Python 2.7 TLS Broken on GitHub? [solved]
Sat Feb 03, 2018 9:29 am
I have been using the excellent IndigoPluginUpdateChecker module in my plugins and have not had any issues until now. GitHub is apparently not happy with the urllib2 call under TLS:
urllib2.URLError: <urlopen error [SSL: TLSV1_ALERT_PROTOCOL_VERSION] tlsv1 alert protocol version (_ssl.c:590)>
  • Tried the requests library in addition to urllib2 with the same result, in addition to running a simple attempt with a short script written from scratch (the page loads just fine in Safari).
  • Tried with both https:// and http://.
  • Running a straight call to the Weather Underground API works as expected.
  • Tried overcoming with Dropbox and Box but neither serve up .html files cleanly.
I wonder if a recent Apple security update might not have something to do with it.... Any suggestions to overcome this limitation until we can do update checking through the Indigo Plugin Store?
Sat Feb 03, 2018 10:22 am
Re: Python 2.7 TLS Broken on GitHub?
Sent you a PM. Thanks for looking into this!
Sun Feb 04, 2018 6:38 am
Thanks to @Ianbrown who suggested I try curl, looks like I have a solution. This is tailored to my situation which uses GitHub to serve the file necessary for the IndigoPluginUpdateChecker() module to do its thing. Note the 'raw' in the URL--this is the path that serves the file without any html formatting or other stuff.
My URL for reaching out to GitHub (goes in plugin.py):
url = 'https://raw.githubusercontent.com/USERNAME/REPO_NAME/master/FILENAME.html'
The changes I made to Travis' indigoPluginUpdateChecker() module
import subprocess
# Replace this:
f = urlopen(self.fileUrl)
# With this:
f = subprocess.Popen(["curl", "-k", self.fileUrl], stdout=subprocess.PIPE, stderr=subprocess.PIPE, shell=False)
out, err = f.communicate()
# and replace this:
lines = f.read().split('\n')
# With This:
lines = out.split('\n')
Could also modify the code to use 'err', but I didn't feel it was needed.
Sun Feb 04, 2018 9:24 am
Re: Python 2.7 TLS Broken on GitHub? [solved]
I have the same problem. There is a way to update openssl but it requires to reboot in recovery mode then replace the lib and reboot again. If you have a published plugin that will likely not work for the users. Hence I have switched to curl. Does the trick but you need to understand how to use the security cookies. See the other thread
Karl.
Sun Feb 04, 2018 12:19 pm
Thanks all. I reread my post above and edited to be more clear. I said it was tailored to my purpose, but that was really only referring to the target URL.
Sun Feb 04, 2018 12:42 pm
If you are connecting to GitHub to do version checking I'd recommend not wasting your time with other solutions. We'll have an API for checking versions on the plugin store pretty soon.
Sun Feb 04, 2018 5:13 pm
I hope in the next week or so.
Mon Feb 05, 2018 6:58 am
The solution above seems to be working well. I plan to switch my plugins to the upcoming Indigo Plugin Store version tracking system when it becomes available, but until then, it seems that this will do the trick.
Tue Feb 20, 2018 5:56 pm
Thu Feb 22, 2018 7:02 pm
GlennNZ offline
Thanks Dave for the pointers
For those using the ghpu.py update code, the following change to curl works
Changed _Get Def
   def _GET(self, requestPath):
      self.logger.debug('GET %s' % requestPath)
      headers = {
         'User-Agent': 'Indigo-Plugin-Updater',
         'Accept': 'application/vnd.github.v3+json'
      data = None
      requestPath = 'https://api.github.com'+ requestPath
      #conn = httplib.HTTPSConnection('api.github.com')
      #conn.request('GET', requestPath, None, headers)
      #resp = conn.getresponse()
      f = subprocess.Popen(["curl",  requestPath], stdout=subprocess.PIPE, stderr=subprocess.PIPE, shell=False)
   #'-H', str(headers), "-k",
      self.logger.debug(u'HTTP Err result:'+unicode(err) )
      self.logger.debug(u'ReturnCode:{0}'.format(unicode(f.returncode)))
      #self.sleep(1)
      if (int(f.returncode) == 0):
         data = json.loads(out)
         self.logger.debug(u'Json results:'+unicode(data))
      elif (400 <= f.status < 500):
         error = json.loads(out)
         self.logger.error('%s' % error['message'])
         self.logger.error('Error: %s' % unicode(err))
      return data
Thu Feb 22, 2018 7:52 pm
Cheers!
Thu Mar 01, 2018 10:03 pm
kmarkley offline
The fix above fixes ghpu.py checking for releases, but not installing them. The method _getZipFileFromRelease also needs to be converted to curl for a full solution:
    def _getZipFileFromRelease(self, release):
        # download and verify zipfile from the release package
        zipball = release.get('zipball_url', None)
        if (zipball == None):
            raise Exception('Invalid release package: no zipball')
        self._debug('Downloading zip file: %s' % zipball)
        # zipdata = urlopen(zipball).read()
        f = subprocess.Popen(["curl", "-L",  zipball], stdout=subprocess.PIPE, stderr=subprocess.PIPE, shell=False)
        zipdata, err = f.communicate()
        self._debug(u'HTTP Err result:'+unicode(err) )
        self._debug(u'ReturnCode:{0}'.format(unicode(f.returncode)))
        zipfile = ZipFile(StringIO(zipdata))
        self._debug('Verifying zip file (%d bytes)...' % len(zipdata))
        if (zipfile.testzip() != None):
            raise Exception('Download corrupted')
        return zipfile
