Hue Lights discussion
Tue May 29, 2018 2:33 pm
Re: Hue Lights discussion
Updated my Hue app to v 3.0 today and no problems. But then, it didn't say anything about changing hub software anyway.
Wed May 30, 2018 11:54 am
https://home.woot.com/plus/smart-home?r ... _hm_2_wp_1 has Hue stuff, mostly refurb, on sale for OK prices.
Wed May 30, 2018 11:58 am
akimball offline
Different Computers wrote:
https://home.woot.com/plus/smart-home?ref=w_gh_hm_2_wp_1 has Hue stuff, mostly refurb, on sale for OK prices.
Careful...all gen2. Noting that the g10 bulbs have no gen3 version yet. After seeing the green greens, and the blue blue’s of the gen3 you’ll never want gen2.
-Al
Tue Jun 12, 2018 6:55 am
jaga01 offline
New INNR Smart Plug compatiility. Hi - I have just bought the new INNR Smart Plug. It shows up in The HUE app and I can controll it. But is it possible to have it integrated in the plugin, so that I can control it from Indigo?
Regards, Jacob
Wed Jun 13, 2018 10:49 pm
nsheldon offline
Hi Jacob.
Does the INNR Smart Plug show up as a light in the Hue app or something else? If it shows up as a light, it can probably be supported in the Hue Lights plugin. I just need the exact model ID for that device. You can probably get the model ID from the Hue app if you touch the "Settings" option at the bottom of the Hue app, then go to "Light setup" and touch the "i" icon to the right of the device in the lights list. It should show "Model" then some text. I need that in order to add lighting support in the Hue Lights plugin. I'm assuming the INNR Smart Plug is just a dimmable outlet right?
Thu Jun 14, 2018 9:04 am
jaga01 offline
Hi nsheldon,
Thanks for your answer. The INNR Smart Plug shows up as a On/Off plug: the model is empty but sw says 20.
On the PowerPlug itself it says:
SP120 T25
And lastly. www.innr.com
1817-4
It seems that I am not able to attach pictures as they always get to big.
It is super if you can ad it.
Thanks in advance.
Regards, Jacob
Thu Jun 14, 2018 9:14 am
jaga01 offline
Here is a picture of the HUE App where INNR is:
IMG_0005 2.PNG (111.34 KiB) Viewed 831 times
Thu Jun 14, 2018 11:20 am
nsheldon offline
Hmm. The Hue Lights plugin requires a model ID in order to know what kinds of messages to send to it. Maybe you could get some debug logs that I can look through to see if I can find an ID to use. Enable debug logging by going to the Plugins menu then Hue Lights then Toggle Debug Logging then reload the plugin (Plugins -> Hue Lights -> Reload). Paste the entire log from the reload.
Fri Jun 15, 2018 4:49 am
shapa offline
Could you please add Ikea Tradfri lighting panel support?
https://www.ikea.com/gb/en/products/lig ... -40332210/
Hue app identified it as a "Color temperature light"
From the plugin debug log:
u'type': u'Extended color light', u'modelid': u'LST002'}, u'17': {u'swversion': u'1.2.217', u'name': u'Garage Panel', u'swupdate': {u'state': u'notupdatable', u'lastinstall': None}, u'uniqueid': u'90:fd:9f:ff:fe:87:00:52-01', u'capabilities': {u'control': {u'ct': {u'max': 454, u'min': 250}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 322}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Color temperature light', u'modelid': u'FLOALT panel WS 30x90'},
Fri Jun 15, 2018 1:08 pm
jaga01 offline
Here is the logging. It seems it keeps repeating. Hope i got it all: regards Jacob
*************************************Log*****************
Hue Lights Debug Starting parseAllHueLightsData.
Hue Lights Debug parseAllHueLightsData: There are 14 lights on the Hue bridge and 10 Indigo devices controlling Hue devices.
Hue Lights Debug Starting updateGroupsList.
