HKLS Startup Errors
Fri Jun 09, 2023 4:28 pm
papamac offline
HKLS Startup Errors
Recently, I started seeing HLKS "hap pair verify" errors at plugin startup. There is one of these for each of my 3 HLKS accessory servers. Nevertheless, my HKLS devices all seem to be functioning normally. The errors are shown below. They repeat exactly each time I reload HKLS.
 Reloading plugin "HomeKitLink Siri 0.6.5" using API v3.2
   Stopping plugin "HomeKitLink Siri 0.6.5" (pid 35933)
   HomeKitLink Siri                Stopping accessory HomeKitLink Bridge 124078 on address 10.10.10.82, port 51826.
   HomeKitLink Siri                Stopping accessory HomeKitLink Bridge 815295 on address 10.10.10.82, port 51828.
   HomeKitLink Siri                Stopping accessory HomeKitLink Bridge 131595 on address 10.10.10.82, port 51827.
   HomeKitLink Siri                Closed the flux capacitor loop.
   HomeKitLink Siri                Completing full Bridge Shutdown ...
   HomeKitLink Siri                home-cameras-hklsBridge has completed full Bridge, Driver and Bridge Thread Shutdown.
   HomeKitLink Siri                home-lights-hklsBridge has completed full Bridge, Driver and Bridge Thread Shutdown.
   HomeKitLink Siri                home-security-hklsBridge has completed full Bridge, Driver and Bridge Thread Shutdown.
   HomeKitLink Siri                Shutting down HomeKitLink
   Stopped plugin "HomeKitLink Siri 0.6.5"
   Starting plugin "HomeKitLink Siri 0.6.5" (pid 35994)
   HomeKitLink Siri
   HomeKitLink Siri                ================================================ Initializing New Plugin Session =================================================
   HomeKitLink Siri                Plugin name:                   HomeKitLink Siri
   HomeKitLink Siri                Plugin version:                0.6.5
   HomeKitLink Siri                Plugin ID:                     com.GlennNZ.indigoplugin.HomeKitLink-Siri
   HomeKitLink Siri                Indigo version:                2022.2.2
   HomeKitLink Siri                Python version:                3.10.2 (v3.10.2:a58ebcc701, Jan 13 2022, 14:50:16) [Clang 13.0.0 (clang-1300.0.29.30)]
   HomeKitLink Siri                Python Directory:              /Library/Frameworks/Python.framework/Versions/3.10
   HomeKitLink Siri
   HomeKitLink Siri                ================================================== End Initializing New Plugin  ==================================================
   Started plugin "HomeKitLink Siri 0.6.5"
   HomeKitLink Siri                Finding devices to publish to HomeKit Given Startup...
   HomeKitLink Siri                Starting accessory HomeKitLink Bridge 124078 on address 10.10.10.82, port 51826.
   HomeKitLink Siri Error          (hap_handler.py: Function: _pair_verify_two  line: 547):    Error :  Message : ('10.10.10.190', 49230): Client c34d094c-3d40-420d-b6ad-15c8f1a5bfae attempted pair verify without being paired to HomeKitLink Bridge 124078 first.
   HomeKitLink Siri                Camera Thread is being spooled up to manage camera images
   HomeKitLink Siri                Starting accessory HomeKitLink Bridge 131595 on address 10.10.10.82, port 51827.
   HomeKitLink Siri Error          (hap_handler.py: Function: _pair_verify_two  line: 547):    Error :  Message : ('10.10.10.190', 49231): Client c34d094c-3d40-420d-b6ad-15c8f1a5bfae attempted pair verify without being paired to HomeKitLink Bridge 131595 first.
   HomeKitLink Siri                Starting accessory HomeKitLink Bridge 815295 on address 10.10.10.82, port 51828.
   HomeKitLink Siri Error          (hap_handler.py: Function: _pair_verify_two  line: 547):    Error :  Message : ('10.10.10.190', 49232): Client c34d094c-3d40-420d-b6ad-15c8f1a5bfae attempted pair verify without being paired to HomeKitLink Bridge 815295 first.
   HomeKitLink Siri                A total of 80 devices are currently selected to be published to HomeKit
   HomeKitLink Siri                80 Home Kit Accessories are now Started..
For reference, the device cited in the message, "10.10.10.190", is an Apple TV. Doesn't make any sense to me.
Does anyone know what this error means? Should I investigate more? Since there are no apparent failures... do I care?
Thanks for your help,
papamac
Fri Jun 09, 2023 4:29 pm
GlennNZ offline
HKLS Startup Errors
Covered here in the troubleshooting page:
viewtopic.php?t=27136
& discussed:here:
viewtopic.php?t=27199
viewtopic.php?f=366&t=27213
https://github.com/Ghawken/HomeKitLink-Siri/issues/28
&& probably elsewhere that have forgotten.
Your Client 10.10.10.190 - has failed upgrading to OS 16.4, OR is incompatible with OS 16.5.
Glenn
Fri Jun 09, 2023 4:33 pm
papamac offline
Re: HKLS Startup Errors
Thanks Glenn. Silly me... I need to read your posts before I post.
Sorry about that,
David
Sat Jun 10, 2023 12:43 am
GlennNZ offline
Sorry about that,
David
