Config up pane size
Sun Sep 01, 2019 12:06 pm
berkinet offline
Config up pane size
Is there anyway to force the size of a ConfigUI pane? I have a Menuitem UI that has only one visible entry when it opens, then after a button is pressed, more fields become visible. The only problem is the pane is sized for the initial one menu item, one button display and when the hidden fields become visible, the pane must be dragged larger.
I could just start with all the fields visible, they are empty and readonly and the pane will size correctly. Except, the checkboxes are "writeable" and imply they can somehow be used. I can disable them, but at the cost of graying out their labels. No huge deal, just having fun and trying to push the envelope a bit I guess.
Sun Sep 01, 2019 12:16 pm
berkinet offline
Re: Config UI pane size
To illustrate...
Screen Shot 2019-09-01 at 20.12.38.png (103.59 KiB) Viewed 1666 times
Screen Shot 2019-09-01 at 20.12.46.png (114.11 KiB) Viewed 1666 times
Sun Sep 01, 2019 1:53 pm
Re: Config up pane size
Set the alwaysUseInDialogHeightCalc attribute on your invisible controls:
alwaysUseInDialogHeightCalc="true"
Sun Sep 01, 2019 2:35 pm
berkinet offline
:D Thanks
Wed Sep 04, 2019 6:03 am
Nice. I didn't know about that one.
Mon Mar 13, 2023 3:21 am
GlennNZ offline
Hi all,
Can we add this to the documentation - couldn't seem to find it there and took this search. to find something thought existed
Mon Mar 13, 2023 5:26 am