Hue Lights Debug Sending command to hub: http://192.168.0.42/api/2unjF08mW5wEhjW ... aQ3/groups
Hue Lights Debug Got response {u'11': {u'name': u'hgrp-0000131040', u'lights': [u'7', u'15', u'5', u'12', u'9', u'6', u'10', u'8', u'16', u'14', u'13', u'11'], u'state': {u'any_on': True, u'all_on': False}, u'recycle': False, u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4573, 0.41], u'bri': 1, u'ct': 366, u'sat': 140}}, u'10': {u'name': u'hgrp-0000032736', u'lights': [u'7', u'5', u'12', u'6', u'9', u'8', u'14', u'10', u'13', u'11'], u'state': {u'any_on': True, u'all_on': False}, u'recycle': False, u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4573, 0.41], u'bri': 1, u'ct': 366, u'sat': 140}}, u'1': {u'name': u'Entrance', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'type': u'Room', u'class': u'Front door'}, u'3': {u'name': u'Bio', u'lights': [u'7', u'8', u'9', u'16'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4578, 0.41], u'bri': 254, u'ct': 367, u'sat': 0}, u'recycle': False, u'type': u'Room', u'class': u'Recreation'}, u'2': {u'name': u'Spisestue', u'lights': [u'12', u'13'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 0, u'alert': u'none'}, u'recycle': False, u'type': u'Room', u'class': u'Dining'}, u'5': {u'name': u'Stue', u'lights': [u'6', u'5', u'19'], u'state': {u'any_on': True, u'all_on': False}, u'action': {u'on': True, u'hue': 8418, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 254, u'ct': 366, u'sat': 140}, u'recycle': False, u'type': u'Room', u'class': u'Living room'}, u'4': {u'name': u'hgrp-0000016352', u'lights': [u'7', u'5', u'12', u'6', u'8', u'9', u'10', u'13', u'11'], u'state': {u'any_on': True, u'all_on': False}, u'recycle': False, u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4573, 0.41], u'bri': 1, u'ct': 366, u'sat': 140}}, u'7': {u'name': u'Entre', u'lights': [u'10', u'11'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4573, 0.41], u'bri': 1, u'ct': 366, u'sat': 140}, u'recycle': False, u'type': u'Room', u'class': u'Hallway'}, u'6': {u'name': u'hgrp-0000000046', u'lights': [u'5'], u'state': {u'any_on': True, u'all_on': True}, u'recycle': False, u'type': u'LightGroup', u'action': {u'on': True, u'bri': 254, u'alert': u'none'}}, u'9': {u'name': u'hgrp-0000000896', u'lights': [u'7', u'8', u'9'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4575, 0.4099], u'bri': 254, u'ct': 366, u'sat': 140}}, u'8': {u'name': u'BasementOffice', u'lights': [u'14', u'15'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 254, u'alert': u'none'}, u'recycle': False, u'type': u'Room', u'class': u'Office'}}
Hue Lights Debug Loaded groups list - {u'11': {u'name': u'hgrp-0000131040', u'lights': [u'7', u'15', u'5', u'12', u'9', u'6', u'10', u'8', u'16', u'14', u'13', u'11'], u'state': {u'any_on': True, u'all_on': False}, u'recycle': False, u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4573, 0.41], u'bri': 1, u'ct': 366, u'sat': 140}}, u'10': {u'name': u'hgrp-0000032736', u'lights': [u'7', u'5', u'12', u'6', u'9', u'8', u'14', u'10', u'13', u'11'], u'state': {u'any_on': True, u'all_on': False}, u'recycle': False, u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4573, 0.41], u'bri': 1, u'ct': 366, u'sat': 140}}, u'1': {u'name': u'Entrance', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'type': u'Room', u'class': u'Front door'}, u'3': {u'name': u'Bio', u'lights': [u'7', u'8', u'9', u'16'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4578, 0.41], u'bri': 254, u'ct': 367, u'sat': 0}, u'recycle': False, u'type': u'Room', u'class': u'Recreation'}, u'2': {u'name': u'Spisestue', u'lights': [u'12', u'13'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 0, u'alert': u'none'}, u'recycle': False, u'type': u'Room', u'class': u'Dining'}, u'5': {u'name': u'Stue', u'lights': [u'6', u'5', u'19'], u'state': {u'any_on': True, u'all_on': False}, u'action': {u'on': True, u'hue': 8418, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 254, u'ct': 366, u'sat': 140}, u'recycle': False, u'type': u'Room', u'class': u'Living room'}, u'4': {u'name': u'hgrp-0000016352', u'lights': [u'7', u'5', u'12', u'6', u'8', u'9', u'10', u'13', u'11'], u'state': {u'any_on': True, u'all_on': False}, u'recycle': False, u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4573, 0.41], u'bri': 1, u'ct': 366, u'sat': 140}}, u'7': {u'name': u'Entre', u'lights': [u'10', u'11'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4573, 0.41], u'bri': 1, u'ct': 366, u'sat': 140}, u'recycle': False, u'type': u'Room', u'class': u'Hallway'}, u'6': {u'name': u'hgrp-0000000046', u'lights': [u'5'], u'state': {u'any_on': True, u'all_on': True}, u'recycle': False, u'type': u'LightGroup', u'action': {u'on': True, u'bri': 254, u'alert': u'none'}}, u'9': {u'name': u'hgrp-0000000896', u'lights': [u'7', u'8', u'9'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'type': u'LightGroup', u'action': {u'on': False, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4575, 0.4099], u'bri': 254, u'ct': 366, u'sat': 140}}, u'8': {u'name': u'BasementOffice', u'lights': [u'14', u'15'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 254, u'alert': u'none'}, u'recycle': False, u'type': u'Room', u'class': u'Office'}}
Hue Lights Debug Starting parseAllHueGroupsData.
