Is there anyway to force the size of a ConfigUI pane? I have a Menuitem UI that has only one visible entry when it opens, then after a button is pressed, more fields become visible. The only problem is the pane is sized for the initial one menu item, one button display and when the hidden fields become visible, the pane must be dragged larger.
I could just start with all the fields visible, they are empty and readonly and the pane will size correctly. Except, the checkboxes are "writeable" and imply they can somehow be used. I can disable them, but at the cost of graying out their labels. No huge deal, just having fun and trying to push the envelope a bit I guess.
