RESTFUL Api Issues
Sat Nov 14, 2015 3:58 pm
nanobots offline
RESTFUL Api Issues
Hello,
Are there any known bugs with the current version of the Indigo 6.1.4 and the RESTFUL apis? I'm having several issues and can't figure out what's going on.
1. Indigo Touch reports all devices are either "Plugin not installed" or "interface disabled" even though things are working fine through the remote connection on my laptop
2. When I visit the RESTFUL apis (http://<IP>/devices/X.json), I'm not being prompted for credentials, even after clearing saved creds out, using an incognito window, using CURL from the command line etc.
3. The device list (http://10.0.0.7:8176/controlpage?name=_ ... useJS=True)/control pages aren't working. They display the status of things fine, but if I click any links to change the status of a devices (i.e. turn a lamp off) it doesn't work. Looking at the server response, I'm getting redirected:
HTTP/1.1 303 See Other
Content-Length: 124
Vary: Accept-Encoding
Server: IndigoWebServer/5.0
Allow: GET, HEAD, POST, PUT
Date: Sat, 14 Nov 2015 21:54:40 GMT
Content-Type: text/html;charset=utf-8
This resource can be found at <a href='http://10.0.0.6:8176/devices/Hall Light'>http://10.0.0.6:8176/devices/Hall Light</a>.
4. A script that I've used in the past to authenticate to the server and update devices using the restful urls is no longer working. Specifically it's failing when attempting to authenticate using digest authentication saying the server is not returning the authentication header. It appears I'm getting the same redirect response as above.
5. Also have tried the curl commands from the wiki. Example:
curl -u user:password --digest -X PUT -d isOn=0 "http://10.0.0.6:8176/devices/Hall%20KPL"
This is also causing a redirection:
This resource can be found at <a href='http://10.0.0.6:8176/devices/Hall KPL'>http://10.0.0.6:8176/devices/Hall KPL</a>.
I've tried restarting the server several times. Also tried removing the authentication credentials, putting them back in, and restarting the server again. Hasn't seemed to do anything.
Sat Nov 14, 2015 4:16 pm
webdeck offline
Re: RESTFUL Api Issues
Sorry to jump onboard your thread, but there's another issue with the RESTful API I wanted to add, as I had to work around it for my Amazon Echo integration. It doesn't support the standard URL encoding of using a plus sign to replace a space. So, even though "http://xxx.xxx.xxx.xxx/devices/Kitchen+Light.json" is a valid URL encoding , it doesn't work. You have to use %20 to represent spaces ("http://xxx.xxx.xxx.xxx/devices/Kitchen%20Light.json") It would be nice if they both worked.
-Mike
Mon Nov 16, 2015 11:49 am
There are a few JSON encoding bugs, but other than that none that we know of.
Are you sure Indigo Touch isn't connecting to a different Indigo Server on a different Mac? If Indigo Touch is showing those two things, that's what the Indigo Server it's connected to is telling it. In the Mac client, they would also show up in red with the same error in the status column. If not, then the only explanation I can think of is that Indigo Touch is connecting to a different server. Remember that Indigo is a client-server app, so the server can be running as a background process without the UI.
Again, make sure you're connecting to the right server. If you have authentication turned on in the Start Local Server dialog, then it will always perform digest authentication.
Yet another clue that you're pointing to the wrong server somehow.
Ditto. I'm pretty sure multiple servers is your issue.
Mon Nov 16, 2015 11:58 am
-Mike
The general rule is that form data is encoded using either %20 or "+" and URLs (as specified in RFC 1738) are encoded with %20. The query component of a URL (after the ?) can contain either as it's analogous to form data but technically the path portion should use %20.
Mon Nov 16, 2015 11:52 pm
webdeck offline
jay (support) wrote:
-Mike
I learned something new! I didn't realize that the plus sign convention was specific to application/x-www-form-urlencoded. Thanks!
-Mike
Tue Nov 17, 2015 12:36 pm
nanobots offline
Thanks Jay, totally right. Somehow I got a server started on my laptop and was pointing to that.
