ad2usb plugin discussion
Mon Jul 30, 2018 8:14 am
ELWOOD offline
Re: ad2usb plugin discussion
If you are looking to have perimeter PIR sensors that trigger events and notifications only. You can add any wireless sensor to the plugin but you don't need to have it programed into the alarm panel. I have a few outdoor wireless PIR's that control lights and notify on any one moving around outside. Just add a new device type "alarm zone" enter it's serial number and loop number. Now the alarm panel does not see the sensor but the plugin does. Set up a trigger to fire any time the device state changes.
Elwood
Sun Aug 12, 2018 8:04 am
hamw offline
Thanks for the tip. Do you include the a in front of the wireless number as well as the dash in the middle? For a standard 5800 PIR it would be a loop one?
The plug-in is working in basic mode. I tried adding some relay boards and assigning the zones to the different relays in sequence, then tried adding emulator boards and assigning the zones to the different emulator board spots. The zones don’t register or clear. Not sure I can operate this 20se in advanced mode? So am I out of luck getting the wireless sensors to work if it won’t operate in advanced mode? Or is there something I’m doing wrong?
Sun Aug 12, 2018 9:13 am
ELWOOD offline
Hi hamw
I am running a vista 128 panel in advanced mode. I think your vista 20se should work with wireless in basic mode. I have included a screen
shot of the setup for one of my outdoor wireless motion detectors. The only difference for your setup is the zone number. With the 20se
you need to enter only 2 digits for the zone number. Also this wireless zone is not programed into the vista128 panel.
Elwood
Screen Shot 2018-08-12 at 10.54.37 AM.png (425.26 KiB) Viewed 977 times
Thu Aug 16, 2018 8:05 am
wideglidejrp offline
I am suddenly getting a stream of errors from the plugin. I have been using 1.5.5. I downloaded 1.60 but it will not install. An error message says something is wrong with the plugin.
John Patrick
Author of Home Attitude
http://johnpatrick.com
Thu Aug 16, 2018 8:37 am
berkinet offline
wideglidejrp wrote:
...An error message says something is wrong with the plugin.
Could you post the actual error message.
Thu Aug 16, 2018 8:41 am
Sorry, here is the actual error message.
Screenshot 2018-08-16 10.39.56.png (21.45 KiB) Viewed 928 times
John Patrick
Thu Aug 16, 2018 8:44 am
berkinet offline
I have no idea. Did you download the plugin from the Plugin-Store? I just downloaded a copy and it installed without any issues.
Was there anything in the log?
Thu Aug 16, 2018 8:46 am
I downloaded from a page somewhere in Indigo. Could you give me a link to the download you used?
John Patrick
Thu Aug 16, 2018 8:47 am
berkinet offline
It is in the Plugin Store.
Thu Aug 16, 2018 1:26 pm
Of course. Sorry to not be thinking. I went to Plugin Store. You have a nice prominent spot there at top left. I downloaded the file and launched it. Got exactly same error as before. I am using Indigo 7.1.1. I restarted my Mac and tried again. Same result. Any suggestions on how to diagnose this?
John Patrick
Thu Aug 16, 2018 1:37 pm
berkinet offline
I’d drop Matt and Jay a note.. My guess is a corrupted plugin settings file. Unfortunately, I a,m not near a computer right now to tell you exactly how to find it.
Thu Aug 16, 2018 3:08 pm
I dropped them a note as you suggested. They asked if anything appeared in event log. Here is what I got….
Aug 16, 2018 at 4:55:04 PM
Error plugin "ad2usb.indigoPlugin" is missing file: /Users/jrpatric/Downloads/ad2usb.indigoPlugin/Contents/Info.plist
They said, Forward that information on to Berkinet. Looks like whatever you downloaded is missing a critical file (Info.plist).
John Patrick
Fri Aug 17, 2018 3:44 am
berkinet offline
Except, the file is included in the download...
    ..:Downloads:ad2usb.indigoPlugin rdp$ ls -lR
    drwxr-xr-x@ 7 rdp staff 238 Aug 17 11:33 Contents
    ./Contents:
    -rwxr-xrwx@ 1 rdp staff 742 Nov 29 2017 Info.plist
    -rw-r--r--@ 1 rdp staff 8695 Nov 27 2017 Release_notes.txt
    drwxr-xr-x@ 3 rdp staff 102 Nov 29 2017 Resources
    drwxr-xr-x@ 13 rdp staff 442 Aug 17 11:33 Server Plugin
In the finder: navigate to the plugin you downloaded; right (control) click on the plugin; select Show Package Contents; open the Contents folder and see if Info.plist is there. If it is, then there is some issue in the way Indigo is opening and trying to install the plugin. If it is not there, then: open the Resources and Server Plugin folders and tell me what files you see there.
Fri Aug 17, 2018 9:44 am
The file he was dealing with was the zipped plugin, but it was missing the .zip extension. Not sure how he got it into that state.
Fri Aug 17, 2018 9:51 am
All is well now with updated plugin installed. Fyi, when I went to Plugin Store and clicked to download latest release the download dialog I received was as show here. Since it needs to be a zip file, why does that not appear? I realize now I should have changed it to .zip but curious why .IndigoPlugin appeared.
John Patrick
