Progress.
I did as you suggested and that part worked. I now have 4 devices set up, one for each relay and can manually toggle them when selected in the Device Panel.
But, I still am unable to set up a timer as the only action that I can make work at all is the "Action/Device Action/Phidget Controls/Control a InterfaceKit Digital Output Device (Phidget Controls)"
The Edit Action allows me to select one of the Phidgets that I set up under devices and asks for the output 0-3. But then asks for an "Output Action" and I am presented with Pulse On/Off or Pulse Off/On and a ms time which if selected 999 or less works. This is not what I need. I need to be able to turn on the relay and maybe an hour later turn it off.
So, I am once again stuck.
Thank you for your support,
Oliver