Hue Lights Debug Starting updateSensorsList.
Hue Lights Debug Starting parseAllHueSensorsData.
Hue Lights Debug Starting updateLightsList.
Hue Lights Debug Sending command to hub: http://192.168.0.42/api/2unjF08mW5wEhjW ... aQ3/lights
Hue Lights Debug Got response {u'11': {u'swversion': u'1.29.0_r21169', u'name': u'Welcome red', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-11-29T13:50:45'}, u'productid': u'Philips-LCT012-1-E14ECLv1', u'uniqueid': u'00:17:88:01:02:62:4b:49-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 2000, u'maxlumen': 450, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color candle', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 366, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'EA9279F9', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'candlebulb'}, u'type': u'Extended color light', u'modelid': u'LCT012'}, u'10': {u'swversion': u'1.29.0_r21169', u'name': u'Welcome white', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-11-29T13:50:42'}, u'productid': u'Philips-LTW012-1-E14CTv1', u'uniqueid': u'00:17:88:01:02:1d:15:19-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 450, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance candle', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'none', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 366}, u'manufacturername': u'Philips', u'swconfigid': u'301F302C', u'config': {u'function': u'decorative', u'direction': u'omnidirectional', u'archetype': u'candlebulb'}, u'type': u'Color temperature light', u'modelid': u'LTW012'}, u'13': {u'swversion': u'5.38.2.19136', u'name': u'Starck 2', u'swupdate': {u'state': u'transferring', u'lastinstall': None}, u'uniqueid': u'00:17:88:01:00:e4:8c:74-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 750}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': False, u'mode': u'homeautomation', u'bri': 0, u'alert': u'none'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'12': {u'swversion': u'5.38.2.19136', u'name': u'Starck 1', u'swupdate': {u'state': u'transferring', u'lastinstall': None}, u'uniqueid': u'00:17:88:01:00:e4:6c:8b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 750}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': False, u'mode': u'homeautomation', u'bri': 0, u'alert': u'none'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'15': {u'swversion': u'5.105.0.21169', u'name': u'Basement', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-11-29T13:50:59'}, u'uniqueid': u'00:17:88:01:10:58:4f:18-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'none'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'14': {u'swversion': u'5.105.0.21169', u'name': u'Huebasoffe1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-11-29T13:51:02'}, u'uniqueid': u'00:17:88:01:10:58:35:45-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'16': {u'swversion': u'1.29.0_r21169', u'name': u'Hue lightstrip plus 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-11-29T13:51:43'}, u'productid': u'Philips-LST002-1-LedStripsv3', u'uniqueid': u'00:17:88:01:02:9d:5a:5c-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 0, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4578, 0.41], u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 367, u'sat': 0}, u'manufacturername': u'Philips', u'swconfigid': u'0612AD68', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'19': {u'swversion': u'2.0', u'name': u'On/Off plug 1', u'swupdate': {u'state': u'notupdatable', u'lastinstall': None}, u'uniqueid': u'00:15:8d:00:02:17:87:7b-01', u'capabilities': {u'control': {}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'On/Off plug', u'state': {u'on': True, u'reachable': False, u'mode': u'homeautomation', u'alert': u'select'}, u'manufacturername': u'innr', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'On/Off plug-in unit', u'modelid': u'SP 120'}, u'18': {u'swversion': u'1.15.2_r19181', u'name': u'Hue ambiance candle 1', u'swupdate': {u'state': u'transferring', u'lastinstall': None}, u'productid': u'Philips-LTW012-1-E14CTv1', u'uniqueid': u'00:17:88:01:02:9b:6a:37-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 450, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance candle', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 366}, u'manufacturername': u'Philips', u'swconfigid': u'FEC1005F', u'config': {u'function': u'decorative', u'direction': u'omnidirectional', u'archetype': u'candlebulb'}, u'type': u'Color temperature light', u'modelid': u'LTW012'}, u'5': {u'swversion': u'5.105.0.21169', u'name': u'PH', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-11-29T13:51:05'}, u'uniqueid': u'00:17:88:01:10:58:34:65-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'none'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'7': {u'swversion': u'1.29.0_r21169', u'name': u'Sofa', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-11-29T13:50:40'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:3d:62:f0-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4575, 