Autelis Jandy
Sat Aug 04, 2012 10:24 am
nlagaros offline
Autelis Jandy
Autelis Jandy v1.2.0
Download plugin here: https://vulture.lagaros.com/wiki/projec ... ation.html
Autelis Pool Control for Jandy®/Zodiac® is designed to interface to your existing Aqualink® system. It will enable you to control your pool equipment from any web browser, by using the built-in mobile web app which is compatible with iPhone, iPad, and Android, or through integration with your existing home automation system.
Documentation on actions to come...
Sun May 26, 2013 5:57 am
nlagaros offline
Autelis Jandy v1.2.0 Update
Pool season is open! I've started on some improvements to the Autelis Jandy plugin. Thanks to the Autelis team, keypad updates are now sent as updates on the TCP stream. This means that we can create actions that are a combination of physical keypad button presses. This is somewhat arcane, but Jandy does not provide any direct command control for some of their other devices.
I started with AquaPure support, and will move in to variable speed pumps. I'd love to work with anyone who wants support for other equipment. Please send me screenshots, keypad sequences, and desired actions.
This version requires v1.5.4 of the Autelis firmware. Also, please update the plugin configuration. There are additional items to check. For now, ignore the UDP options - they are not used yet.
v1.2.0 - 05/26/2013
  • Added support for keypad updates (requires v1.5.4 or Autelis TCP firmware)
  • Added AquaPure actions (set, boost)
  • Additional states:
    • KP_00 -> KP_11 : mimics physical keypad display
    • AP_STATUS : AquaPure Status (on, off, boost)
    • AP_SET : AquaPure Production Setting
    • AP_SALT : Salt Concentration in PPM
Mon May 27, 2013 3:06 am
nlagaros offline
Re: Autelis Jandy
v1.2.1 - 05/27/2013
  • Corrected socket logic on closeConnection()
  • Changed socket timeout to 0.25 sec
Sun Jun 02, 2013 5:50 am
nlagaros offline
Re: Autelis Jandy
v1.2.3 - 06/02/2013
  • Added Keypad actions (Page Up, Page Dn, Back, Select, Up, Down)
v1.2.2 - 06/01/2013
  • Added device configuration (not necessary to fill out)
  • Basic support for Jandy variable speed ePump
    • P1_NAME: name of VSP 1
    • P1_RPM: speed of VSP 1
    • P1_STATUS: running status of VSP 1
    • P1_WATTS: power of VSP 1
  • Bug Fix - corrected action for Pool Cleaner Toggle
Sun Jun 02, 2013 2:16 pm
nlagaros offline
Re: Autelis Jandy
v1.2.4 - 06/02/2013
  • Refined special character identification in keypad states
  • Added [] for highlighting current keypad line
Sat Jun 08, 2013 3:42 pm
nlagaros offline
Re: Autelis Jandy
v1.2.5 - 06/09/2013
  • Added support for setting variable speed pump (must configure with AquaLink speed labels)
  • Beginning support for Jandy LED Color Lights
Sun Jun 09, 2013 3:20 am
nlagaros offline
Re: Autelis Jandy
v1.2.6 - 06/10/2013
  • Bug Fix - correction variable speed pump settings
  • Added action to set Jandy LED Color Lights (must configure with LED Aux Device)
Mon Dec 30, 2013 3:21 am
nlagaros offline
Autelis Jandy Update v1.2.9
v1.2.9 - 12/30/2013
  • Added Plugin Update Checker Module developed by travisc. Thank you Travis!
v1.2.8.7 - 07/25/2013
  • Bug fixes for Jandy LED Color Lights
  • Bug fixes for AquaPure SWG
  • Bug fixes for Jandy ePump
