Home Automation Skill for Alexa - HomeSeer has done it!
Mon Feb 20, 2017 6:24 pm
ricvieira offline
Just saw that HomeSeer implemented an Alexa skill that allows for quite sophisticated commands. I am currently using the Alexa-Hue bridge which is okay for basic commands, but reading HomeSeer's skill made my mouth water :P .
http://homeseer.com/amazon-echo-integration.html
Tue Feb 21, 2017 4:03 pm
Re: Home Automation Skill for Alexa - HomeSeer has done it!
Yes - it's on our feature request list. We wrote a blog post about it some time ago. Unfortunately, Amazon hasn't addressed the limitations, particularly the configuration/security issues, so it's still a very large undertaking.
Thu Apr 06, 2017 7:12 am
taber offline
Have you looked at the new Amazon Alexa API ?
https://developer.amazon.com/blogs/alex ... -dashboard
Are we any closer to seeing a release with Alexa support?
Thu Apr 06, 2017 1:36 pm
bkmar1192 offline
Reading through the HS article I accomplished almost everything that the article talks about except for getting Alexa to talk back to me.
The only oddity is saying, "Alexa, turn on {action}". However, I don't have to say, "Alexa, tell Indigo to...". So I view it as a trade off.
Some of my main commands:
"Alexa, turn on main lights"
"Alexa, set living room speakers to 75"
"Alexa, turn on/off front lock"
Thu Apr 06, 2017 2:35 pm
That's doesn't address the issues I outlined above. So, no, it doesn't help us any. We still have to address security and authentication on our side. we're looking at how to best and most securely address that.
Tue Jun 04, 2019 10:17 pm
whmoorejr offline
The Alexa Connect Kit...Does this open any doors? I'm not totally sure what it is.... just that it looks like a way to skip around the Alexa cloud authentication security issues to use the developer's service....
https://developer.amazon.com/alexa/connected-devices/alexa-connect-kit
or....
Is it possible to add the "Sensors API" definitions to the hue plugin? If we could add a virtual sensor, you could set up routines within Alexa that could do fancy Alexa things... like announce stuff.
https://developer.amazon.com/docs/smarthome/build-smart-home-skills-for-sensors.html
Bill
My Plugin: My People
Wed Jun 05, 2019 10:02 am
This is for hardware makers to add their hardware (blenders, washing machines, etc) more easily to the Alexa ecosystem. Doesn't apply for us.
Once a real Alexa Skill can be built, then the skill should be able to expose Indigo Sensor devices in this way. This isn't the place to discuss the Hue Plugin, so you'd want to clarify and post your question on that forum.
Wed Jun 05, 2019 6:15 pm
whmoorejr offline
Thanks for the quick reply Jay. I wasn't sure if it was something that could be incorporated at the reflector level... the documentation wasn't very clear to me.
I misspoke. I was actually referring to the Alexa Hue Bridge plugin.... so I'm heading over to Alexa-Hue Bridge.
Bill
Wed Jun 05, 2019 8:41 pm
ckeyes888 offline
Assuming there was native Alexa support, would the commands have to be prefaced with, “Tell Indigo”?
If that’s the case I prefer it the way it is.
Carl
Wed Jun 05, 2019 8:57 pm
whmoorejr offline
ckeyes888 wrote:
“Tell Indigo”?
I agree. The way it is... you can control anything in indigo. There are only two downsides...
1) You have to use "light" commands (turn off, turn on, set to 50 <-dimmers). For most stuff that works great. But I can never remember if "Turn on front door lock" unlocks the door or locks the door.
2) One way communication only. Alexa can control Indigo, but Indigo can't really control Alexa.
I have tried various approaches to using Airfoil on several devices to do announcements which have all been problematic. Alexa has this down, but it's hard to get her to make a custom announcement based off an indigo action. I currently have routines that listen for "Alpha, Bravo, Charlie, etc..." Each routine runs a unique announcement. So if my wife's code is used to unlock the front door, the Mac speaker next to my echo dot speaks "Alexa, run Bravo", then that routine is launched to welcome her / let everyone know Mom's home.
Hopefully, Alexa will expand to trigger routines off lights. Right now they only trigger off voice, schedule, echo button, location, and sensor devices (contact or motion).
I could hack a button and connect to an I/O device... but that would be one button and one I/O device per routine.
Bill
Thu Jun 06, 2019 7:34 am
siclark offline
Carl
That used to be the way you had to control harmony remotes but now you can drop that through use of scenes. Maybe we could do similar with indigo?
Thu Jun 06, 2019 9:33 am
There are 2 types of Alexa skills: smart home skills and custom skills. The former doesn't require a user to preface "tell Indigo" because once a full skill is available Alexa would just see an Indigo switch (for instance) as any other switch, so "turn on Living Room Lights" would get translated into the appropriate command to "Living Room Lights" which the Alexa would then dispatch to the skill that "owns" that device, in this case Indigo.
The custom skill would be necessary to implement stuff that's not defined by the smart home skills API - perhaps like speaking the value of a variable or executing an Action Group.
The good news is that Amazon recently started allowing a single skill to contain both of those types in the same skill. Before, you would have to installed 2 separate skills.
Also, yes, there are a couple of ways to help avoid the use of "tell Indigo" as well that are now part of the Alexa experience.
Thu Jun 06, 2019 10:10 am
racarter offline
Why not use an Alexa routine for this? I can say “Alexa, open the curtains” and that turns on an Indigo switch device via the Hue plugin.
Thu Jun 06, 2019 3:53 pm
whmoorejr offline
Because I'm an idiot and even though the answer has been sitting right in front of me, I never put that together until you said it. Thank you!!
Bill
Thu Jun 06, 2019 11:07 pm
RogueProeliator offline
So, simple, right? Have it by Sunday? :: ducks ::
Now all you need is the Indigo community to donate a $50k so you can contract that out and be done with it. LOL
