Verisure Plugin
Sun Jan 10, 2016 8:42 am
lindehoff offline
Re: Verisure Plugin
haavarda wrote:
Hi. The verisure my Pages has a possibility to enable or disable auto locking of the door. Is this possible to add to the plugin? If there is a lot of of traffic through the door it would be nice to disable auto lock for 1 hour etc...
Thanks for a great plugin!
Yes it is possible, I will try to implement it as soon as possible. You can see the status via this Issue on Github
Wed Feb 03, 2016 1:38 am
lindehoff offline
Verisure Plugin 0.3.0
New version available 0.3.0
Improvements
  • Plugin now support updates directly from Indigo #21
  • Exclude the python-verisure module from the plugin, you now have to install this module manually using
    sudo pip2.6 install vsure
  • Change Automatic Locking settings (Enable/Disable) #23
To get this version to work you have to do 2 things:
  • Install the vsure python module
  • You have to update you Lock Devices by deleting the lock and adding it again or open the Lock Device then click "Edit Device Settings" and then click Save.
Wed Feb 03, 2016 4:59 am
haavarda offline
Re: Verisure Plugin
Thanks for the update.
I am getting the following error when I try do disable AutoLock:
  Action Group                    Verisure - disable AutoLock 1h
  Verisure Error                  Error in plugin execution ExecuteAction:
  File "plugin.py", line 321, in updateAutoLockStatus
<type 'exceptions.KeyError'>: key automaticLocking not found in dict
Any idea?
Håvard
Wed Feb 03, 2016 5:03 am
lindehoff offline
Re: Verisure Plugin
Any idea?
Have you done the last step in my upgrade description:
Wed Feb 03, 2016 5:06 am
haavarda offline
Re: Verisure Plugin
Yes. I deleted the device, and created a new one...
Håvard
Wed Feb 03, 2016 5:26 am
lindehoff offline
Re: Verisure Plugin
When you are using the Action, you must click the "Edit Action Settings.." button and the click Save.
Wed Feb 03, 2016 5:34 am
haavarda offline
Re: Verisure Plugin
That did the trick. Thanks for your quick response.
Håvard
Wed Feb 03, 2016 5:38 am
lindehoff offline
Re: Verisure Plugin
New version 0.3.1
I have done a new release that should fix this. Please try the new Update feature within Indigo, Plugins->Verisure->Update Plugin
Sat Feb 20, 2016 4:57 am
DrLove offline
Re: Verisure Plugin
Hi! Great plugin!
I think you have introduced some unicode problems in your later releases:
<type 'exceptions.UnicodeEncodeError'>: 'ascii' codec can't encode character u'\xf6' in position 6: ordinal not in range(128)
Changing the name of my lock to something non-Swedish did the trick.
Best regards, L
Love Kull (yes it's my name)
Blog (in Swedish)
Sweden
Sat May 14, 2016 2:58 pm
Bjornror offline
Re: Verisure Plugin
Hello I'm getting this when I'm trying to start the app:
14 maj 2016 22:53:56
Reloading plugin "Verisure 0.3.0"
Starting plugin "Verisure 0.3.0" (pid 47925)
Verisure Error Error in plugin execution InitializeMain:
File "plugin.py", line 11, in <module>
ImportError: No module named verisure
Stopping plugin "Verisure 0.3.0" (pid 47925)
Stopped plugin "Verisure 0.3.0"
Ive installed the verisure python module without any problems. running El capitan.
Björn
Sun May 15, 2016 10:37 am
Re: Verisure Plugin
How did you install that python module? It needs to be installed in python 2.6 not 2.7.
Sun May 15, 2016 10:47 am
lindehoff offline
Re: Verisure Plugin
Björn
Sorry, I haven't had the time to replay. Try
Sun May 15, 2016 4:42 pm
Bjornror offline
Re: Verisure Plugin
I'm on el capitan and it comes with python 2.7 and I'm not sure if i could downgrade it to 2.6.
How to approach this problem?
Björn
Mon May 16, 2016 9:02 am
Re: Verisure Plugin
Python 2.6 is also installed on El Capitan. Python 2.7 is the default install, but there are 2.6 versions of all python commands. So, for python there's a corresponding python2.6, for pip there should be a pip2.6, etc.
Mon May 16, 2016 11:51 am
Bjornror offline
Re: Verisure Plugin
Ok i try to install with 2.6 and get this:
MiniMac:~ bjorn1$ pip2.6 install vsure
-bash: pip2.6: command not found
How do i use 2.6 ?
Page 4 of 10 1, 2, 3, 4, 5, 6, 7 ... 10
Users browsing this forum: Google [Bot] and 0 guests
