Fibaro Door/Window Sensor FGK101 - extra channel
Tue Aug 25, 2015 9:55 am
DomoPat offline
Hi users of the FGK101, before I buy them to replace old X10 security sensors, can you tell me:
1- can you use the extra channel of the sensor ? is it available in the configuration menu or does it appear as a second device ? it is possible to connect another 'dry contact' on that module, but if it is not handled by Indigo I need to find another solution.
2- what about battery life ? do you really get one year of use ?
Thank you for the help and info !
Patrick
Tue Aug 25, 2015 11:38 pm
MarcoGT offline
Re: Fibaro Door/Window Sensor FGK101 - extra channel
Hi DomoPat,
I have 6 of them; it is a bit of pain to include them as they are battery operated devices but they are very good in reporting status.
I use them for windows and doors, unfortunately I do not use they input (for example, temperature sensor).
I find the battery very good.
For the entry door which is opened/closed many times per day, now it is a 68% and it's there since February, 6 months round about. But windows which report lessare at 90% and they are there since January
It also depends on how often the status report is set (I have it at 4 hrs).
Hope this helps
Bye,
Marco
Wed Aug 26, 2015 1:21 am
DomoPat offline
Thank you Marco, this is good feedback.
In the configuration screen; do you see the possibility for the other input ? (not the temperature sensor, but the 'dry contact' input.).
Thank you,
Patrick
Wed Aug 26, 2015 1:31 am
McJohn offline
Hello Patrick,
I've tested (and use) a lot of different brands door/window sensors and by far the FGK101 is the best of the world (at this moment :-) )
- including proces is sometimes a tough job
+ transmission distance is perfect
+ battery live is the best, (68% after a year)
+ the extra channel for a separate contact works good (or it can be use for a temp sensor, not both!)
Kind regards,
John
Wed Aug 26, 2015 1:58 am
autolog offline
Hi Patrick,
I use the FGK101 to:
  • Detect my side door opening using the magnetic sensor
  • Detect my garage door opening using the IN (potential free input)
As others have said, battery life is excellent and device is reliable :)
The magnet and IN (potential free input) are seen as the same device in Indigo i.e. AFAIK it is not possible to differentiate between the two separate inputs - either operating will trigger the Door/Window sensor in Indigo. The tamper alarm is seen as a separate device.
Hope this helps :)
Wed Aug 26, 2015 2:45 am
DomoPat offline
This is the deal breaker for me ! I need the device to report the magnet and Aux input separately, like the X10-DS10 security device does today: I have one at each window reporting both the window opening and blind opening through two different devices in Indigo.
The FGK101 looks like a very good door sensor, I will use it for other application but my quest for a wireless-double-input ZWave device continues !
Thanks for all the good feedback everyone provided.
Patrick
Wed Aug 26, 2015 2:49 am
McJohn offline
Or you can use 2 x FGK101 :-)
Wed Aug 26, 2015 8:20 am
aderrington offline
Just thinking off the top of my head, could you not use the Fibaro universal sensor. I think that has multiple inputs. It's not as clean as the proper door/window sensors but could be an option.
Wed Aug 26, 2015 11:35 am
DomoPat offline
The Fibaro universal sensor. could be an option, but the battery life is probably very bad... and with 6 devices I will be ruined before I realize it !
Wed Aug 26, 2015 12:09 pm
durosity offline
Yeah I temporarily ran a universal sensor on a 12v 7ah alarm battery for about 3 weeks before it gave out.
Thu Aug 27, 2015 6:52 am
lochnesz offline
The Fibaro Universal Sensor isn't a battery operated device by design which of course drains battery quickly if you decide to feed it from a battery.
I have three mains powered (with power adapter of course :wink: ) fed from UPS powered outlets.
Peter
Thu Aug 27, 2015 9:55 am
durosity offline
Peter
Exactly! I use the 12v power from my alarm system to power mine, seemed the easiest and most elegant solution at the time :)
Thu Aug 27, 2015 11:53 am
Nice idea!
Fri May 12, 2017 7:16 am
MarcoGT offline
autolog wrote:
Hi Patrick,
Hope this helps :)
Very old thread, but I am interested in how you connected the garage door to the free input
My idea is to use an automatic switch which will be opened/closed by the garage door and this will send the input to the Fibaro Door/Window Sensor.
Or how did you do it?
Marco
Fri May 12, 2017 7:38 am
autolog offline
Hi Marko,
Take a look at this post: http://forums.indigodomo.com/viewtopic.php?p=85151
I have now replaced the Fiabaro with this device: Z-Wave Vision Door & Window Sensor - Gen5 (I think mine might be the previous non-Gen5 version - not sure without checking and it is installed in a difficult place to get to. ) :)
The Vision was a lot simpler to include/exclude than the Fibaro.
Users browsing this forum: No registered users and 19 guests