0.4099], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'6A139B19', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'6': {u'swversion': u'1.29.0_r21169', u'name': u'B', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-11-29T13:50:37'}, u'productid': u'Philips-LCT012-1-E14ECLv1', u'uniqueid': u'00:17:88:01:02:1c:36:58-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 2000, u'maxlumen': 450, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color candle', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 366, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'EA9279F9', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'candlebulb'}, u'type': u'Extended color light', u'modelid': u'LCT012'}, u'9': {u'swversion': u'1.29.0_r21169', u'name': u'Papir 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-11-29T13:50:48'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:3d:6a:df-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4575, 0.4099], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'6A139B19', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'8': {u'swversion': u'1.29.0_r21169', u'name': u'Papir 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-11-29T13:50:50'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:47:72:db-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4575, 0.4099], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'6A139B19', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}}
Hue Lights Debug Loaded lights list - {u'11': {u'swversion': u'1.29.0_r21169', u'name': u'Welcome red', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-11-29T13:50:45'}, u'productid': u'Philips-LCT012-1-E14ECLv1', u'uniqueid': u'00:17:88:01:02:62:4b:49-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 2000, u'maxlumen': 450, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color candle', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 366, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'EA9279F9', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'candlebulb'}, u'type': u'Extended color light', u'modelid': u'LCT012'}, u'10': {u'swversion': u'1.29.0_r21169', u'name': u'Welcome white', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-11-29T13:50:42'}, u'productid': u'Philips-LTW012-1-E14CTv1', u'uniqueid': u'00:17:88:01:02:1d:15:19-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 450, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance candle', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'none', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 366}, u'manufacturername': u'Philips', u'swconfigid': u'301F302C', u'config': {u'function': u'decorative', u'direction': u'omnidirectional', u'archetype': u'candlebulb'}, u'type': u'Color temperature light', u'modelid': u'LTW012'}, u'13': {u'swversion': u'5.38.2.19136', u'name': u'Starck 2', u'swupdate': {u'state': u'transferring', u'lastinstall': None}, u'uniqueid': u'00:17:88:01:00:e4:8c:74-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 750}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': False, u'mode': u'homeautomation', u'bri': 0, u'alert': u'none'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'12': {u'swversion': u'5.38.2.19136', u'name': u'Starck 1', u'swupdate': {u'state': u'transferring', u'lastinstall': None}, u'uniqueid': u'00:17:88:01:00:e4:6c:8b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 750}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': False, u'mode': u'homeautomation', u'bri': 0, u'alert': u'none'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'15': {u'swversion': u'5.105.0.21169', u'name': u'Basement', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-11-29T13:50:59'}, u'uniqueid': u'00:17:88:01:10:58:4f:18-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'none'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'14': {u'swversion': u'5.105.0.21169', u'name': u'Huebasoffe1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-11-29T13:51:02'}, u'uniqueid': u'00:17:88:01:10:58:35:45-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'16': {u'swversion': u'1.29.0_r21169', u'name': u'Hue lightstrip plus 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-11-29T13:51:43'}, u'productid': u'Philips-LST002-1-LedStripsv3', u'uniqueid': u'00:17:88:01:02:9d:5a:5c-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 0, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4578, 0.41], u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 367, u'sat': 0}, u'manufacturername': u'Philips', u'swconfigid': u'0612AD68', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'19': {u'swversion': u'2.0', u'name': u'On/Off plug 1', u'swupdate': {u'state': u'notupdatable', u'lastinstall': None}, u'uniqueid': u'00:15:8d:00:02:17:87:7b-01', u'capabilities': {u'control': {}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'On/Off