ZWave Lock Manager
Sat Nov 19, 2016 6:26 am
Bollar offline
ZWave Lock Manager
Thanks again for this.
With just these initial functions, I quickly created Action Groups to add users to my new locks and I added a schedule to allow a contractor access during the day.
Sat Nov 19, 2016 6:35 am
durosity online
Re: ZWave Lock Manager
Awesome! Sorry I wasn't able to finish testing with you, it's been a horrible week :(
Sat Nov 19, 2016 7:02 am
jalves offline
Thanks for creating this plugin! I'm about to buy a couple of z-wave locks and this looks to be very helpful in managing them.
Jeff
Sat Nov 19, 2016 8:33 am
Working fine with my Kwikset 910, so far.
Suggestion - change the deviceFilter in your Devices.xml (3 places) to:
   <Action id="setUserPin" deviceFilter="indigo.relay,indigo.zwave">
No need to list relay devices that aren't Z-wave. Have to ask M&J whether there's a filter for just lock subtypes.
Sat Nov 19, 2016 8:36 am
Ah, thanks - didn't realise I could combine filters.
I've already asked about filter for just locks - not available yet :)
Sat Nov 19, 2016 11:27 am
I actually got it snuck into 7.0 but forgot to tell anyone :-) :
for dev in indigo.devices.iter("indigo.relay, props.IsLockSubType"):
  print dev.name
# Or:
   <Action id="setUserPin" deviceFilter="indigo.relay,props.IsLockSubType">
Now that I think about it, technically you could leave off the indigo.relay specifier and just use props.IsLockSubType although I think I prefer that one specifies the main class type (relay in this case) too.
Sat Nov 19, 2016 11:29 am
Would
 <Action id="setUserPin"  deviceFilter="indigo.relay,indigo.zwave,props.IsLockSubType">
Work?
Sat Nov 19, 2016 11:34 am
FlyingDiver wrote:
Would
Work?
Just tested it. It works. With all three terms, I ONLY get the Z-wave door lock. Without the Z-wave term, I get the Z-Wave lock and my MyQ devices. Without the lock subtype, I get the Z-wave door lock and my water valves (my only other Z-wave relay type devices).
Sat Nov 19, 2016 11:36 am
Yes, that would and you are correct that is what we want here since the functionality is Z-Wave specific. Note that logically the search is performed by AND'ing the categories (protocol, class, and props) and OR'ing the items within each category. For example, using a filter string of:
indigo.insteon, indigo.x10, indigo.relay, indigo.dimmer, props.SupportsColor, props.SupportsWhiteTemperature
logically performs a search using:
(insteon OR x10) AND (relay OR dimmer) AND (props["SupportsColor"] OR props["SupportsWhiteTemperature"])
Sat Nov 19, 2016 11:37 am
matt (support) wrote:
Yes, that would and you are correct that is what we want here since the functionality is Z-Wave specific. Note that logically the search is performed by AND'ing the categories (protocol, class, and props) and OR'ing the property items within a category. For example, using a filter string of:
And if you need more than that, create the list dynamically. ;)
Sat Nov 19, 2016 11:38 am
Don't suppose device.scenecontrollers exists yet...? ;-)
Can you do my subforum for lock manager?
Sat Nov 19, 2016 11:54 am
Not yet. :(
I had made it before your last post. Apparently I like making changes and not telling anymore. :twisted:
Sat Nov 19, 2016 12:06 pm
Doesn't help that Tapatalk doesn't show empty subforums!
Sat Nov 19, 2016 12:24 pm
FYI I just split this topic into 2, so my update announcements are in an Announcement thread that's locked.
You can reply here or in new threads depending what it relates to.
Peter
Sat Nov 19, 2016 1:22 pm
durosity online
Does actually :) there's a add a motor subforum for c4w which shows that's empty!
