph impossible.
Is there another way covering this?
Thanks for the input,
Tsjompie
Wed Dec 14, 2016 2:01 pm
Re: Multiple on/off statuses in one plot
One way : Mult=-1 add 1
Wed Dec 14, 2016 2:02 pm
Mult=-2. Add 2
Etc
Thu Dec 15, 2016 6:42 am
Tsjompie offline
Thank you :lol:
Started the config
Thu Dec 15, 2016 6:52 am
johnpolasek offline
I use event based plotting with a different multiplier for each device. Here is a plot of the last 24 hours showing when the driveway alert triggered (0.75), when my 3 motion sensors ((0.8, 0.85, 0.9) and when each of the 4 door open switches (1.0, 1.25, 1.5, and 1.75) occurred. The green line plotted against the right axis is the count of "family" Pi Beacons present listed as straight data. The only thing that I need to edit is to change the color of the Guest Motion to something a bit more distinctive from the Front Door...
Occupation Plot.png (58.48 KiB) Viewed 4284 times
Thu Dec 15, 2016 10:14 am
Tsjompie sorry misread your equation. I though you like to show the OFF state.
John shows an example how to show on/off (really nice plot)..
(((BYTW John, you could suppress the left y axis numbers as they do not add value: set tick marks to >>" "0<< would show a space at 0 the x-axis -- syntax:
"stringToShow"at posY,"stringToShow"at posY,"stringToShow"at posY,"stringToShow"at posY,
"abc"1,"123"5,"xxx",7
would show abc at Y=1; 123 at Y=5 and xxx at Y=7)))
In general to show x on/off lines and to remove the dots at 0:
mult= 1,2,3,4,5,6,7,8,..
offset = -0.01
yrange= 0:10 ( will not show anything < 0)
would put the ON states on 1,2,3,4,5,6,7,8 and OFF at -0.0001 (< 0!!)
and should not show the of states on the x axis as they are outside the plot are.
if you want to plot ONLY the OFF states do:
mult = -1,-2,-3,-4...
offset 0.9999,1.999,2.9999,3.9999
that would multiply the values with -1 and add 0.999 results in values 0/1 => 0.9999/-0.00001 = OFF at 0.9999 ON at -0.0001 and similar for 2,3,4
Fri Dec 23, 2016 5:49 am
Tsjompie offline
Hi Guys,
Just ran into your replies, for which I'd like to thank you.
In particular as that shows me how to solve the histogram view at the bottom of the plot.
At the moment the plot I use now serves the insight I was looking for, though with your input I'll change the way those histograms look like now.
Thanks for your support, enjoy your x-mas days.
Tsjompie
PS:
- the multi motion sensor is close to the dog basket
- the histogram data is based on the SmartPhone radar plugin
Sat Dec 24, 2016 3:32 am
You could get rid of the line keys by putting their label on the y axis with the trick set tick marks.
Mon Dec 26, 2016 9:45 am
Tsjompie offline
Merry X-mas Karl (and any other reading this :D ),
I tried to change those tickmarks (as that would show way better), though I seem to have a config set incorrect.
See the attached images for the string configuration and the graph.
Using quotes ("test","value","third,sensor","register","zes", "zeven", "acht", "negen", "ten", "eleven", "twelve") results in a error message in left corner of the plat stating: string incorrect.
Doing the same, ending with (e.g.) 10, 11 and 12 (integers) they show; the text ticks won't.
It would be great you help me out with this ;)
Thanks (again),
Tsjompie
Mon Dec 26, 2016 10:50 am
It is "label"position,"label"position ...
And position is a number.
So for your example something like:
"Test"1,"sensor"2,"register"3 .....
That would put Test on y=1 ; sensor on y=2 ....
Tue Dec 27, 2016 7:13 am
johnpolasek offline
And I can verify that it does work; my latest incarnation of the daily presence plot, which makes a lot more sense than the 0.5, 0.6, 0.7... etc that I had.
Tue Dec 27, 2016 8:50 am
And you can switch off the line keys :
Delete the text of the line key field for each line.
Wed Dec 28, 2016 4:32 am
Tsjompie offline
Thanks guys, for sharing this :)
Attached the plots I created, covering my needs.
E.g. setting the HouseInUse variable using triggers on the motion sensors.
(see plotmotion-minute-s1)
Other good example is:
I use (besides the default "isdaylight") also an "IsDark" variable. Very cloudy, not sunny, weather impacts the wish to enable lights. The graph showing that behavior is embedded as Luminance-minute-S2
Finally, the last plot shows the temperatures, combined with the setting (setpoints) of the Nest thermostats. This one still to be combined with the presence variable, for now only plotted in the motionplot. Once sure that behaves correctly I'll set the heating based on whether people are at home or not.
Again,
I'm very happy with this functionality as it doesn't only allow me to look at the behavior, but also to debug any incorrect set trigger to change variables.
Hoping you enjoy the configurations as much as i do.
Tsjompie
Temperatures and SetPoints of Nest
Luminance and Dark/Daylight
Motion plot including presence variable