plug', u'state': {u'on': True, u'reachable': False, u'mode': u'homeautomation', u'alert': u'select'}, u'manufacturername': u'innr', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'On/Off plug-in unit', u'modelid': u'SP 120'}, u'18': {u'swversion': u'1.15.2_r19181', u'name': u'Hue ambiance candle 1', u'swupdate': {u'state': u'transferring', u'lastinstall': None}, u'productid': u'Philips-LTW012-1-E14CTv1', u'uniqueid': u'00:17:88:01:02:9b:6a:37-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 450, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance candle', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 366}, u'manufacturername': u'Philips', u'swconfigid': u'FEC1005F', u'config': {u'function': u'decorative', u'direction': u'omnidirectional', u'archetype': u'candlebulb'}, u'type': u'Color temperature light', u'modelid': u'LTW012'}, u'5': {u'swversion': u'5.105.0.21169', u'name': u'PH', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-11-29T13:51:05'}, u'uniqueid': u'00:17:88:01:10:58:34:65-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'none'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'7': {u'swversion': u'1.29.0_r21169', u'name': u'Sofa', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-11-29T13:50:40'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:3d:62:f0-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4575, 0.4099], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'6A139B19', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'6': {u'swversion': u'1.29.0_r21169', u'name': u'B', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-11-29T13:50:37'}, u'productid': u'Philips-LCT012-1-E14ECLv1', u'uniqueid': u'00:17:88:01:02:1c:36:58-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 2000, u'maxlumen': 450, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color candle', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 366, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'EA9279F9', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'candlebulb'}, u'type': u'Extended color light', u'modelid': u'LCT012'}, u'9': {u'swversion': u'1.29.0_r21169', u'name': u'Papir 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-11-29T13:50:48'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:3d:6a:df-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4575, 0.4099], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'6A139B19', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'8': {u'swversion': u'1.29.0_r21169', u'name': u'Papir 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-11-29T13:50:50'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:47:72:db-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4575, 0.4099], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'6A139B19', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}}
****************end log***************************
Fri Jun 15, 2018 1:23 pm
akimball offline
I can’t wait for the hue outdoor garden lights coming mid july. Hope these will be supported.
https://www2.meethue.com/en-us/p/hue-wh ... ody___img1
https://www2.meethue.com/en-us/p/hue-wh ... ody___cta2
Defintely going to need a new bridge soon. It looks like the lights will be gen3...great colours. I’ve quite a few outdoor hues already on the house, on the porches, and in my columns. They are not really rated for outdoors but so far, so good. My landscape lights are the last stray dog. I’m guessing sale prices for these new units will be closer to 50/100 USD respectively.
-Al
Sat Jun 16, 2018 11:20 am
petematheson offline
Hiya,
Just upgraded to the latest version and I can't add a new hue Bloom.
When I click Save I get this in the log:
Hue Lights Error Error in plugin execution UiValidate:
File "plugin.py", line 773, in validateDeviceConfigUi
UnicodeDecodeError: 'ascii' codec can't decode byte 0xe2 in position 262: ordinal not in range(128)
Sat Jun 16, 2018 11:30 am
Ah sorted this one - it was because it was called Harvey's Room and not Harveys Room (doesn't like the ' in the name?)
Quick question.
Is there any way of starting routines via Indigo?
I have the 30 minutes 'go to sleep' routing that sets the light colour and dims it over 30 minutes. Would be nice to trigger from a switch.
Mon Jun 18, 2018 3:01 am
nsheldon offline
Version 1.6.13 Posted
  • Added support for the Innr SP 120 On/Off Plugin module.
  • Added support for the IKEA 30x90 color temperature LED panel.
Mon Jun 18, 2018 3:03 am
nsheldon offline
Hi.
No. Sorry. There's no way to directly trigger any Hue routines from Indigo. If you can configure a routine to monitor the condition of a specific bulb and trigger only when that bulb becomes set to a specific color and/or brightness, that might work as a workaround, but otherwise, no. Sorry.
Page 58 of 65 1 ... 55, 56, 57, 58, 59, 60, 61 ... 65
